Question about Hobart 29 in. AM15-1 Free-Standing Dishwasher
Why is my hobart am 15 not getting to wash temp or rinse temp
Wash cycle is only getting to 147-153, rinse drops below these temps after a second or two.has a wrench symbol and p3 code
    Problem Solver:
  • 12 Answers
Need to look at heating elements
Posted on Apr 02, 2014
  • 211 Answers
SOURCE: Odd operation
This unit is a sanitizer, not a full fledged dishwasher. It is designed for restaurants and bars where the primary use is washing glassware. The behavior you describe is normal for this model. The manual can be found at the following link:
https://feg.hobartcorp.com/resourcecenter/ProductDocumentation/F34779%20Rev%20B.PDF
Posted on Dec 04, 2008
  • 41 Answers
SOURCE: wrench and code p3 display
this is a probe booster error your probe failed replace it
Posted on Dec 09, 2008
bigg t
  • 640 Answers
SOURCE: what is p3 code on hobart am15 dishwasher
It means that the final rinse thermistor is bad.Your not getting 180 degrees---right?Its located on the booster and costs about $65.I work for hobart.Any ?
Posted on Jan 25, 2009
bigg t
  • 640 Answers
SOURCE: reset swish
What reset switch?The red button on the booster (it sits underneath to the left)?
Posted on Feb 14, 2009
  • 110 Answers
SOURCE: no rinse cycle
MACH. PROB.LOST PROGRAMMING. GO INTO PGM AND SELECT H FOR RINSE
Posted on Jan 11, 2010
I have a am-14 hobart washer. having problem with rinse temp indicator. it is fine for the wash then the temp gauge is jumping around, could it be the thermostat?
Your rinse temperature sensor that is a tiny probe in the water piping (top rear of machine) needs replaced. Hobart part # 00-294692. It costs about $84.
Oct 19, 2012 | Hobart Dishwasher Am-14 Commercial Dish...
Rinse temp too low, first it comes up to 180 degrees and then drops to wash tank temperature, WHY?
The rinse temp only reaches 180 degrees for a couple of seconds towards the end of the cycle. This will sanitize all warewash and meets most health code regulations. The rinse water temp will drop rapidly as it is incorporated in to the machine and sprayed on the dishes.
Regards
Feb 23, 2010 | Moyer Diebel 24 in. 301HT-40 Built-in...
Hobart WM-ID dishwasher doesn't heat water enough to clean dishes
The WM-1D does not have any internal heating devices. You have to supply the machine with the proper water temp. It has two fill valves, one for wash and one for rinse. It should have 150F supplied to the wash fill valve and 180F to the rinse fill valve.
Feb 04, 2010 | Hobart AM14C-155 Dishwasher
After pressing On - the dishwasher just sits are about 80 degrees and doesn't get any hotter when normally it goes up to about 118. Can we still use it to wash or is something wrong?
A hobart LXIH-3 uses a chemical to sanitize however a 120 degree wash temp is required as well.
Turn up your hot water tank that supplies the dishmachine, make sure your sanitizer is pumping into the rinse cycle using micro-clorine test papers and all is well.
Dec 22, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Temp. too hot
First off, the temp adjustment can only be made by a trained service tech, since the dishwasher will need to be reprogrammed to allow for a lower temperature in the rinse cycle but still have the higher temp needed in the wash cycle. Also, since any change in the water temp settings will require a longer wash and rinse cycle to be programmed into the unit.
Of course, you could simply lower the water temp on the water heater that supplies water to this unit, but you'd have lower temp water elsewhere and likely get cited at the next heatlh department inspection on that issue.
Since this is a commercial dishwasher, you might want to reconsider lowering the temp, since health codes and standards for commercial establishments require a MINIMUM water temperarture of 185 degrees F (85 degrees C) for proper operation and to get all the crud off the dishes, etc.
Note, the manufacturer sets these units to the higher temp, 203 degree F (95 degree C) knowing that the water will cool down quickly once the wash cycle starts and the water contacts the dishes, etc. That is also why these units have a added heater element, to help keep the water at the correct temperature needed to both clean AND sanitize the dishes, according to established health standards.
If you really want to change the water temp settings, contact your Hobart service rep and explain the reason you want it lower and see what they say.
Hope you found this very helpful and best regards!
Aug 19, 2009 | Hobart SR24-H Built-in Dishwasher
No rinse cycle
If it is new, would you not call Hobart for a warranty call? 1-800-444-4764 to reach the nearest branch in Canada.
Seeing it's new it is most probably not programmed correctly. On the control board is factory jumper J5, short thse two pins and press ON on keyboard. when the display shows ty remove short. pressing select on the CB will change the options, pressing up arrow will incriment the change options. first setting is machine type= AS,second is id, hot/cold or plain AM15 only, select H,C,or P.
3rd is tc,auto temp control. The rest will not affect your condition. Press OFF on keyboard to save and exit.
Jul 03, 2009 | Hobart 29 in. AM15-1 Free-Standing...
Operation of digital temperature indicator
When the unit is idle and in a wash cycle the wash temp is displayed.If you look inside the tank you will see a white float and a metal probe which is the themometer for the wash tank temp.The rinse temp will only be shown when the display reads (Rinse) and theres a thermistor that screws into the water line near the solenoid valve that measures the temp.
Feb 17, 2009 | Hobart AM14C-155 Dishwasher
Tank temp
check to see if your element is scaled up or your element may be damaged
Nov 21, 2008 | Hobart AM15T Dishwasher
Odd operation
Jun 15, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart 29 in. AM15-1 Free-Standing Dishwasher Logo
268 people viewed this question
Top Hobart Dishwashers Experts
Jason
handygirl911
handygirl911
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
