Hotpoint Aquarius TVF760. What is causing F07 error?
3 Suggested Answers
SOURCE: hotpoint Aquarius WF740
Hello again update on error f05 was a sock blockage in the black rubber tubing that connects from bottom of drum to the pump it was a easy fix just plastic clips holding it on make sure you turn off electric first lol !!!! all working fine now.
thanks daddonk
Posted on Jan 20, 2008
  • 193 Answers
SOURCE: h20 error on hotpoint
Lift the lid and check that clear hose is connected to the pressure switch.
Posted on Nov 02, 2009
My hotpoint aquarius tvf760 tumble dryer keeps flashing and saying error-07........ Has it died?
Not really, just a bit sick. I found this
F07 Lower tumble dryer element failure
  • Check security of module connector J4
  • Test between pins 4 and 3 on J4 (approximately 48 Ohms). If open circuit, test lower element and wiring between J4 and the heater.
Nov 27, 2015 | Hotpoint Dryers
Hotpoint aquarius super silent WF630 FAULT CODE F02
[/spoiler] [spoiler title="EVO1 Washing Machines and Washer Dryers" open="0" style="2"]
  • F01 - Short circuit motor triac*
  • F02 - Motor jammed tacho detached*
  • F03 - Wash thermistor open/short circuit*
  • F04 - Pressure switch jammed on empty*
  • F05 - Pressure switch jammed on full*
  • F06 - Program selector error*
  • F07 - Heater relay stuck*
  • F08 - Heater relay cannot be activated*
  • F09 - Incompatible eeprom*
  • F10 - Pressure switch not sensing correctly*
  • F11 - Pump cannot be activated*
  • F12 - Communication error*
  • F13 - Dryer fan or dryer thermistor faulty*
  • F14 - Dryer element faulty*
  • F15 - Dryer element relay faulty*
  • H20 - Not fillings. Check tap, hose and inlet valves
  • LOCKED - Check interlock*
Error Codes Hotpoint Service
Aug 24, 2015 | Hotpoint Washing Machines
Hotpoint TVF760 Aquarius + change belt
Hotpoint tumble dryer not turning? How to replace a Hotpoint tumble dryer belt.
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. 9 rib stretch tumble dryer drive belt Contitech 144001958 9PHE 1860 How...
Aug 06, 2013 | Dryers
Hotpoint aquarius tvf760 dryer where do wires go on control box
Is it 3-wire or 4? With three, the ground/neutral (combo) attaches to the center and the two hots go onto the outer screws. With four, match up the colors of the wires in the dryer with the colored wires on the power cord.
May 12, 2012 | Hotpoint Dryers
My hotpoint aquarius washing machine is flashing f-07
For most Hotpoint (Indesit) models 'F07' means 'heater relay (possibly) stuck'. 'Check power supply connections to the heater, wiring and module (i.e. PCB) connections' (apparently poor PCB connections are often the cause).
So- if you are not electrically confident and competent yourself, which you may be, you need to employ the skills of a partner, friend or service engineer ;-0)
Sorry we cannot be of more help!
Good luck, John C
Mar 30, 2011 | Hotpoint Washing Machines
F-07 flashing on display
For most Hotpoint (and other named) models 'F07' means 'heater relay (possibly) stuck'. 'Check power supply connections to the heater, wiring and module (i.e. PCB) connections' (apparently poor PCB connections are often the cause)
Good luck,
John C
Mar 14, 2011 | Hotpoint Aquarius WF000 Front Load Washer
(and again!) Hi from retired Englishman in SW France,
Good luck,
John C
Mar 14, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius cycle not finishing with f02 error
Dont think its pressure switch.if sticks one way machine overfills the other brings on heater with empty drum..Could be fauly rinse solonoid valve...Check with multimeter coil should read around3k ohms..good luck
Sep 29, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Fault code F-07 on the display
Error code F07 indicates the heater relay is stuck, this is not recommended as a D.I.Y repair, my advice would be to call an experienced engineer to look at it, as there may be other probs that have caused this to happen.
Plz rate my soution
Thanks.
Jan 07, 2009 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
66 people viewed this question
Top Washing Machines Experts
