Fujitsu ASTA12LCC A/con unit will not turn on, there is power to the unit, the remote works on my other a/con unit
There is power to the a/con, the remote does work as it operates my other Fujitsu A/Con, seems to be the switching of the unit or pcb....?
bobotfel
  • 236 Answers
SOURCE: I have a Fujitsu Split
Try to disconnect the supply from circuit breaker for 10sec. and "on" again, if it doesn't work you need at qualified technician for that problem.
Posted on Apr 16, 2008
bobotfel
  • 236 Answers
SOURCE: AIR CON REMOTE CONTROL NOT WORKING
replace your receiver board it may be defective.
Posted on May 16, 2008
notsomot
  • 67 Answers
SOURCE: Remote Control Unit-Fujitsu Air Con. Model:AR-DL1 is broken.
If you contact Fujitsu in your country and you will be able to buy it straight from them, if they are still available. Now I have to warn you as a Fujitsu warrenty agent they are very very expensive.
I would prolly recommend getting a universal remote. ALOT cheaper
Posted on Jan 23, 2009
praky16
  • 744 Answers
SOURCE: fujitsu ducted air con cant switch on
hi...
Prevent any direct sunlight from heating up the room the unit is in. Clean the dust filter every month or as often as it needs it. Limit using any heat generating appliances such as stoves, ovens, microwave ovens, hair dryers, etc.,..
thank u
rate me!!
Posted on May 24, 2009
  • 10865 Answers
SOURCE: unable to turn on aircon with remote control and no manaul on button on the air con unit
I recommend putting new batteries in the remote. If that alone solves your problem great. If not, get back and let me know
Posted on May 25, 2009
Fujitsu ASTA12LCC WILL NOT HEAT OR COOL. GREEN TIMER LIGHT FLASHES TWICE AT INTERVALS. FAN WORKING. IS IT REPAIRABLE?
Serial signal reverse error. Basically the outdoor unit is not talking to the indoor unit. This is normally due to damage to the outdoor controller PCB and it needs to be replaced.
Jul 03, 2017 | Fujitsu Heating & Cooling
Fujitsu asta12lcc timer flashes 5 times
From the service manual:
Serial forward transfer error during the operation
When the outdoor unit does not receive the signal for 10 consecutive seconds during the operation > Outdoor unit stops.
[Diagnosis Point]
Check the indoor /outdoor cable connection (in order). If the cable wiring is not abnormal, measure the voltage of the outdoor unit terminals and diagnose the defective location.
(Refer to the after mentioned [Serial Signal Diagnosis] for the voltage measuring method and diagnosis method.)
Jan 17, 2017 | Fujitsu Heating & Cooling
ASTA12JEC Fujitsu Air Conditioning unit. Dear sir or madam. My air conditioning unit is no longer responding to remote control but stays on. It used to work fine then one day it stopped responding.
Start by replacing the batteries to your remote control and make sure there is nothing blocking the IR receiver on the unit itself. If that is blocked by something hanging on it or tape over it from something hanging on it previously.
Jan 31, 2015 | Fujitsu Heating & Cooling
New Fujitsu remote AR-DJ8 will turn unit on but will not turn unit off
Try new batteries before you buy or repair anything.
Feb 10, 2014 | Heating & Cooling
FUJITSU Indoor Inverter ASTA09LCC/ASTA12LCC airconditioning - not cooling
If the operation button is flashing 8 times, the timer light should also flash 4 times in each sequence. This indicates a failure of the PFC circuit in the outdoor unit which basically means a faulty outdoor board and will have to be replaced.
If the operation light is flashing 8 times by itself, the indoor controller board may have a fault. You can normally test this by putting the mode on the remote to 'Fan' and checking that the controls otherwise work normally - louvers work as directed and fan speed changes correctly when selected on the remote.
Most likely the fault lies in the outdoor board but you should contact a tech to diagnose correctly.
Sep 24, 2017 | Fujitsu 18C1 Air Conditioner
I have a Fujitsu Inverter heat and cool model SET-ASTA12LCC - about 14 months old. when you turn it on it gives off a horrible chemical smell. any suggestions as to what it could be?
I ahve an ASTA12LCC model and was on constant for 3 months(21 degrees auto). When I tried to shut it off by remote it would not. I had to power down by control switch outside
I have used the remote on another unit and it transmits fine.
I have tried the other remote and it does not recieve either
May 03, 2011 | Fujitsu 18C1 Air Conditioner
Air con not working. Operation and timer lights flashing, then operation light flashes and then lights go off. Air con is blowing air but the outside unit is not blowing any air.
First check your timer on and off. If you want to reset, remove batteries from remote and power off to unit. Reset it. Now run the unit. Set temp mode once again in your remote and wait for 3 minutes. If still out door unit not working, check power line to out door unit.
Dec 31, 2010 | Fujitsu Heating & Cooling
Have just installed a Fujitsu Asta 24lC air con heat pump problem
Hi Shannon,
I would pursue your fight with Fujitsu, normally their units are reliable:(
It could be a really simple problem or a really complex one ranging from many componenets. A air conditioner has many more components that people may think. Keep fighting to get the unit repaired will it is still under warranty, after that Fujitsu wont want to know you. It could also be a wiring and refrigerant fault. Call Fujitsu out again.
I take the time to answer your question, so please rate me.
Thankyou Mat
Aug 24, 2009 | Heating & Cooling
Fujitsu air con unit. Remote wont work. has new batteries
Check the micro processor control whether it is in manual mode or not. If not check the sensor whether it is functioning or not. If everything is fine then remote control has to be changed.
Aug 15, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
