Question about Ovens
Is it easy to replace a broken door spring (right side) on Siemens Innowave Oven HB86E560B
The spring appears to have broken on right hand side and door drops far too quickly now (left spring still okay). I have identified part # 42 8608 (spring) from siemens website ... it fits lever 49 1731. I was wondering if the side panel 47 1603 comes away ok to expose lever/spring. Thanks in advance
Firstly, I spent some time searching for info. on how to repair a broken door spring in this type of micro-combi oven (Siemens Innowave HB86E560N), eventually gave up and just tried. It turned out to be a piece of cake.
The part you need can be found on the internet, just type in the name and code of your oven and look for a door spring, mine cost 17 euro including packing.
Turn off the electrical supply to your oven (obvious, I know). Open the door and then unscrew the 2 securing brackets holding the oven "built-in". Your oven will slide out, but its quite heavy and will probably need 2 of you (one to make sure your power cable doesn't catch). Now you have to unscrew the casing. Start with the screws in the top section, which will then slide backwards and off. Now unscrew the slide panel were you expect your broken spring is. You shouldn't have to unscrew all the screws, but enough to allow easy access without bending the metal casing out of shape. When you (gently) pull the metal casing aside you will be able to see your problem straight away. Now simply hook your new spring in place (its pretty obvious, otherwise take a look at the spring on the other door). Presto.
To be honest the worst part of the job was getting all the screws to go in straight. I was finished in 30 minutes.... saving (I guess) at least 100 euro.
Good Luck
Posted on Jun 18, 2014
  • 3 Answers
SOURCE: Control Panel
See:
http://www.siemens-home.com/pdf/sl84a30xuc_manual.pdf
There is a pic with the buttons in there.
Posted on Dec 28, 2008
SOURCE: Identifying my dishwasher
On my Siemens all the ID numbers are on the top of the door, on the metal, "inside" part of the door.
Posted on Oct 26, 2008
  • 3 Answers
SOURCE: Dishwasher door won't open, latch seems broken
Hello, I read your comment. If the latch is broken, then I suggest first of all disconect the electricity from the dishwasher. You may want to try using a small screwdriver and insert it where the latch is to activate the opening mechanism. If it doesnt open, then there are two options, I suggest to call the technical service to replace the door with a new latch.
Hope I have been of help.
Regards Nevd ´ll fixya.
Posted on Feb 15, 2009
SOURCE: How do get access to the door hinge of my Maytag CWE4800ACB oven
In first, excuse my poor english if i make some mistake.
I hare repair the same problem. part broken in left side and the door fall.
You have to pull out the oven from the wall, use some objet to support the oven,small table or plastic box if you dont want to put down completely.
You have to unsecure the electric wire connection in back if you whant to pull out enough for remove the left cover. You have to remove some parts in front for acces to screws on the side cabinet.
In my case the hinge was broken, i have soldered and fix again.
If hard to replace the spring in the mecanism, you better to do this on the bench before put all in the side of the oven.
I think the maytag oven have the same problem.
Other problem also is the timer alarm sound in the night went you sleeping, prob whit switch sensitif pc board. Now i turn off the breaker in the back of oven all night, and i sleep good.
Bye..
Posted on Jun 03, 2009
bozcro
  • 867 Answers
SOURCE: the inside glass needs cleaning on siemens
look for screws around the door, usally phillips, remove them then gently pry the door apart. popping the door off will make work easier.
Posted on Jun 27, 2009
What replacement parts should I order to keep my Kenmore oven door from just dropping down when it is opened?
If the hinge is not broken "Check the Springs".
They sometimes come off at one end or can be broken.
There are 2 one on each hinge. They are strong so be VERY careful.
As I remember they have a color code according to how strong that are according to the weight of the oven door.
The surest way is to get the MODEL NUMBER from the tag on your oven. The parts store will be able to look up the proper replacement.
I may be able to tell you more with a model number for Identification, the oven is likely a Whirlpool Product made for Kenmore. Let me know if you are in New York City area.
Hope this helps.
May 19, 2015 | Kenmore 47783 Electric Single Oven
Hi, We have a Westinghouse electric wall oven with a door which appears to have a broken spring inside. We have previously been able to set it back in gap for hinge but now it has given up holding...
You should be able to buy new springs or the hinge complete from most appliance parts outlets. On some Westinghouse, the door will slide straight off the hinges but on others, you have to strip the door to get at them. Try opening the door and see if the door slides up and away from the oven. If it does, its pretty easy to change the hinge, if not, there will be a little clip on each hinge which locks the arm in place. Slide the clip on both hinges to the front and then you can lift the door up and out of the oven. remove the screws holding the door together and then you will see the 2 screws which hold the hinges in. Order a left (or right) hand side whatever one you need, but I would suggest that they are replaced as a pair, otherwise the door may not close evenly.
Jul 31, 2011 | Ovens
Fault code Close Door (__M) Keeps coming up and oven wont start
door switch on the right side (looking at the oven) is broken, part is about 2 to 3$, unscrew 2 screws and that's it
Apr 15, 2011 | TurboChef TORNADO Electric Oven
Our magic chef gas stove oven door spring has broken how to replace it
Pull out the oven. If it has no side panels then GREAT you can replace it very easy from the side. If not then you are going to need to take off that one side. IF neither of those are possible, then you might have to replace it from the backside of the oven after removing the panel. And finally there is a VERY rare last way which the oven is dismantled from the inside. I don't know what model you have so I am betting it is from the side when you pull it out.
Mar 14, 2010 | Ovens
Top oven door will not close..appears left hinge not working
The problem will be caused the hinge spring being broken or weak.
The only solution is to replace both oven door hinges to ensure a satisfactory repair.
Trust this helps with your problem.
Dec 15, 2009 | GE Profile JTP56 Electric Double Oven
The right hand side of the main oven has broken
You have not given much information to go on, but I am assuming that you mean the door hinge has broken.
If it is a drop down door, then you will have to replace the hinges as a pair.
If it is not the door that is the prob, then I need more information.
Thanks
Please rate my comments.
Nov 22, 2009 | Stoves 720EF Electric Double Oven
Moffatt double oven 4175 lower oven door springs broken
My problem was not with an Amana single oven but aMoffatt double oven ! However I have now decided to buy new.
Oct 31, 2009 | Amana AEW3530DD Electric Single Oven
Kleenmaid Stainless Steel oven door will not close properly.
The door hinge is probaly broken or could just be the spring. Open the door to the 45 degree position (halfway) and pull on the door. It should come off the hinge assembly. Slide out the oven a little to access the screws for the hinge to see what is broken or wore out.
Aug 10, 2009 | Ovens
Hello I am after the user manual for a Siemens HB86E560B microwave oven
The SIEMENS HB86E560B is discontinued. You can try one HERE
Jul 08, 2009 | Siemens Ovens
Bye..
Mar 24, 2009 | Maytag CWE4800A Electric Single Oven
Ovens Logo
204 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
