Question about Chinaewindow PSP MP5 Player
How i update my firmware of psp mp5
Latest version
How can i upgrade my psp2001 5.50prome-4 to 6.20?
How to Update PSP to Firmware Ver 6.20
It's easy to update/upgrade the Playstation Portable (PSP) 3000 system software to firmware version 6.20. There are two ways to do a PSP 6.20update - regular file download and network update. We did an update on our pink PSP 3000 using the network update procedure since our place has wifi.
Why did we choose network update in updating our PSP firmware to ver 6.20? It's much simpler. Here is a quick tutorial on how to carry out PSP 6.20 update using Network Update (Method 1):
  1. Go to Network Settings to configure your PSP WLAN by setting up an access point.
  2. Under Network Settings, it would be best to choose Automatic to simplify the process. Your PSP console will search for any wireless network available nearby.
  3. To Update System Software to the latest 6.20 firmware version, Go to Network Update. Be sure your battery is full because the update will fail if you turn off you PSP console or if the unit shuts down due to lack of battery power.
Method 2: Download File To Update PSP 6.20 Firmware Using a PC. If you prefer to update your console using the download method, here are the simple steps in doing this:
May 28, 2011 | Sony PlayStation Portable Slim Black...
Tip
PSP Custom Firmware 6.35 PRO-B4 has been release by Virtousflame (a.k.a...
PSP Custom Firmware 6.35 PRO-B4 has been release by Virtousflame (a.k.a liquidzigong) and coldbird. The latest release includes a few bugs fixes for better stability and compatibility for all model PSP System (PSP 1000, 2000, 3000 and PSP GO - N-Series)
This CFw has works on Sony firmware (OFw) 6.35 to lets users play backup UMD's - ISO games, so if you're already on OFw 6.35, you can either use this, If it doesn't, you will need to update your PSP firmware to 6.35.
Required :
  • PSP-300x or PSP-200x TA-088v3 or PSP GO has Sony Firmware '6.35' installed. other firmware is not supported. If you don't have PSP 6.35 installed, you need to update it.
  • Version check: On the PSP Menu (also known as XMB= Xross Media Bar), and goto 'Settings Menu' >> 'System Settings' >> 'System Information' and you should see firmware version of your PSP.
  • An Memory Stick at least 32mb for OFw update & CFw 6.35PRO-B4, ( Internal storage for PSP GO ).
**Download:
*CFw 6.35PRO-B.
*CFw 6.35PRO-B4.
--Depends of your PSP.--
*OFw PSP 6.35 (for PSP 100x, 200x, 300x).
*OFw PSP-GO 6.35 (for PSP Go - N-Series).
Installation Instructions :
Note:
This software is free, and comes with no warranty, it has been tested and it has work, however I am not responsible for any bricked, so please try this at your own risk!. If you're afraid of risk of brick, don't try to downgrade. Read more...
on Apr 21, 2011 | Sony PlayStation Portable (PSP) Console
Where can i find the latest version for my play station portable
listen do you know custome firmware??? if you dont then what that means is that you will stay at a certain firmware BUT special firmware that lets you play games from your memory card!!! instead of using your umd and ORiginal firmware cant play the games from the memory card HOW to know if your psp is custome firmware well go to system settings and check on system information if it says 5.00M33-4 its custome any that has M or GEN is custome if it does not say anything your psp is original..NOTE you cannot have custome firmware on a psp 3000 or 3001 it will only work on 1000's 1001's 2000's 2001's how to check that?? look ont he bottom of your psp it says a serial number than it should say psp1001 or 2001 but if it says 3000 or 3001 it WILL NOT WORK anyways you can connect to the internet by your psp and update from the network ORRR download the latest firmware from your computer lets say 6.20 download put it in a folder called UPDATE with all capitals and put it in game you will now have the updated version on your memory stick. and you can boot it from there go to dthe playstation .com and they probably have it there.RATTEEE!!
Jul 23, 2010 | Sony Video Game Consoles & Games
My psp has a virus
update the firmware on your sony psp and this will get rid of the virus. Go to this website and it will have the latest version and then it will explain how to update the psp firmware by connecting it to your PC thru your usb cable.
http://www.us.playstation.com/support/systemupdates/psp
Click on the PSP that says 6.20 and that will bring you to the page that tells you about hooking up the PSP to your pc to update the firmware.
Jan 15, 2010 | Sony PSP-3000 Silver Console
Psp update 5.50 error
I suggest you stick with 3.90 M33 Custom Firmware because the old and good games can't be read with the latest versions
May 20, 2009 | Sony PSP (Piano Black)
Games,Update, Version 5.02
The firmware/software 5.02 is official sony firmware, its can't load/play your iso game from your MS.. to load iso, You'll need install custom firmware on your psp, the latest cfw update is 5.00m33-3, You can find it by googling or see at my blog here!. how to create pandora - magic stick.
To change your psp from official firmware you'll need pandora - magic stick (latest update DC7 - 4.01m33)for downgrading and install cfw,because since high kernel released, cfwcan be installing from 1.50 OF fat(old model) psp.. and 3.60 for slimpsp as startingpoint.
When you have 4.01M33 you can update to the latest CFw 5.00M33-3.
Hopefully this help, Pls post back should you need additional information, and also Show your Appreciation, to help other USER.
http://e-arena.blogspot.com.
Nov 25, 2008 | Sony PlayStation Portable (PSP) Slim...
I cant play games from memory
Hi kalfan
What happened was that when you downgraded your PSP to -play game from your memory stick, that version was loaded onto your PSP for a reason. What you did now is install the latest firmware and that disabled you from playing games from your memory stick. You might have to get your PSP downgraded again with the older firmware version.
Nov 11, 2008 | Sony PlayStation Portable (PSP) Console
How to downgrade psp v5.01 to 3.80
hi your previous psp version is 3.80 m33 if yes your using custom firmware that why you can play game to your memory stick the problem is you upgrade your psp firmware to sony official firmware 5.01 you reinstall your firwmware again using custom firmware like 5.00 m33-3 cfw below with m33 or OE
Nov 02, 2008 | Sony PlayStation Portable (PSP) Console
Psp firmware latest version has updated, after that my game can't to play as before, how to restore back my original psp firmware version as original or any guide to resolved my problem
Try a restore default settings. If you are updated to the latest official firmware and trying to run a game from a memory stick it wont work. As official firmware wont support playing backup games from the memory stick
Jul 23, 2008 | Video Game Consoles & Games
I cant update firmware!?
Try these:
http://www.youtube.com/watch?v=Rwxq1mJZ2G4
http://www.noobz.eu/joomla/news/pandoras-battery.html
Jan 03, 2008 | Sony PlayStation Portable (PSP) Console
Chinaewindow PSP MP5 Player Logo
104 people viewed this question
Top Chinaewindow Video Game Consoles & Games Experts
James Wishart
Are you a Chinaewindow Video Game Console and Game Expert? Answer questions, earn points and help others
