Question about Saws
Change blade for delta 81/4 miter saw Model 36-040
rowdy45176
  • 2176 Answers
SOURCE: I have a 10"DELTA Miter
Without a model number I cant look for this saw, but if it is like the other mitre saws that I work on, the lower guard should have a bolt holding it in place, loosen the bolt so you can move the guard and the blade bolt is usually LH thread, on the backside of the gearcase by the blade there should be a spindle lock, rotate blade until it locks and then remove bolt. If your saw is different please give me the model number and I will pull up a schematic and look at it.
Posted on Jan 17, 2009
rowdy45176
  • 2176 Answers
SOURCE: change blade
OK first raise the cutting head. Loosen the screw that holds the guard in place and move out of the way. Find the spindle lock on the right hand side of the gearcase and turn blade by hand (UNPLUG SAW FIRST) until it locks. With the wrench supplied with saw put it on the blade bolt and turn it clockwise to loosen, it has left hand threads, remove outer flange and blade. Let me know it you need any more help
Posted on Jan 26, 2009
picatudo
  • 239 Answers
SOURCE: changed delta saw blade
it turns the other way, to the right!
Posted on Feb 07, 2009
efs_perpends
  • 1996 Answers
SOURCE: Cant find owners manual for Delta compound miter saw model Ms250
Go to this link and you'll be able to download a pdf file with the manual you're seeking: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Delta/A05737.pdf
If this solves your problem, please take a second to rate this post and let us know! Best wishes!
Posted on Mar 25, 2009
efs_perpends
  • 1996 Answers
SOURCE: Need manual for Delta 10'' compound power miter saw MS 250
If you can't print from your computer, or local library, find a local print shop or copy shop that is willing to download and print a .pdf file for you.
Then go to this link and you'll be able to download a pdf file with the manual you're seeking: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Delta/A05737.pdf
How do you "unlock" the Delta miter saw?
To unlock a miter saw, push down on the saw to unlock the head and loosen the knob on the table to make adjustments. Start using a miter saw with help from a custom furniture maker in this free video on woodworking tools. Read more: How to Unlock a Miter Saw How to Unlock Miter Saw Best Miter Saw Reviews Real Man Miter Saw
Oct 22, 2011 | Delta SM100M 13 Amp 10" Compound Miter Saw
The blade on my Delta Model 36-075 miter saw spins freely - motor works fine - i disassembled down to the gear drive - the gear appears to be fine no missing teeth or obvious damage. Does the inner shaft...
hi, on your Delta saw shaft has two flanges which one goes in front of the blade and the other behind the blade. These flanges have two flat spots in the center of it which over the shaft, the blade has the same cut out so you need to check your shaft, flanges and blade to make sure they are all locking on the shaft. Do not forget to unplug the saw before you do any work.
Feb 09, 2018 | Delta Saws
How do I replace a blade on a Delta 36-585 miter saw
There should be a wench on the mecnine that fits the bolt. the bolt turns in the oppiste derection as a normal bolt its called left handed thread this keeps it from coming lose during use. There is a buttom you need to press to lock the shaft then lossen to bolt lift the blade gaurd replace the blade note the washers that go up against the blade and make sure you install then in the same order as they were removed
Dec 17, 2010 | Delta SM100M 13 Amp 10" Compound Miter Saw
Need to adjust Miter gauge for Delta tablesaw 36-977. The 90 degree stop is off
1) Before setting the Miter gauge, check that the blade is straight (parallel) with the slide grooves. Lock a board in the miter gauge and place against the front of the blade, and then the back of the blade. Is the distance EXACTLY the same (it won't matter if the miter gauge isn't straight and square). If not, you'll need to loosen the table and rotate the blade holder to square it up.
2) Now Cut a board in half the flip one side over and place the cut back together. If it isn't straight, the resulting board will have a "dog-leg".
3) Adjust the miter-set-screw until the cuts on the trial board yield a board that comes out straight (or use a Framing square to check).
Dec 31, 2009 | Delta 36 977 Left Tilt Contractors Saw
How do i change the blade on my delta 10" mitre saw
Exploded diagram for your SM100M miter saw is here.
User manual is here.
Page 20 covers blade change operation.
Make sure you unplug your saw! You need to remove a screw from the cover and rotate the cover to the rear. Use a hex wrench in the motor shaft to keep the saw blade from turning, and loosen the arbor nut with a 1/2" wrench. The arbor is reverse threaded, so you'll turn it clockwise to loosen, then counterclockwise to tighten it up after you have swapped the blade.
Rotate the cover back after that's done, and replace the screw.
If this was useful, please vote. Thanks.
Nov 23, 2009 | Delta SM100M 13 Amp 10" Compound Miter Saw
Change blade miter saw
Un-plug the saw. Remove the screws holding the side saw guard in place. Look at the center of the saw blade for the nut holding it in place. Take a socket wrench that fits the nut and loosen it. You'll need to take a scrap piece of wood 2x4, and jamb the teeth of the blade into it while loosening the nut. The nut will come off first and then a washer/spacer.
Reverse the order for installing the new blade. Make sure you use the proper size diameter blade (10 inch) and mounting hole in the replacement blade. Also, use the provided washer/spacers that were on the original blade and secure the nut. Spin by hand to see if everything clears. Mount the protective guard back on. Plug in the saw and test cut .
Good luck. If you are still unsure - ask a handy neighbor to help. It takes about 5 minutes to complete this task.
Oct 05, 2009 | Delta Cycle Rothko Rolling Bicycle Stand
How do I align the saw blade with the saw table I have a 10 inch Delta Contractor's saw that is about 10 years old. The blade is not straignt with the miter slot. andyc@bergeralllied.com
The Blade Arbor is held to the bottom of the table with mounting screws and stop/adjusting screws. Loosen the mounting screw and adjust the stop screws to make Blade true with miter slot.
Sep 14, 2009 | Delta 36 982 10 Inch Left Tilt 1 1/2...
I have a 10"DELTA Miter Saw and need to change blade. Please describe how to remove and replace blade. Thanks
Jan 16, 2009 | Saws
Changed delta saw blade
Oct 18, 2008 | Saws
Saws Logo
136 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
