Question about Panasonic NN-S763BF Microwave Oven
Panasonic NNP994SFR shuts off after 3 second countdown
Microwave shuts down after a few seconds,
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave shuts off after 3 seconds
Although your model number doesn't seem to show up, the NNS950-series units are powered by an high-voltage inverter. And yours has failed. While an inverter (switched-mode power supply) is more efficient from a power consumption standpoint, it is more complex, thus more statistically prone to fail. These should only be examined and worked on by someone who has the necessary technical qualifications. Seriously. Often the machine-soldered connections in a microwave inverter are too weak, so they eventually fail, especially if heat is high in the area. They sometimes fail catastrophically. When not catastrophically damaged, you may hear clicking or squealing and may smell an electrical odor, which is sometimes obscured by the cooling fan. Sometimes a whole new inverter is cheaper than the time and labor required to fix the old one. If a technician is willing and able to troubleshoot and repair the inverter to component level, it will may be expensive, but may be worth it, especially if he or she will resolder and reinforce connections as needed as part of a thorough repair. That could easily make your inverter beter than a new one! You might be able to get some verbal estimates if you call Panasonic-authorized appliance / microwave repair shops and ask then specifically about inverter component-level repair and simple inverter replacement costs for your exact model number.
Posted on Dec 28, 2006
MicrowaveSvc
  • 9047 Answers
SOURCE: Panasonic microwave 1200
This model uses an inverter to produce high voltage. That symptom is an usually indication of a problem with the inverter or a bad magnetron. I do not recommend that a person without training and experience ever work on these models. You should be able to locate a Panasonic-authorized servicer here: http://www.pasc.panasonic.com/WhereTo/FindServicer.asp?Pass=1 I would mention the exact symptom when you call so the technician can bring a new inverter with him when he comes out to repair it. Might save you having it pulled into the shop. Good luck!
Posted on Sep 22, 2007
SOURCE: Panasonic Model No. NN-S933BF Microwave Oven
could it be that i didn't follow the manuel because i got it second hand or is it because something is wrong with it,and i have to get it fixed.
Posted on Oct 21, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave turns off by itself after being on for 3 seconds
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://www.microwavedisplay.com/safety.txt and
http://www.microwavedisplay.com/disassembly.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Posted on Mar 06, 2009
SOURCE: Panasonic NN-T994SF Microwave Oven quits after 15 seconds
my microwave shuts off after a few seconds. is there a fuse that needs replacing?
Posted on Nov 24, 2010
Panasonic microwave began arcing and now shuts off after a few seconds
Your wave guide cover and magnitron need to be replaced.
Apr 10, 2012 | Panasonic Microwave Ovens
Panasonic Microwave suddenly won't cook.
Your microwave is detecting an internal shot and shutting down, Most likely due to a faulty Magnetron which is not a part that is worth replacing due to the cost of the part and the decrease in cost of new microwaves.
Mar 06, 2012 | Panasonic Microwave Ovens
My NN-T994SFR Panasonic Microwave shuts off after 1 second.
My unit shuts off after about 2 seconds. It seems like it tries to go, but it sounds like it stops working and then 1 or 2 more seconds run off and it shuts down. Then you hit start again and it lights up inside and then shuts down. It's only about 2 or 3 years old.Any solutions?
Mar 05, 2010 | Panasonic Microwave Ovens
Feb 01, 2010 | Panasonic NN-T994SF Microwave Oven
Will not cook or will not warm
Your temperature sensor inside on the microwave need to rreplace. It maybe dirty or faulty. Bring your microwave to electronics technician to check it.
Jul 24, 2009 | Panasonic NN-H504WF Microwave Oven
Microwave shuts down after 3 seconds
you need a new magnetron and inverter board, this is an expensive repair, unit can be replaced with panasonic parts or replaced with same size panasonic unit
Jul 17, 2009 | Thermador MBBS Microwave Oven
Micro wave operates for a few seconds then shuts down, light goes out, but fan continues to work
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
The oven will also strop after 22 seconds if there are certain problems with the inverter or magnetron.
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 13, 2008 | Panasonic Microwave Ovens
On for 2-3 seconds and shuts down with slight wire burning odor.
http://froogle.google.com is showing this model selling for as little as $100. But as a technician, I have never cared for the inverter models. As complexity increases...
Mar 21, 2007 | Panasonic NN-T774SF Microwave Oven
Panasonic NN-S763BF Microwave Oven Logo
81 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
