Question about Panasonic Viera TH-42PX80U Plasma TV
Sub 5V SOS / Sub 3.3v SOS Tuner Power SOS - Panasonic Viera TH-42PX80U Plasma TV
Panasonci Viera 50
10 blinks is the Miscellaneous error code. Your TV knows something is wrong, but isn't sure what it is. It can be any number of things, including bad boards. Generally A red light blinking 10 times means that a video board has gone bad. viz.
Sub 5v SOS / Main 3v SOS DG Board/ DTV 9v SOS / Tuner Power SOS
Jan 10, 2012 | Panasonic Televison & Video
Tip
BLINKS PROBLEM MALFUNCTIONING PART
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
on Apr 12, 2009 | Panasonic Viera TH-50PX80U Plasma TV
Error code 11 flashes shown on the power LED
HI:
Sorry for your luck. If you just bought it I would definitely return it. Here are the codes for your set.
12G Models :
X24 / C2 / U2 / S2 / G20 / G25 / VT20 / VT25
Code:
BLINKS PROBLEM CHECK POINT
2 blinks 15v SOS D-Board / P-Board
3 blinks 3.3v SOS D-Board
4 blinks Power SOS P-Board
5 blinks 5v SOS D-Board
6 blinks Driver SOS 1 SC-Board / D-SC FPC
SC Energy Recovery Circuit
D-SC FPC DET
7 blinks Driver SOS 2 SU-Board / SD-Board
SU/SD Connector DET
SU/SD Scan and Logic IC
8 blinks Driver SOS 3 SS-Board / SS2-Board
SS FPC Detect
SS Energy Recovery Circuit
9 blinks Discharge Control SOS D-Board
10 blinks Sub 5V SOS / Sub 3.3v SOS A-Board / SC-Board / SS-Board / P-Board
Sub 9V SOS / Tuner Power SOS
MIHO 3.3 SOS / LED 8v SOS
11 blinks Fan SOS A-Board / Fan
12 blinks Sound SOS A-Board / Speaker
Good luck
Apr 20, 2011 | Televison & Video
Error code 11 flashes model TCP50VT25
12G Models :
Code:
D-SC FPC DET
SU/SD Connector DET
SS FPC Detect
Good luck
Apr 20, 2011 | Panasonic 50 in. Plasma TV
My tv is giving me the 10 blink issue. Can I buy an ABoard online and replace it myself or do I need to know how to solder?
found this tonight:
Dec 12, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
My Panasonic was working fine when I shut it off last night and I turned it on today and everything has a pink tinge to it now. It seems as though I lost a color. Can someone help me address this issue...
found this tonight:
Dec 12, 2010 | Panasonic TH-42PX60U Television
My TV just turned off and the power light flashes 8 times. what is the flash code for 8 times on a panasonic TC-50PS14
thought I would post this here for everyone.
May 14, 2010 | Panasonic Televison & Video
Th42px80u- tv wont come on and red light flashes 10 times
Here are all the Panasonic blink codes.
Oct 21, 2009 | Panasonic Viera TH-42PX80U Plasma TV
No picture and the led ligth is blinking panasonic veita 52
If you have the flashing red light of death you can use the chart below, and call Panasonic to have it replaced. At the bottom is the list terms.
Panel = Plasma Display Panel (Plasma Glass)
D Board = Format Converter / Plasma AL / Sub-Field Processor
DG Board = AC-DC Converter / Digital Signal Processor / Full HD
Microcumputer HDMI Interface / Peaks Lite 2
H Board = Speaker Out / Sound Processor
AV Terminal / AV Switch
P Board = Power Supply
PB Board = Fan Control
SC Board = Scan Drive
SD Board = Scan Out (Lower)
SS Board = Sustain Drive
SU Board = Scan Out (Upper)
Jun 11, 2009 | Panasonic (TH-50PZ700U) Television
The power light keeps blinking and it doesnt matter if i unplug the tv and plug it back in when i go to turn it back on it just blinks.
the blinking power light is actually a diagnostic of a faulty part inside the set.
Here is the diagnostic info and which part you need to replace.
if this set is still unedr warranty, please use the warranty to replace the part. Else, have a professional install the new part for your safety.
hope this helps.
regards,
voodoo
Jun 09, 2009 | Panasonic Viera TH-50PZ85U Plasma TV
Panasonic Viera TH-42PX80U Plasma TV Logo
106 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
