Question about Dryers
Dehumidifer wont turn on
Model ad50usl1
  • 314 Answers
What is the name of the dryer please rate for clean solution
Posted on Jan 15, 2013
How do you add more freon?
Make sure the thermostat sensing tube is in it's place first. The thestat can be faulty too. The likely hood of Freon leaking is remote but possible. You need a whole bunch of special equipment to find the leak, repair it and recharge the system.
Aug 27, 2014 | LG LP1111WXR Portable Air...
Float Switch
Contact there customer service at: www.sylvane.com 1-800-934-9194. you will need model number etc.
Feb 18, 2014 | Winix WDH751 Dehumidifier
DEHUMIDIFER WONT START
empty the tank, and clean the dust off of the condenser in the front or clean the filter. if it still won't turn on, may have a bad sensor or a siezed compressor.
May 09, 2012 | Midea Dehumidifiers
Goldstar dehumidifer model GDH 30 wont turn on
first check outlet, some have a killer switch at base of unit, and if not setting level will not turn on.
Sep 30, 2011 | LG DH30 GoldStar Dehumidifier
The dehumidifer doesn't
sounds like your evaporator coil is dirty its the coil where the air goes in
Apr 08, 2010 | Whirlpool AD50USL Dehumidifier
Runs, but no dehumidification. 6 months old.
If the room tempature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defost over night.
Only specially made dehumidifers work below a room temo of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Dec 30, 2009 | Haier Dehumidifiers
The temperature it says it off by 3 or 4 degrees. It's making the house too cold.
if it is a vision pro you need to change the settings in the installer mode, it has the option of + or - degrees, if it is the model with dehumidification (the 21 series then shut off or adjust the setting to a higher humidity, the dehumidification option as it will allow a three degree "droop" to help remove humidity. the installer sopuld have left a book with instructions on how to enter installer mode, if not it is available at the mfg website
Jul 13, 2009 | Honeywell Programmable Thermostat Heater
Snow on the Tv screen
Make sure the dehumidifer is grounded with a 3 pin plug, into a 3 pin recepticle. If so, try plugging the dehumidifer or the TV into another power outlet.
Mar 23, 2008 | Philips Magnavox 27MS343S 27" TV
No water in tank
have you turned them off, waited a long time, and restarted? if yes, but still problem, both have developed freon leaks. the coils may have "frozen over", verified by looking at them-do they appear frosty? caused by humidistats that are not functioning properly (starting to corrode)...try turning down the stats to allow motors to rest (and frost to melt)
May 27, 2007 | LG DH404E Dehumidifier
Dryers Logo
29 people viewed this question
Top Dryers Experts
