Question about OfficeMax Zeal II Leather Task Chair OM02955
Tilt The chair is supposed to tilt back when sitting in it but I cannot figure out how to make it do that.
The repairman for our vendor figured out, as he was about to replace some mechanisms so our Boss B9431 chairs would tilt, that they were not broken! While flipping down the paddle on the left can lock the chair in a particular angle, once you've tilted it, it will not tilt IF the height adjustment lever on the right is PUSHED IN towards the chair, locking out the capability of tilting. You have to gently pull the height lever away from the chair, sliding 0.5 or 0.7 inches, to activate the tilt ability. This may be the case with other models, or may not.
Posted on Feb 21, 2013
I inherited a Turnstone office chair model #TS38001 and can't figure out how to lock the back so I don't always feel like I'm in a recliner. I need to be able to sit straight. Thanks! Terry
You may have inherited the chair because the back could not be adjusted. I have found that many office chairs lack lumbar support.
Nov 21, 2016 | Furniture
My wheelchair's green light doesn't come on after I return from my reclining position
Contact Pride for a manual, you'll need one. Or a Wheelchair/ medical equipment outfit.
Aug 02, 2014 | Pride Health & Beauty
How do you correct or replace the Apex 2000 Storz exam chair that will not hold in position when tilted back?
This should be visually diagnosed to get an accurate identification of the issue. That said, I would look to the tilt motor having broken teeth on the sprocket or a broken drive gear. Also the drive chain may be loose enough to allow it to slip on the sprocket. In most cases, the issue is with the tilt motor mechanism. Removing it will determine if an adjustment is all that you need or if it needs replacement.
May 12, 2014 | storz SMR Apex 2000 Exam Chair
What is a padded beach chair?
A padded beach chair is a high quality beach chair that's cushioned with foam to increase comfort. This type of chair is very beneficial if you're planning to sit around for a few hours because it will prevent unnecessary back pain that could be caused from long sitting hours on regular beach chairs.
Aug 19, 2012 | Garden
Graco highchair tray
Although the Graco high chair comes with a tray that you can tilt position wise, it shouldn't be tilting forwards.
Use the instruction manual and make sure that you have clipped it in properly.
If it's still tilting forwards then take it back to the place where you bought it to have it checked before you put a child in it, just in case it's faulty.
Good Luck
Aug 11, 2012 | Baby Gear
What exactly is a recliner? How is it different from other chairs?
A recliner is a versatile flexible chair that more comfortable than any other chairs.
They are made up of fabric or leather and can be used for both sleeping and sitting.
You can get these recliners from Oversized Recliner, the best pieces available here are:
a. RECLINER GENIUS 360 DEGREE SWIVEL MASSAGE RECLINER
b. PULASKI BIRCH HILL
c. MONARCH SPECIALTIES IVORY BONDED LEATHER RECLINER
d. PULASKI HARMONY SWIVEL GLIDER
e. DIVANO ROMA BONDED LEATHER ROCKER
Aug 09, 2012 | Furniture
What is an executive office chair?
An executiveoffice chair is a fancy office chair that is made from high quality fabric orleather. Its' unique feature is the high back rest that is generally not found in regular office chairs.
Jul 30, 2012 | Furniture
Today I turned my wheel chair on and it would not go forward or back. The indicator on the control panel shows I have a full charge. This has never happened before. I did some checking, when I put the...
I am making some assumptions based on your description of the problem:
1: You have a Jazzy 1113 with tilt.
2. You have batteries that are fully charged as indicated by the battery display
3. Your chair is not in freewheel, that is the brakes are engaged with the levers in the correct position.
4. The motors are not turning.
5.You do not state the type of tilt system but I am assuming it is either true balance tilt by Pride or Motion Concepts tilt.
6.You have no flash error code on the battery display.
7. You do have a flash error on the joystick.
My initial response based on these assumptions is that your chair is in drive lock out and the electronics are inhibited because of the following reasons:
You have a bad switch that indicates to the electronics that the chair is in tilt or more than 20 degrees of tilt. You have a bad inhibit harness. You have a bad end of travel switch on the actuator. The list is long depending on the system.
Check all the wiring and switches associated with the tilt system for broken/disconnected wiring.
Get back to me with exact specs of the system including type of tilt system and the serial number of the chair so I can research the configuration and give you exact and not general answers. I hope we are off to a good start.
Dec 10, 2010 | Pride Jazzy 1113 Power Chair
OfficeMax Zeal II Leather Task Chair OM02955 Logo
563 people viewed this question
Top OfficeMax Furniture Experts
CrisO
ray gallant
Tom Chichester
Are you an OfficeMax Furniture Expert? Answer questions, earn points and help others
