I have a Samsung SER-7000 till, and the journal paper end message wont go, i have the correct paper till roll, but i cant use the till untill this is rectified, thank you ...Sarah
How to change paper
This product uses 2 1/4in (57/58mm) wide standard thermal paper. Use the feed keys only when changing the paper. Do not pull the paper manually.
1. If prompted during use, or when setting up the printer for the first time, open the printer compartment by lifting up on the tabs located toward the back of the register. This will expose the printers.
2. Depending on each sides needs, use the release buttons to open the paper wells and release the print rollers.
3. Place the paper rolls into the paper well so it feeds from the bottom of the roll towards the front of the cash register (not the back). Pull the paper up and past the print heads towards the front of the cash register.
4. Once done, close the printer arms and use the feed keys to advance the paper.
5. To attach the journal roll to the back of the winding wheel, remove the wheel from the comparment. Put a small fold in the end of the journal roll and feed it under and around the tabs located on the wheel. Spin the wheel manually to take up paper slack.
6. Once the paper is attached, place the wheel into the holder in the back of the printer compartment. The part of the winding wheel with two discs should be on the right side.
Dec 23, 2015 | Royal 29445B Alpha 9500ML Cash Register
Hey I have a ER-5200M electronic cash register I have paper rolls full in my machine and it's coming up with warning J paper end ? Help please
after replacing the journal or receipt paper on the 5200 you must shut the top platen firmly and then press clear...sometimes it doesn't click all the way and you have to do it twice to get it to seat correctly. clear will then take away the message from the display
Jan 22, 2014 | Retail Supplies
HEAD UP ERROR WON'T CLEAR WITH "CL" BUTTON PRESSED AND FULL ROLL PAPER IN PLACE??
Did you check to see if the retainer has been removed, that the print head release lever is in the print position, or that there is a paper roll in the Receipt and/or the Journal? Aslo, make sure that he Journal Return wheel is not broke on the side that holds the wheel in place. That's the only time I have recieved that message.
Aug 09, 2013 | Sharp XE-A404 PC Desktop
I have casio te 2000 now not working. there is message JPAP-END
You need to replace the journal paper roll.
If anyone needs a Casio TE-2000 manual, one of our users has it here:
http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-2000_users_and_programming_manual.html
Jan 07, 2013 | Casio Parts Cash Register PC Desktop
My tec ma 1450 register won't work just blinks 0.00 and none of the keys work
With paper loaded properly, turn off/unplug register, turn MA or Service key to "Blind" position (approx. 5 o'clock), turn on/plug in register. "Status-C" will print on the receipt. Some of these TEC's won't reset after changing paper, and this procedure becomes necessary after each installation of a new roll of paper.
Jul 18, 2012 | Computers & Internet
My casio PCR -T2000 won't print receipt paper. The paper is not moving. There is no error on the screen. There is no jam. It is the correct thermal paper. I've tried turning power off and on and...
You haven't mentioned the journal roll, so I will assume it prints the journal but not the receipt. What happens if you press the post receipt button at the end of a sale. Does it print daily reports on both rolls? --------------------------------------------------------------------
If anyone needs a Casio PCR-T2000 manual, C-tech collective have it here: http://the-checkout-tech.com/manuals/cashregisters/Casio3.php
Jul 25, 2011 | Casio Parts Cash Register PC Desktop
MY CASH REGISTER CASIO TE 2000 HAVE ERR MESSAGE 12 AND IS NOT IN ENGLISH I NEED TO CLEAR THIS ERR MESSAGE AND CHANGE THE LANGUAGE TO ENGLISH
Hi. Error 12 means you have run out of journal paper. replace the journal roll. The language can only be changed when the machine is fully cleared back to factory specs, then you must re-program it. It would be best to take it to a dealer if you are not confident. -----------------------------------------------------------------------
If anyone needs a Casio TE-2000 manual, http://the-checkout-tech.com/manuals/cashregisters/Casio4.php
Sep 04, 2010 | Casio Parts Cash Register PC Desktop
What ink does a pcrt470 use
It doesnt use ink at all.....
It has a thermal printer...you have to use special thermal paper in it.....if you use regular journal paper it wont do a thing.
Sep 11, 2009 | Casio Parts Cash Register PC Desktop
Paper
Hi. The PCR-T470 is only a single roll machine, so if you had them printing at the same time, you would be handing the customer your journal when you gave them their receipt. This machine can be setup either as journal only (in which case you use the black takeup reel that sits inside the printer housing), or receipt mode (in which case you have the paper coming out of the front of the printer cover). The best thing about single roll machines is that when you have them in recipt mode (recommended), you can print the journal out of memory whenever you want. to do this, turn the key to X mode and press RC button until you see 'electronic journal', then press CASH to print it. you might be able to reset the journal by doing the procedure in Z mode (the manual isn't clear about this). Give it a try.
Hope this helps. Let me know if you have more trouble.
Mark
Sep 04, 2008 | Casio Parts Cash Register PC Desktop
Job waiting message appears on screen.
You can selectively clear information stored in your machine’s memory.
1. Press Setup on the control panel. The display shows the first menu;
FAX NUMBER/NAME.
2. Press ➛ or ❿ until ‘MEMORY CLEAR’ appears, then press
Start/Enter. The display shows the items you can choose to clear.
• FAX NUMBER/NAME : your fax number and name are cleared from
the machine’s memory.
• DIAL/SCHEDULE : clears the one-touch, speed dial, or group dial
numbers stored in the memory. In addition, all
the Schedule Job operations you have reserved
are also cancelled.
• JOURNAL : clears all records of transmissions & receptions.
• DEFAULT SETUP : restores all the option settings to factory default.
Only clear de Journal, don't clear the other.
Try this if it resolve the problem.
Nov 20, 2007 | Samsung SF-5100 Plain Paper Laser Fax
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
