Question about HP 920 Plain Paper Fax
Fax query I have a bother fax 920 and have just got rid of my separate fax line and had a duet line put on my home phone number. (A duet line allows me to keep the same fax number I had before without having a separate line.) Does anyone know how to set the fax up so it works properly?
  • Anonymous Mar 26, 2014
    faxes and copies have lines
  • 59 Answers
This sounds like you have smart ring on your home line. Smart ring lets you have 2 seperate telephone numbers, One for fax and another for phone, but 2 distinctive rings all one one line. Check your manual to see if you have this feature and to set it up.
Posted on Aug 09, 2007
SOURCE:
Phone company added a dedicated fax line to the outside of my house and my home phone rings to my fax
Your wall outlet has four wires, the center two are the first line and the outside two are the new fax line. You need to go to Radio Shack and get an adapter to split your first and second line into two separate wires. The part number is below.
Steren® 2-Line 4-Conductor Splitter/Adapter (Ivory) pixel.gifModel: T07843 | Catalog #: 55034722
Mar 09, 2010 | Panasonic KX-FHD332 Plain Paper Thermal...
Each time I try to send a fax it says the number is busy when I know it is not
Dial the number on a regular phone and verify that the number ANSWERS with the fax tones immediately. If it doesn't, then the line will register as busy to your fax.
Jan 13, 2010 | HP 920 Plain Paper Fax
Faxes received locally from India, but cannot get faxes from USA
Because either they have the wrong phone number or they are not putting in the correct Country Code when dialing.
Nov 25, 2009 | HP 920 Plain Paper Fax
Fax series 920, can receive but not send faxes, error code 344*
Do you have or are you sending a fax to a party that has a DIGITAL PHONE SERVICE?
Jun 04, 2009 | HP 920 Plain Paper Fax
Home phone line and fax on one line
Mine is free from Bellsouth. I do not know about other phone companies.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 30, 2009 | HP OfficeJet 6110 All-In-One InkJet...
FAX, MODEL 920 NOT RECEIVING
Try calling your fax machine from a cell phone. If the fax doesen't answer, or if the line is busy, the phone line may be bad. Also check that the phone line to the fax is plugged into the receptical marked LINE, not PHONE. The PHONE receptical is to connect a telephone to the fax machine. If it still does not answer, try going into the fax menu and go to RECEIVE settngs. Try changing each setting, then call the fax with the cell to see if it answers. Write down each setting before you change it, so you can set it back if changing it does not solve the problem.
Jul 10, 2008 | HP 920 Plain Paper Fax
Fax issue on X5495
Yes you do unless it is a seperate phone number for your fax line.
Jun 26, 2008 | Lexmark X5470 All-In-One InkJet Printer
Epson ACULASER CX11NF incoming fax problem
Try this:
Unplug line from back of printer
Set the Incoming mode to autoswitching
set DRPD to Off so that it will recognize all incoming calls
** if possible call your telephone company and set a distinctive ring pattern for phone calls
replug cable on line port at the back of printer
then ask someone to send you a fax...
Feb 05, 2008 | Epson ACULASER CX11NF All-In-One Printer
Fax machine FO-P610
you could probally download a manual from sharps web, but you need to turn destintive ring to on, menu, 0, 3 I think
Nov 02, 2007 | Office Equipment & Supplies
HP 920 Plain Paper Fax Logo
135 people viewed this question
Clive
Clive
Thomas F. Schneider
