Question about E-Machines eMachines Desktop PC
How come my computer keeps turning on and off by it's self ?
    Problem Solver:
  • 9 Answers
It's got into a reset loop - often it's a fault on the memory card(s) or possibly even a software fault after an update or new programme. Try going in in safe mode (keep tapping F8 whilst starting up) and see if re-sets itself.
If not then it's likely to be software. Remove the last programme loaded and then restart the machine - see if that works.
You can try to reseat the memory cards for another possible solution.
Posted on Jan 24, 2009
Why do my proscan tablet keeps resetting its self
Not normal behaviour. You should take it to service
Dec 28, 2014 | Proscan 8" Tablet with 4GB Memory
1998 plymouth grand voyager resetting it self
If the ECM keeps resetting itself, try disconnecting one or more sensors with engine running, If you get no codes after this the ECM is malfunctoning
Nov 15, 2014 | 1998 Plymouth Grand Voyager
My E-machine E3031 keeps turning its self off what can i do
you have a problem with your PSU (Power Supply Unit) I had this same problem with this exact same PC & Once i replaced my PSU it solved this problem, check eBay for people breaking this PC & Bag a bargain, Mine cost me 23 GBP & was fitted in no time check online for details on how to replace the PSU.
Sep 21, 2012 | E-Machines eMachines Desktop PC
Pc turns it self on by it's self
Make sure the power button isn't sticking at all. If it is sticking then use some glass cleaner on a cotton swab and clean around the button.
Try plugging the computer directly into a wall outlet instead of a surge protector or power strip to rule out a faulty product.
If the same thing keeps happening then you'll need to replace the power supply.
Jan 12, 2012 | E-Machines eMachines Desktop PC
Dell inspiron m5030 keeps turning it self off
This problem is due to the following:
  • Your computer is overheating
  • Critical problems with your registry
  • Critical state of the system files
  • Hard disk data cable and power cord are loose
  • RAM is not properly connected
  • Problem with the SMPS connections
For fixing computer automatically shuts down issue, you shall remove the motherboard and reconnect all the connections. Take help of a hardware expert while doing the task.
The solution to fix computer automatically shuts down is to download and run a good and reputed Registry Cleaner software, use RegInOut to fix this problem.
Jan 03, 2012 | Dell Inspiron M5030 Laptop
My hard drive fails and it wont boot. What is the best solution to it?
If its a HP notebook then perform the har drive self test.
Here are the steps below.
Steps for HDD self test.
  1. If the notebook computer is running solely on battery power, plug the AC adapter into the notebook.
  2. Shut down the computer if it is running.
  3. Press the power button to turn on the computer.
  4. Press f10 when the HP/Compaq logo displays.
  5. After the BIOS Setup Utility displays, use the Right Arrow key to select the Diagnostics menu.
  6. Select HDD Self-Test options .
  7. Press enter to display a list of HDD/Self-Test options.
  8. Select Notebook Hard Drive and then press f10 to display an Estimated test time .
  9. Press f10 to continue. The Hard Drive Self Test executes a Quick test , a Comprehensive test, and a SMART test.
If the hard drive fails then surely there is no option other than replacing it....
Please surely buy HP Hard drive.
Jun 14, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
Dell OptiPlex GX260 PC Desktop keeps switching its self on !!!!!!
Check the pwer settings on Desktop-properties-screen saver- power options and set it from there. Disable Hibernation......sodeep
Mar 22, 2009 | Dell OptiPlex GX260 PC Desktop
Bios set 08-08-2008 resets to 31-07-2007 every time i turn computer off.turn computer off then turn on it resets its self to 2007.turn power off and on at power switch. computer starts on own i do not push...
- do a bios update (or downgrade if needed) to see if it fixes the issue
- but probably the BIOS battery is not keeping the proper voltage anymore, and it automatically resets the BIOS (do the bios setting that u change, remain changed after unpluging/pluging the comp ?!). Try keeping the computer pluged in for a day and see if the battery charged properrly (if the set date remains )... if not ..change the battery.
- as for the self starting, there is a setting in the BIOS, that activates/dissables that ! - see u;re user manual ...
Aug 08, 2008 | Computers & Internet
Monitor not working
These messages appear during if the video cable becomes disconnected or
damaged.(most likely you will need to replace it)
Turn off your monitor and reconnect the video cable; then turn on both your computer and the
monitor.
If your monitor screen remains blank after using the previous procedure, check your video
controller and computer system; your monitor is functioning properly
Nov 14, 2007 | NEC MultiSync LCD1830 18.1" LCD Monitor
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
