Question about Sterling Home
I need a new flush valve assembly for an original Sterling Devonshire toilet..part #4691. It was Sterlings design before Kohler moved the line to theirs.
I can not find the parts breakdown for this toilet tank
  • 979 Answers
Have you found what you needed yet.
Posted on Feb 04, 2013
slacko
  • 5 Answers
SOURCE: pf/2 geberit tank assembly
is the syphon lifting every time?
Posted on Dec 05, 2008
smokenic
  • 49 Answers
SOURCE: K3367 one pice toilet harmonic vibration
check your water preasure. it sounds like it's to high and you should adjust your prv
Posted on Sep 20, 2009
bearsfan7538
  • 119 Answers
SOURCE: I have 2 K3466 model Kohler toilets and just had a
There is a volume control screw on the valves usually a plastic thumbscrew on side of valve turn clockwise until they quiet up the plumber should have adjusted that these are very tempermental toilets but when adjusted properly are excellent toilets I have 2 in my own home
Posted on Nov 15, 2009
  • 119 Answers
SOURCE: How install Kohler part no. 87988 in Santa Rosa
look under the tank, their should be a nut holding on the old one. by removing that nut the part should free itself.
Posted on Mar 28, 2010
  • 83 Answers
SOURCE: After flushing my Kohler 3386
sometimes removing the 3 or 4 screws that hold the top of assemble and separating the assemble will dislodge debri..and adjust the seat so that the water comes out of the small tube into the overflow tube like it should.
Posted on Nov 25, 2010
Have old kohler, i do not know what the inside flapper part is. However toilet will flush but tank will not fill. I can turn thhe water to the tank off and turn on again and it will fill
This indicated that there is dirt of corrosion in the flush valve assembly that get jarred loose and flushed out when turning on the supply valve below. My recommendation is replacing the flush valve assembly with a Fluidmaster flush valve. Be sure to follow the instructions when removing the old valve and installing the new one. If you need step by step instructions, please message me and I will provide them.
Dec 05, 2010 | Kohler Home
Can't install new Kohler rialto Flush Value
First things first, remove the fill valve, and the flush handle mechanism. This will give you plenty of room to work with the flush valve. Before installing flush valve lubricate tabs with plumbers grease. Now put on a pair of work gloves, pushed down very hard and turn the tabs should slide easy because of the grease. Remember do not alter the gasket, the gasket needs to be compressed to do its job. I know removing the fill valve and the flush handle seems like a pain, but there is no way to get your hands in the proper position to install the flush valve assembly.
Apr 25, 2010 | Kohler K-3386-0 Rialto one-piece...
Igenium Flushing valve will not shut off.
THE WHITE PIECE IS LOCKED IN YOU MUST PUSH DOWN AND TURN A HALF OF TURN .THEN LIFT IT OUT,DON'T DAMAGE YOUR O RING
Apr 05, 2010 | Kohler K-3422 - Wellworth Elongated...
We have a Devonshire pedalstal sink that is clogged and we can't snake with the P trap it just gets hung up. Plunging hasn't worked. Any ideas?
You need to remove trap and rod from the wall opening I have had to remove many pedestal sinks in order to rod the drain
Nov 15, 2009 | Kohler K-3488-0 White Devonshire...
I have a new sterling 1.6gpf toilet can I increase the amount of water in the bowl. Every time or almost everytime, waste sticks to the bowl and I have to brush it loose.
If you raise the water level in the tank it will double flush. I suggest you change out the toilet to a Toto or Kohler class five flush action.
Nov 13, 2009 | Sterling Home
Oct 26, 2009 | Kohler K-3466-95 San Raphael one-piece...
What is the procedure for replacing the flush valve assy on a san raphael toilet. it is a one piece tank and bowl assy and must install from the inside of the tank. it appears to possibly rotate into place...
If you purchase the flush valve from Kohler, it comes without instruction. Rotation is the key to removal. First note the exact orientation of the assembly before attempting removal. Unhook the flapper chain and remove the flapper. The old assembly does indeed rotate in either direction for removal. I used a counterclockwise motion. (it was a tough turn, don't break the bottom of the bowl where the valve seat is located.) Then install the new foam gasket on the assembly. The new assembly is replaced in the reverse manner. I removed the new flapper from the flush valve for ease of install. You must put significant downward pressure on the flapper seat while rotation is accomplished. Orient the assembly as was the old one. Replace the flapper, connect the chain and observe the flapper for proper opperation.
Oct 03, 2009 | Kohler K-3384-2-0 San Raphael elongated...
Sep 13, 2009 | Kohler Toilet - One Piece with Ingenium...
Kohler one-piece has no flushing power
Hi
try to increase the amount of water for each flush .
Jul 17, 2009 | Kohler Toilet - One Piece with Ingenium...
Home Logo
131 people viewed this question
Top Sterling Home Experts
Tim Whalen
deton8 von Splosion
Are you a Sterling Home Expert? Answer questions, earn points and help others
