Question about Watches
Changed the battery, and now the buttons no longer work
Hi all, I recently changed the battery in my watch, but now the buttons no longer work. So I can't amend the time or date. Any advice?
    Genius:
  • Watches Master
  • 1,669 Answers
When you opened it up, you inadvertently broke the seals around the buttons that keep out moisture and dirt. Now, that you have closed the watch, the dirt is pressing against the seals instead of being the blocks against the dirt. Instead of tahing the whole watch apart again I suddest you get some WD 40 or CRC sprat and spray it on one button at a time and exercise it in and out until it is free. If that doesn't work...open the watch and clean each pin with the spray and a cue tip!
Posted on Jan 15, 2013
SOURCE: Tag Heuer 200meter Professional series
This is to let you know that the battery needs to be replaced.make sure that you use a watchmaker that can test and replace any worn case parts so that your watch will retain it's original design water resistance.
Donald McPherson
Certified Watchmaker AWCI
www.finewatchmaking.com
Posted on Oct 22, 2007
pgh_pa_guy
  • 2992 Answers
SOURCE: changing the date on a timex perpetual calendar watch
You can download the Perpetual Calendar instructions from Timex's website here.
If you don't like clicking on a link, here's the URL:
http://assets.timex.com/instructions/perpetualCal.pdf
Hope this helps. If this solution has been what you needed, please take a moment to rate it a fixya, and thanks for asking here!
Posted on Mar 11, 2009
  • 79 Answers
SOURCE: Diesel DZ7069 watch - how do I set the correct date/time?
ok ,here it is .
Instructions To Set The Time On The Diesel DZ7071 Watch
Ok the first and most important thing to know about this watch is that it has an unusual timezone function (unusual to me at least). This allows the watch to display two different times. Time 1 (or T1) is the primary time (the time of the place where you spend most of your time!). The time can only be adjusted whilst the watch is in the T1 mode (T1 should be displayed in the bottom left corner of the screen). Holding down the top right button for one or two seconds will temporarily replace the current T1 time with the T2 time. Holding down this same button for several seconds will toggle the current time mode to T2 and the watch will continue to function in the second time zone until you toggle it back to T1.
The second most important thing to know is that you can only set the time whilst in the T1 mode. When in T1 mode hold down the top left button until the watch enters the settings menu (it should say "Light" at the top of the screen) now use the bottom left button to toggle through the settings menu until you get to the time settings. I think this part of the process if sufficiently straight forward so I'm not going to go into more details here, all I'll add is that once you have the watch set to the desired time mode 12h/24h time and date you just need to press the top left button to save the settings and return to the main time screen.
To set a secondary timezone time you have to first toggle the watch to the secondary time zone mode (hold the top right button for several seconds and the T1 indicator should change to T2 (and the watch will now be displaying the time that is currently set for the secondary timezone). This time is based on the primary time by simply telling the watch a number of whole hours ahead or behind the primary time. To adjust this hold down the top left button for several seconds, the watch will then say "offset" now use the buttons on the right to add or subtract hours from the primary time. Once set press the top left button again to return to the main time screen. Finally hold down the top right button for several seconds once more to return the watch to the T1 mode.
Posted on May 15, 2009
SOURCE: Can't adjust the date on a digital watch
These are the instructions for the AD0721. They might apply to your model, too. I hope this helps:
http://img261.imageshack.us/img261/6784/manualr.jpg
The analog setting of the watch takes place by pulling out the knob (kind of tough) and adjusting, like a regular analog watch. The analog and digital displays are will NOT stay in sync, unfortunately.
Good luck.
PC
Posted on Jun 05, 2009
  • 7993 Answers
SOURCE: Casio Waveceptor 2734 WVA-105H watch not working
You can use the manual to manually reset the time. After you succeed in setting UK time zone, wait until midgnigth: it should synchronize itself with the time signal from Germany. If unsuccessful to do so, it will keep attempting to synchronize itself at 1, 2, 3, 4, and 5.
Read the manual to figure out how to place the watch on a window sill. It might be better to be outside.
Keep in mind that the success of the operation depends on meteorological conditions.
Good Luck.
Posted on Feb 05, 2010
Timex electric watch not running
Hi Mark,
It appears to be a battery problem. Have you changed the battery recently? How have you checked the battery? I suggest you check the battery's voltage, even if it is a new, replaced battery.
You need to be sure the battery is not the problem before looking elsewhere.
Need more detail if this does not help, including the model of watch. Also how long has this problem existed, and when did you notice a change - was there a specific time/event?
Feb 01, 2014 | Timex Watches
I have a casio cmd 40 i recently changed the battery and the keypad did work. it still switched on but the key pad was not working
hi lagathon121 I had the same problem after i replaced the battery and what i did was to short the + end of the battery plate with the - end for two seconds, apparently this will reset the watch. there is also a sticker pasted on the battery plate holder.
Oct 15, 2010 | Watches
I love my E. Howard radio controlled watch. I recently had the battery replaced by a local jewelry shop but it no longer keeps accurate time!It is about 55 minutes fast and remains that way. What do I do...
mcdevito75 here, Return to the shop that changed the battery for adjustments, possibly a new battery or the factory recommended type battery.
Jul 22, 2010 | Watches
Big tic no longer changes color
The big tic has two batteries. The battery for the display may need to be changed and the circuit reset. You can then hold the display button down for 2.5 seconds to cycle through the display function.
Sep 17, 2009 | Fossil JR8096 Wrist Watch
Invicta Ocean Ghost Chrono Model# 2636
Did you recently have a battery changed. A lot of times on chronos when the battery is changed the battery has to be short circuited to the AC. Which is done by taking tweezers. & touching the positive part of the battery to the part of the watch marked AC. Then try to pull the crown all the way out to time setting position press the top rt button & the second should move keep moving until it lines up with zero. If you haven't had the battery changed try what I told you to do with the crown & the top right button.
Mar 13, 2008 | Invicta 2636 Ocean Ghost Chronograph Watch
CASIO PAG-40 Keeps good time but buttons stopped working
open the backside.
probably the light switch contact at the six side of the watch (attached to the steel mainframe) may have contact with the electronic cirquit
Jan 13, 2008 | Casio PRG-40T-7 Pathfinder
Watches Logo
110 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
