Question about Acer Aspire 5732Z-4855 Notebook
Acer notbook black screen
Stays on but goes to black screen
  • Acer Master
  • 5,660 Answers
Acer Aspire 5732Z series of Notebook PC?
Need to test whether the problem is;
A) Graphics chipset,
Or,
B) Video Cable,
Or,
C) Inside the Display Assembly
Inside the Display Assembly problem could be;
A) Screen Inverter
B) CCFL Backlight
C) LCD screen
1) CCFL Backlight:
CCFL stands for Cold Cathode Fluorescent Lamp. (Bulb)
Similar to Fluorescent lighting used in homes, and businesses; but on a MUCH smaller scale.
According to searches for an LCD screen, the Aspire 5732Z series of Notebook PC; uses one single CCFL for a Backlight.
One example,
https://www.laptopscreen.com/English/model/Acer/ASPIRE~5732Z/
Average thickness is 2mm. That is a little larger than 1/16th of an Inch. Average length is almost as long, as the LCD screen is in height.
The CCFL contains MERCURY, just like it's larger 'cousins' used in homes, and businesses.
Mercury is a POISON. The bulb breaks EASILY.
If a CCFL is the problem, I STRONGLY recommend letting a professional change the CCFL out, OR just replace the LCD screen as a unit.
It contains the CCFL backlight,
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
View the last 8 photos.
Use a flashlight, and shine it at the LCD screen at various angles.
If you can make out graphics on the LCD screen, the Backlight is bad; or the screen Inverter.
90 PERCENT OF THE TIME the fault can be attributed to a bad screen Inverter.
2) Graphics chipset:
Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port, on the back of the laptop.
The VGA port is on the Back of the laptop, and next to the Ethernet port.
[ Which is right next to the DC Power Jack (DC_IN), that you plug the AC adapter (Charger) into ]
This is an example of a VGA cable, and VGA connector (Port),
http://en.wikipedia.org/wiki/VGA_Connector
Scroll down for the VGA cable example. Note that color of connector does not matter. It is usually Blue in color, though.
You can use a CRT type of monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By factory default settings, the display should show on the external VGA monitor.
No?
You have at least 3 display options available;
A) Internal monitor of laptop ONLY
B) Internal monitor of laptop AND external VGA monitor
C) External VGA monitor ONLY
Press, and hold the Fn key down.
(Bottom row of Keyboard, second key from left)
At the same time tap the F5 key once.
(The F5 key is the Display Toggle-Over key)
Still no?
Hold the Fn key down again, and tap once more on the F5 key.
No display on the external VGA monitor indicates a bad graphics chipset. More than likely the problem would actually be the mounting, of graphics chipset TO motherboard.
It is soldered directly to the motherboard using a BGA surface mount. (Ball Grid Array)
I doubt you have a graphics chipset problem, but this flowchart method entails that; and no 'stone should be left unturned'.
It would 'bite' if you tried diagnosing without checking the graphics chipset, and replaced video cable, screen Inverter, and LCD screen; only to find you needed repair on the graphics chipset mounting to motherboard; or replace motherboard.
3) Video Cable:
This is an example of the Video Cable. Acer deems it the LCD Cable, and that's what we will refer to it as also,
http://www.ebay.com/itm/Acer-Aspire-5732Z-LCD-Video-Cable-DC020000Y00-/360558336892?pt=US_Video_Cables_Adapters&hash=item53f2f39b7c
The long White connector at Top, plugs into the motherboard, in an area to the Top/Left of the Keyboard.
It then routes under the left Hinge, and up into the Display Assembly.
The smaller White connector below it plugs into the screen Inverter.
The LCD cable then connects to the back of the LCD screen, with the large connector shown to the Left side.
The small connector below it plugs into the Camera.
Just from normal repeated opening, and closing of the laptop; the LCD cable may become pinched.
This can cause pulling on it, and result in loose connections at motherboard side; and/or screen Inverter, and/or LCD screen side.
Could also cause damage to the LCD cable.
Stretched/Broken wires.
If the sheath of the LCD cable looks to be damaged, so may be the tiny wires inside the LCD cable.
http://www.insidemylaptop.com/disassemble-acer-aspire-5740-aspire-5340-laptop/
I will include a link to a free Service Manual, for the Aspire 5732Z series of Notebook PC. The above link, and other pictorial guides; are more for you to get a 'hands on' look, besides just looking at a Service Manual.
Here the repair is to Physically see, if you can plug those connections of the LCD cable, in tighter.
Visual inspection alone will NOT do.
http://www.insidemylaptop.com/replace-lcd-screen-acer-aspire-5733z-4851-laptop/
Tried to plug the connections in tighter, and does not cure problem?
Then the LCD cable is to be removed, and a continuity test performed on ALL wires in the LCD cable; with a multimeter set to OHM's. (1K)
Or perhaps take the LCD cable down to the nearest small computer shop, and have the resident tech check it for continuity.
Should only be a couple of bucks.
You MUST rule out the LCD cable before going on. Some may feel with the low cost of the cable, they may just replace it.
Parts changing I know, and not professional; but to each their own until you learn.
4) LCD cable checks out it's time for the screen Inverter.
The screen Inverter is a small circuit board, that converts the power, (Electricity) of the laptop; for the LCD screen, and CCFL backlight.
http://www.ebay.com/itm/New-LCD-Inverter-Board-Backlight-for-Acer-Aspire-5332-5532-5732Z-5732ZG-Series-/300612724754?pt=US_Laptop_Screens_LCD_Panels&hash=item45fdea2812
To test requires a sensitive multimeter. Read fairly expensive.
http://www.fonerbooks.com/test.htm
The plastic frame in front of the LCD screen is the Display Bezel.
Acer? LCD Bezel.
The screen Inverter is located behind the LCD Bezel, and mounted towards the bottom of the LCD screen.
Due to;
A) Non-accessibility of a sensitive multimeter
B) Ease of accessibility of replacing
C) Low cost
,many decide to just replace the screen Inverter.
Again parts changing, but IMHO is justified this time.
[No. You do not want to drag the partially disassembled laptop, down to the nearest computer shop.
A) No tech really wants to come in on someone else's repair, and pardon me; but really not after a non-tech.
Liability issues are also involved.
B) Judge JUST one hour of their service rate, compared to the price of a screen Inverter ]
5) Screen Inverter checks out? (Replaced)
Then the problem is the LCD screen.
Service Manual,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
Go to the paragraph that starts with Aspire 1200. (1200 in Blue)
Drop down to the 9th line. (5720 in Blue)
Scroll across, click on the blue - 5732Z
[Ignore if you are aware;
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
(I would recommend upgrading to the newest version, though)
After you click on the file name (5732Z) it may take up to 30 seconds, before the first page comes up ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Jan 15, 2013
4 Suggested Answers
  • 34 Answers
SOURCE: screen blinking:
first check out if the screen saver is enabled to make your screen black. but if you are using your computer and the screen blinks or turns black there is a loose contact of wire in your computer. bring it to the service center of your notebook and have it fix.
Posted on Dec 22, 2008
frankzjm
  • 191 Answers
SOURCE: cant get past the acer screen
ok,your laptop OS file could be damaged so nothing booting later.
you may do follow steps
1) try F8 or F12 into boot sequence, choose safe mode to start your windowas, it could repair your damaged SYSTEM file. if still trouble
2) you may use a OEM windows disk (match your lable type)
booting from CD drive, then choose a windows repair, it maybe recovery your syastem. if can not do so
3) booting a OEM windows disk (match your lable type) reinstall new OS system(use the CDkey on the lable). and some driver you need downloard from Acer website.
hope you fix it, any question feedback any time please.
please take a rating let me know how much helped you thanks!
Posted on May 22, 2009
  • 74 Answers
SOURCE: acer aspire one D255 went away from notbook for
Hi, try disconnecting the power completely and take the battery out, wait a minute and put the battery back, connect the power and turn the machine on, if still no luck try holding the power switch for over 3 seconds, wait few seconds then try turning on... if still no luck then there might be aproblem with the machine that require taking it to service center... best of luck
Posted on Jan 30, 2011
Black screen on acer aspire Z5600
this can occur due to faulty RAM also or reset the bios to default settings
Jan 30, 2013 | Acer Aspire Z5600 PC Desktop
Monitor keeps losing the screen and goes black several times before it finally stays on
it happened may b due to inproper power supply.So check the monitor data cable & other connections also.
Aug 08, 2009 | Acer 22" X223w LCD Monitor
Screen going black
you probably need a new screen
how ould is the system
Jan 17, 2009 | Acer Aspire 5610-4648 Notebook
Screen blinking:
Dec 22, 2008 | Acer Aspire 4520-5582 Notebook
Window's will not load... desperate need of help
Try this, hook up an external monitor to this PC, usually the F8 key allows you to enable the port to extend video to an external monitor, it varies on each PC. Either way try an external monitor see if the image comes up on that. My suspcion is that the Backlight for the LCD monitor is bad and needs repair. Get back to me please. I would like to no... I am pretty certain that is the case here!
Nov 26, 2007 | Panasonic Toughbook 48 Notebook
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Acer Aspire 5732Z-4855 Notebook Logo
212 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
