Question about Ubi Soft IL-2 1946 PC
Cannot install IL 2 1946
When I put the disk in the disk drive nothing happens. It does not appear to be reading the disk. I have a windows vista system.
  • 2 more comments
  • Anonymous Feb 02, 2009
    asd
  • vilsos Feb 03, 2009
    same here with 32mb vista, worked fine with my old computer with xp though...
  • Anonymous Mar 01, 2009
    Same prob... Thing is, I brought a whole bunch of files over from my old XP 'puter and it worked! Can't tell you how or why. UNFORTUNATELY, I had to uninstall the game, and now it won't work... Back to square one. I'll let you know if I solve it mate
  • Anonymous Apr 18, 2009
    SSAME
Try Compatibility Mode for XP 3. It was a solution for me.
Posted on Jul 10, 2010
Disk read error occurred on hp mini 110-3135
Sounds like your disk drive has a problem. Now is the time when you need a CD drive to fix it or attempt to fix it by running the Check Disk Utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
May 11, 2012 | Computers & Internet
Dell inspiron 530s intel 2 windows vista, black screen at startup than disk read error
Disk read error happens when there is a hard drive failure (sometimes in isolated spots and some times crital failure) if you have another computer, you can try connecting the hard drive as secondary and check if you can backup. The solution to this problem is to replace the hard disk drive.
Feb 03, 2011 | Computers & Internet
Hii..I Am Having An Acer Aspire 5050...Well I Installed Windows Vista Ultimate On It But Originally It Was Windows Visa,Therefore,After Installing Windows Vista Ultimate I Tried To Upgrade The...
If you place your Win7 disk in the DVD drive boot the laptop from the disk and choose to install a new system.
Follow the menu and prompts.
When it has installed download the drivers from Acer.com otherwise you will get problems.
Hope that helps.
Jan 08, 2011 | Acer Aspire 5050-3242 Notebook
My computer won't read disks.
There's only two possiblities either your driver has been corrupted or the drive itself has failed. Try reinstalling the driver, first find or download the driver for your CD drive, when windows tell you it already has the best driver hit back and tell it to install the driver at the location where your driver is at. If this doesn't fix the problem your best fix is to buy a new CD drive, given the current cost of DVD drives this might be a good time to upgrade.
Jul 05, 2010 | Dell Dimension C521 PC Desktop
Will this drive work on a vista 64 bit system?
Try putting the same disks into some other CD/DVD reader, to confirm that the disks are "good".
It definitely should work in XP, XP/64, Vista, Vista/64,
but you could have the misfortune to have purchased a "lemon", i.e., a factory-defective unit.
Got another computer to which you can temporarily connect the new drive, to confirm that the drive will work "somewhere" ?
If all else fails, take it back to the retailer, and get them to demonstrate that it works in one of their computers, using your disks. If it does not, then they should replace it with one that CAN read your disks.
Nov 27, 2009 | Toshiba PA3761U-1DV2 DVD-RAM Burner
My sims double deluxe will start at all.
Vista sucks, no offence, but vista sucks, there was probably a glitch in the thing that pops up when you put a CD-ROM in, so to play the game, go to my computer and select the disk from under devices with removable storage.
Jul 27, 2009 | EA - Electronic Arts The Sims Double...
Cannot get CD-ROM to work,to come up on screen.
Ok with that you need to insert the disc and then go into the my computer section of your computer and then in the CD rom drive you should see the disc and you will click on it to start the process. However if that does not work then your CD rom drive is defective and you need to purchase a new one.
Jun 17, 2009 | Computers & Internet
Inserting pc game and nothing happening, I have windows vista. I have tried putting in by run D;\set up still nothing
Have you considered that the disk may be faulty? This does happen from time to time, if other disks work in your drive and this disk is not picked up at all even if you check in 'My Computer' and nothing is displayed under your cdrom drive then the disk may be faulty.
Also if the game is written on a dvd disk and you are trying to play it using a cdrom drive and not a dvdrom drive then it will not work
Nov 25, 2008 | Computers & Internet
I'am installing a hp photosmart d7260 and have a problem with the install disk . Disk is for windows 2000,xp,vista version 10.0.0 When i load the disk in the drive it just flashes the in use light on the...
hi bob... here is the link... to download the drive for vista.... for hp photosmart d7260
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=3315742&
Sep 21, 2008 | HP Office Equipment & Supplies
External hard disk installation
plz check your usb port if other device read ...........then your external hard disk so error. or if ex hard ok...you install windows vista .
Jan 19, 2008 | Computers & Internet
Ubi Soft IL-2 1946 PC Logo
1,435 people viewed this question
Top Ubi Soft Video Game Consoles & Games Experts
dante
Tom Chichester
MegaByteMe
MegaByteMe
Are you an Ubi Soft Video Game Console and Game Expert? Answer questions, earn points and help others
