Question about Pool & Spa
Spa does not start. Control panel shows a broken line only. Nothing else. Power and fuses ok.
Seris 800, 1998 model
  • 717 Answers
Control panel shows broken line...what is the error code for that?
Can you get me some more information as to what the spa was doing before it quit?
Rod
US Parts Center
Posted on Feb 06, 2013
2 Suggested Answers
  • 2468 Answers
SOURCE: Hi there, I have had a Key's Backyard Spa for
Hi Donna:
I believe you can find both of your inquiries at (www.SpaCare.com),type in VS-500 in the search box and below the picture of the board you can download the troubleshooting manual free in PDF form,I will also call you in case you have questions,Thank You for usinf Fixya.........Daniel(608)214-5632
Posted on Feb 20, 2011
I have a sundance spa 880 that does not start. The control panel shows only a broken line and nothing else.
When you say broken line, do you maybe mean " - - - - " like 4 dashes?
That is called a Watchdog, where the spa internal smart circuitry has sensed a potential damaging problem. Many things could be causing this. If you turn power off and upon re-energizing power, push jets button. Does it come on? This needs to happen immediately after powering up. Using a 2nd person is a great asset in this.
Jan 15, 2013 | Pool & Spa
Display shows SF on model H150ED2
SF is the code for Temperature sensor input failure. check wiring that goes to temperature sensor for brakes or cuts, sensor is located on right lower side of heater where water lines go in. you have to remove the 6 screws to take the side panels off above and below the water lines. sensor is visible then.follow wires back to control board and make sure they are securely pluggin in to board and all broken wires fixed or replaced. If no broken wires or loose connections, Replace temperature sensor.
Aug 29, 2011 | Hayward H Series Pool & Spa Heater...
Hoshizaki klm-450mah ice maker: nothing happens when machine is turned on. this unit has been trouble free for the last 5 years. after turning the unit on everything started as it should and one load of...
http://www.hoshizakiamerica.com/manuals/KML_F-and-H_series_serv.pdf
This is the service manual for you machine. The wiring diagrams on pages 56 and 57 shows that the machine does nothing unless the bin control is in the "Closed position. It is a temperature controled switch. If it is broken, not works. Check that out first.
Jan 13, 2011 | Hoshizaki Ice Maker 30in 550lb Crescent...
When pushing start button on spa pump does not kick in at all, tested power point and working ok ..What could be the problem and solution. Brian C
If you know that power is getting to the computer board then it is either a bad top-side control panel, or a bad relay on the computer board. If this is an older model, replacing the relay may be possibly. If this is a newer board, they build them right into board so a new board is neccessary.
Note: Make sure to check all fuses on the main board before coming to the above conclusion. If you know how to do a continuity test with a multimeter, do this will ALL fuses before replacing anything.
Iyou are not proficient with a multimeter, visually inspect the fuses for breaks in the filiment (if the is a high voltage slow blow fuse that is solid white, start by replacing this fuse. It should be available at any decent hardware store.)
Nov 11, 2010 | ADVANTAGE Waterway Spa Pump 3/4 HP 115v
HAYWARD H250ED2 HEATER WILL NOT GO ON EVERYTHING CHECKS OUT FINE.
agreed; it's usually the diode D1 on the board...a 75 cent part
Sep 10, 2009 | Hayward H Series Pool & Spa Heater...
"Jacuzzi j-400 series" hot tub- F1 code flashes on control panel
Your circulation pump isn't working you should see the flow awitch closing if you have the visible model and hear the pump running.. If its the smaller circulation pump model it needs replacing
May 18, 2009 | Jacuzzi Bath Nova H530 917 Black Soaking...
Pool & Spa Logo
54 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
