Question about Xerox Phaser 6360 Laser Printer
Xerox Phaser 6360 Code 95 - Xerox Phaser 6360 Laser Printer
  • 49 Answers
SOURCE: Phaser 6360 laser failure code 07
Yeah I had a look at the website there too, try powering down again and plugging it out for a longer period of time. You need to get the whole machine to reset and loose all saved info in the bios. Also cleaning it out of all loose toner on any contacts might help!
Niallbt
Posted on Mar 30, 2009
  • 159 Answers
SOURCE: Xerox Phaser 6360 Black Toner prints Light Grey
I have had to repair a few of these. Take off the sides and back of the 6360. You'll see the hoses that feed into the laser. The black one becomes unplugged from the laser. All you have to do is plug it back in. The next step can be kinda messy. Take out the black toner cartridge, and spin the motor backwards. You'll know you're going the right way because it won't turn the other way. Cycle the gear where the toner sits for about 2 revolutions. Reassemble and you should be good to go!
This thing took me 6 days to figure out the first time. Haha!
Please vote on my solution! Thanks!
Posted on Oct 26, 2009
pineworks
  • 4041 Answers
SOURCE: Xerox Phaser 8560 - error code 09 037 45 108564
Hi there
That's a ink loader error, due to the 8200 ink stick; to fix it:
- Power down the printer.
- Hold the back button and the info button at the same time, without letting go, power up the printer.
- Keep holding down the buttons until the XEROX logo comes fully to the center of the screen, keep holding for 2 more seconds, then let go. I'll take about a minute or two for the Diagnostic screen to come up, the display will turn blank and black.
- When the Diagnostic screen comes up go to down to the Function or Exercise option, there will be an option that says "clear ISC faults" it'll ask you to press OK to confirm, after you do then you will exit Diagnostics and the printer will reboot.
It should be fine until it happens again. Until all the 8200 ink is gone you will probably be doing this a few more times. Also make sure the 8200 ink is not jammed inside the ink loader, if it is then you have to un-jam it some how.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 02, 2010
SOURCE: I have a problem with ghosting on a Xerox Phaser 6360
I have the same problem with whatever color that used most. The Xerox sent its people over to fix it. However, the problem gets after a few days. Probably, it cannot handle large volume.
Posted on Jun 16, 2010
lawdog81
SOURCE: xerox phaser 6360 is ghosting.
Most common cause of this is the use of 3rd party toner. This isnt true for all printers but some of the newer Xerox are notorious for it as the 3rd party toners are not produced to the exact specs as xerox. If your not using genuin Xerox toner you have your cause.
If your mechanicaly savy you can completely dissasemble most of the printer in order to clean out the toner. Then start over with new Xerox toner cartridges. I have had to service 2 of these printers in this way, and both were like new when done.
Posted on Feb 11, 2011
Just put in a new imaging unit to a xerox phaser 6360 and now everything is pink... any ideas how to fix?
Check which colour you replaced and check that everything is seated correctly.
Good Luck.
Jul 22, 2014 | Xerox Phaser 6360 Laser Printer
Xerox phaser 6360 imaging unit stuck
The lid lifts a lever on the right side of the printer that moves a set of gears that releases the imaging unit. If the lever is broken or disconnected, it will not release. You may have to remove the right side panel to resolve it. You have to release the top, by removing 4 screws, and then the panel will release.
May 18, 2012 | Xerox Phaser 6360 Laser Printer
Phaser 6360 printer as a error code 07
Unplug the printer from power for at least half an hour. Overnight would be better.
Jul 07, 2011 | Xerox Phaser 6360 Laser Printer
Xerox phaser 6360 laser failure code 07
The most likely cause here is the laser unit, check all connections to the laser unit and cycle the power (turn the machine off and on) if error continues replace the laser unit. You can buy a replacement for $350 new or $225 refurb. Part# 062K17233. Installation isn't very simple, so if you aren't a technician you may want to bring it to one. Good luck
Apr 22, 2011 | Xerox Phaser 6360 Laser Printer
Are LD products safe to use?
Safe , most likely, recommended? I don't recommend using generic supplies in anything but ink ket printers. By that I mean the liquid inks. The toner is a phaser is pretty unique, and the OEM toner is by far the best way to go.
Jan 20, 2010 | Xerox Phaserâ„¢ 6360/DT Printer
I have a problem with ghosting on a Xerox Phaser 6360. Have replaced the Transfer Roller, Imaging Unit, and Fuser. It looks like the problem is mainly in Magenta. This is not a repeating defect, but a...
Dec 02, 2009 | Xerox Phaser 6360 Laser Printer
Cannot install Xerox Phaser 6360 Laser Printer" on vista
http://www.support.xerox.com/go/results.asp?Xlang=en_US&XCntry=USA&prodID=6360&ripId=&Xtype=download
open the above link.it takes you to the download page
Nov 03, 2009 | Xerox Phaser 6360 Laser Printer
Xerox 6360 control panel blank
If your Xerox Phaser 6360 has either garbled characters, inverted or upside down display, or no display, the control panel is most likely bad and must be replaced. Here's a video on how to do it and where to get it. Hope it helps!
Mar 30, 2009 | Xerox Phaser 6360 Laser Printer
Niallbt
Feb 25, 2009 | Xerox Phaser 6360 Laser Printer
Market projection and price of of this product Xerox phaser 6360
50,000 pages a month and depending on features, $1400 to 3000.
Feb 02, 2008 | Xerox Phaser 6360 Laser Printer
Xerox Phaser  6360 Laser Printer Logo
59 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
