Question about 4103LX Remote Start System with Two 4Button Remote
Windshield wipers will not turn off.
The first time using the wipers after having the remote start installed, they will not shut off. Didn't know if it was caused by the installation or if it is the wipers themselves.
  • Leah Groom Jan 29, 2013
    Went back and they checked the wiring. Said they couldn't find anything wrong, but after I left wipers worked just fine. Thanks!
  • Avital Master
  • 625 Answers
Wow...I would return to the place where the installation was done. It's possible that the installer either tapped into the wire or, left the wire exposed after testing it.
Posted on Jan 17, 2013
My turn signals, windshield wipers and rear window defroster stopped working all at the same time. The fuse and multi-function switch are both fine.
Check all fuses with test light or multimeter. I tend to agree with you that it is probably a fuse. Not knowing of any "hidden" fuses or in-line fuses on that system. But sometimes other fuses that are not labeled as wiper or turn signal might be used for power also. So, check all fuses including the ones under the hood.
Feb 22, 2015 | 2002 Chrysler Sebring
I have a 95 toyota celica with an electrical problem. When I purchased the car the wipers would not turn on. The solution was they needed plugged in. When I plugged them in they wouldn't shut off...
Do you know how to do automotive electrical systems testing ? How to use a voltmeter or a test light ? How to use an read a wiring diagram ?
Windshield Wiper Motor Wiring Tutorial
Electric Testing Techniques You Need to Know
Basic Electricity for Service Techs Ohm law Current Flow Opens Shorts
Testing the electrical circuits an eliminating what's good is the way to a fix or solution !
http://www.bbbind.com/free_tsb.html you can find wiring diagrams here . Someone eles on here may tell you to replace the wiper motor ,an that may fix it , but suppose you do an it doesn't fix the problem ? Testing an not guessing > there are no magical fix's for automotive electrical problems .
Apr 03, 2017 | Cars & Trucks
Windshield wipers won't shut off
Turn wipers to off then turn the car off. We have the same problem in our 1986 Pontiac parisienne brougham
Nov 23, 2012 | 1986 Pontiac Parisienne
How To Install Replace Windshield Wiper motor on a Honda Odyssey
Put the right side wiper on only. Turn on wipers. When the wiper moves all the way to the left and starts to go back to the right turn off the ignition with the wiper switch still on. Remove the right wiper arm and install the left wiper arm in the far left of the wiper movement. Turn on ignition and allow the left wiper to go all the way back to it's rest location at the bottom of the windshield. Turn off ignition and install the right side wiper arm. This will give you a start to properly set the wiper arms.
Apr 12, 2012 | 2003 Honda Odyssey
Have a 2001 Jeep Wrangler. Radio won't start
Fix your car right away by clicking the link I attached
2001 Jeep Wrangler
Dec 04, 2017 | 2001 Jeep Wrangler
Windshield wiper 1989 f150
YOU ARE NOT USING TO MUCH POWER. YOU HAVE A SHORT SOMEWHERE IN THE SYSTEM OR SOMEONE PRIOR TO YOU WIRED THE RADIO INTO A POWER LINE THAT WAS INCORRECT. FOR EXAMPLE- SOMEONE INSTALLED AN AFTERMARKET STEREO AND DIDN'T QUITE KNOW WHAT THEY WERE DOING AND GRABBED THE FIRST HOT WIRE THY COULD TAP INTO FOR POWER TO THE RADIO. RUNS THE WIRES OUT TO THE RADIO. THE RADIO SHOULD RUN BACK TO T THE FUSE BLOCK ON THE POWER SIDE.
Nov 12, 2011 | 1989 Ford F 150
After replacing the windshield wiper motor on my 1996 dodge caravan the wipers park in the complete opposite position. If I readjust the arm on the motor, the wipers go down not up over the windshield. Is...
This is an old but very current problem also. I just replace my second 97 caravan motor in 6 months because of severe grinding noise and it was the motor both times. I got another re-mfg replacement motor last week and it is totally quiet.
Before you install the crank arm on the motor you operate the wiper switch in all positions to check that the computer is running it intermittently, slow and fast etc. that it and shuts it off at the same position every time. That shut off position is park.
Unplug the external motor connector or fuses. Now push the mechanism arms fully to the right and install the crank arm at two o'clock on the motor shaft, which gives you just enough room to install the hold down nut. Hold one of the metal bars so you don't turn the motor during tightening the nut.
Now reconnect the power plug and test the operation. The motor should shut off with the right end arms fully extended, which, when connected with the blade arm, will make them stop at the bottom of the windshield. Install the driver side wiper arm slightly above level and the left arm 4 inches below that. Don't power tighten yet. Test the operation. If they hit each other adjust one or the other away. This works for most all wiper adjustments. When you get everything looking right and sweeping the full window and not the body. Start tightening and putting every thing back together.
Also clean out the wiper pan and the two drain hoses. The hoses can be pulled loose below the pan. LOL
Apr 19, 2011 | 1996 Dodge Caravan
Windshield wiper switch
the most common problem is called the multi-function switch or turn signal switch--replace it----8 out of 10 thats the problem
Jun 27, 2008 | 1991 Ford Explorer
4103LX Remote Start System with Two 4Button Remote Logo
49 people viewed this question
Top Avital Vehicle Parts & Accessories Experts
D. E. Hev
baire
Billy Mac
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
