Question about Logitech 967437-0403 Keyboard
Keyboard is locked
Keyboard seems to be locked - only key that seems to work is standby (looks like power button PC) upper right above numeric keypad
  • rohb Jan 16, 2013
    If none of that works ry restarting the computer after double checking all the cords are tight and in place
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 109 Answers
Take the batteries out and put them back in - in a different order and push the re-connect button (usually red) hold it and wait for it to pick up the signal make sure no of your wires came loose - sometimes wires can get cause on drawers or chairs knobs and other things around the desk when we don't noticed and get dislodged so make sure the connection is all the way connected
Posted on Jan 16, 2013
5 Suggested Answers
  • 3 Answers
SOURCE: MX 3200 Cordless Laser Keyboard - Logitech
Press the FN key and *at the same time* press the F10 key for 1 second.
The first part of the time should start to flash.
Use the up / down keys to change the hour, then press TAB. The minute figs. should now flash. Use up/down to change the minutes and press TAB.. do the same with the date and month etc, you can also set 12h or 24h clock.
When you are finished press ENTER.
Posted on Jul 30, 2008
SOURCE: Power Saver not working
The Logitech wireless keyboard "moon" key set the power saver on but would not return the screen no mater what key I hit. So, I connected a standard wired keyboard and hit the space bar. Once returned I disabled the "moon" key though the Logitech software.
Posted on Nov 19, 2008
SOURCE: The keyboard of Logitech dinovo cordless desktop stopped working.
Hi I have exactly the same problem. Did you find a solution?
Please email me gygglechick@gmail.com
Posted on Mar 29, 2010
SOURCE: Logitech MX 3200 wireless keyboard Numeric (right side) keypad does not work.
I recently bought just a numeric keypad (logitech) and it didn't work either. Found that the following worked for me. I have Windows 7.
Click the start button, "Accessories", "Ease of access", "On sceen keyboard". When the keyboard comes up, click on "Options". Check the box "Turn on numeric keypad". Click "OK". Then on your computer keyboard or on the on screen keyboard, turn on the "Numlock".
Posted on Aug 04, 2012
Numeric keypad on keyboard stops working after signing onto desktop computer
Sounds like a short key is being activated when you are pressing series of buttons disable short keys on your PC options menu or hold down the shift key then disable the short/hot keys menu
Feb 22, 2013 | HP Pavilion Computers & Internet
Tip
How to lock or unlock a Samsung Intensity
Many people like the Samsung Intensity because of its slide-out QWERTY keyboard. However, one drawback to the phone for some users is that, unlike a flip phone, the numeric keypad is always exposed. When the Intensity is kept in a pocket or purse, this can result in accidental phone calls, multiple all-black pictures, and sudden activation of the voice command feature.
Luckily, you can lock the phone's keypad to keep it from engaging any functions when you're not using it. Locking the keypad is easy. Just hold down the 0 (zero) button for about two seconds, and a message will pop up telling you that the keypad has been locked. While it's locked, you won't be able to use the numeric keypad.
The standard way to unlock the phone is to press the upper right options button (the one that you would typically press to bring up your Contacts list) and then press the center OK button. (You will see prompts for both of these buttons when the phone is locked.)
However, there is also a quicker way to unlock the phone -- just slide the keyboard open. Sliding the keyboard open will unlock your numeric keypad immediately, and even when you close the keyboard the phone will remain unlocked. If you want to lock it again, you'll have to hold down the zero button to re-lock it.
You can also enable Auto Key Lock mode, in case you think you'll forget to lock your phone. With Auto Key Lock mode turned on, your phone will automatically lock itself when it's not in use and the backlight goes off. You can turn Auto Key Lock mode on or off from the Phone Settings menu.
on Jun 28, 2010 | Cell Phones
My numeric keyboard is not working, the num lock is on.
Have you tried booting up in safe mode to see if it does the same thing? Also check your keyboard to see if there is some type of key combination that locks or unlocks the numeric keypad. If so, usually you will have to hit the FN key or the ALT key or the CTRL key plus some other key to get it to toggle.
Mar 31, 2012 | Toshiba Computers & Internet
When i type the letters on my keyboard, the numbers show up instead. i don't know how to revert the system or functions back to normal. i must've accidentally pressed a button to change the characters when...
Sounds like the keyboard is in NUM LOCK mode
They keys map like this:
7 8 9 = 7 8 9
u i o = 4 5 6
j k l = 1 2 3
0 . = m .
Look for the NUM LOCK key on your keyboard.
Typically, you press the FN key (lower left corner) and the NUM LOCK key (typically towards the upper right) together to put the keyboard back into regular mode.
Apr 21, 2011 | Twinhead DURABOOK N15RB Notebook
Some keys register different characters. For example the O registers the number 6 when it is typed.
This should be a simple fix, look at your keyboard, you should have a function key and if you look at the number pads above the top row of letters there should be either a numerical symbol or a key pad, your keyb board is simply using several keys as an extended numerical keypad. If you look closely at the letters there are small numbers on them. To fix hold down function key and pressing the keypad button. You can also try pressing the number lock.
Al
Aug 04, 2010 | Sony VAIO Notebook
I NEED A MANUAL TO SHOW HOW TO GET MULTIFUNCTION KEYS TO WORK. FOR EXAMPLE HOW DO I GET THE ALTERNATE USE OF THE "NUMERIC 6 "KEY ie THE" QUESTION MARK" FUNCTION
You must have a different keyboard selected other than the standard US keyboard My numeral 6 has ^ on it and the numeric keypad 6 has a right arrow. One generally uses the SHIFT key to access symbols that are written above the main alpha or numeric key. The numeric keypad on side of PC has a button labeled key marked NUMLOCK that is engaged to allow use of the numerals as a calculator or to also be inserted into text.
Please rate my help++++Thanks for using FIXYA
May 09, 2010 | Acer NSK8458AN Keyboard
Unlock numeric key pad on lap top
your laptop should have a blue FN key (Function) that will work in conjunction with other blue keys on teh keyboard. most laptops this is located in the lower left, next to the ctrl key. Look to the right top on your keyboard for a one labeled numlk. hold down teh left FN key and tap the right num lk key and you just turned off the numbers lock.
There is another option that is a little more intense - if interested let me know that laptop type you have.
Feb 04, 2010 | Microsoft Windows XP Professional
How do i activate and lock my Fn keys
Unlike previous models, The 1545 has no imbedded Numeric Keypad, so there is no NUMLOCK option.
For numerics, you will have to use the numbers above the QWERTY row.
SCROLL LOCK was also eliminated from the 1545 keyboard (Legacy item, seldom used)
If you need a numeric keypad and/or Scroll Lock, then an external keyboard may be an option.
Mar 25, 2009 | Dell Inspiron E1505 Notebook
Keyboard letters 'm,j,k,l,u,i,o' permanantly locked for numerals. i have no idea how i switched this function on.
NumLock is on. Look for the Fn key in the lower left corner, and lookint in the top right, the NumLock key.
Mar 22, 2009 | HP 2133 Notebook PC
Acer Aspire 7520 numeric keypad problem
Try pressing the numlock key in the upper right part of your keyboard. Chances are it's turned off and therefore the numeric keypad will not work.
Feb 05, 2009 | Acer Aspire 5500 5570-2609 Laptop
Logitech 967437-0403 Keyboard Logo
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
