Question about Microsoft Windows Vista Ultimate Edition
Graphics.h In my PC i installed the windos vista ultimate OS... when i using the turboC++ editor its not support the graphics.h file
    Scholar:
  • 85 Answers
Ok there is a compatibility issue to run C++ on windows vista...
so try run C++ on compatibility mode [Right click on C++ icon, click on properties, than compatibility] change that to windows 98 or XP.
also try to re install graphics.h header file..
It will solve your problem.
Posted on Jan 24, 2009
How can i install turbo c in windows 7 x64
How to install Turbo C++ on Windows 7 We are providing detailed procedure how to install Turbo C++ on Windows 7. The very same procedure can be used on Win Vista. If you are running 64 bit version of Win 7, read this article. Users having Win 7 Pro and Win 7 Ultimate should use the virtual Windows XP Mode to install Turbo C++.
Installing Turbo C++ on Windows 7
1. Extract the zip files to: e.g. C:\TurboC
step1.jpg Extract zip files
2. Run the install: C:\TurboC\INSTALL.EXE
step2.jpg Run the install
3. Press Enter to continue
step3.jpg Press Enter to continue
4. Enter the Source drive: e.g.C and press Enter to continue
step4.jpg Enter the Source drive
5. Enter the Source path: \TURBOC and press Enter to continue
step5.jpg Enter the Source path
6. In directories specify where Turbo C files are copied. E.g. C:\TC . When done go to start instalation and press Enter
step6.jpg Specify where Turbo C++ files are copied
7. Succesfull instalation
step7.jpg Succesfull instalation
8. First launch from your destination e.g. C:\TC\BIN\TC.EXE
step8.jpg First launch from your destination
Jun 23, 2010 | Computers & Internet
Lg kg195 is not connet pc for internet
u need to call ur Mobile company and ask them u configure ur mobile for this service. Tell them u want to use the phone to access internt on your PC. They will help u setup the connection
Mar 24, 2010 | Microsoft Windows Vista Ultimate Edition
Turboc on win7
Turbo C Was A 16 bit application Which Don't Work On a 64 Bit Os And You Confirmed that Dosbox Or Virtual Pc Isn't Work For You!!
The Only hope Was to Use Windows XP Mode For It!!
If Not Then There is No Hope!!
Feb 06, 2010 | Microsoft Windows® Vista 64-bit Business...
How to run turboc in full screen in windows vista ultimate
Windows Vista And above doest not support full screen command window.. In order to run dos programs in full screen mode u can you use dosbox emulator which will be more convenient. Note that if you use pointers in your program it may not wok under vista directly.. If u run under the dosbox emulation it will work fine.. You can download dosbox from http://www.softpedia.com/get/Programming/Other-Programming-Files/DOSBox.shtml
Sep 22, 2009 | Microsoft Windows Vista Ultimate Edition
How to run turbo c++in vista 64 bit os
You can run Turbo C++ 3.0 on Windows XP 64 bit , Vista 32 bit and 64 bit OS (in full screen)
Install the software DOSBox ver 0.72 (Freeware) from the link below (Direct Link)
http://prdownloads.so urcef orge.net/dosbox/DOSBox0.72-win 32-in staller.exe?download
Before going to the details u have to create a folder (any name will do).
Here we name it as Turbo
Copy the TC into the Turbo folder
Run the DOSBox 0.72 from the icon located on the desktop or from the location of the installation folder
Then u are presented with two screens which look like the command prompt in Windows
Now u are presented with two screens. One with a Z prompt. U can ignore the other screen.
There type the following commands at the command prompt [Z]:
Mount [Type in any alphabet that u wish except z] [Type the source of the turbo C] press enter
For example (Type in the following commands after the Z prompt):
Z: mount d c:\Turbo\ [The folder TC is present inside the folder Turbo]
* Now u should get a message which says: Drive D is mounted as a local directory c:\Turbo\ ***
C:\> cd TC [The contents inside the folder Turbo gets mounted as a virtual drive (Here D drive)
source site :
http://mycomputer.freefor ums.o rg/running-turbo-c-in-full-scr een-m ode-help-t1241.html .
Sep 03, 2009 | Microsoft Windows Vista Ultimate Edition
Turbo-c++ is not installed in full screen
Hi sagar,
Turbo C++ 3.0 is made for MS DOS 6.22 environment. In windows also we can run Turbo C because windows environment provides all native services of DOS. But in Windows VISTA some of the services are revoked. So to enable them either Vista is to be reconfigured or some add-ins are to me installed.
Other versions those can work in Vista are BOROLAND C++ 4.5, VISUAL C++ 6.0, and Visual Studio 2008. But in all these the graphics header file <graphics.h> will not work. Try to find an appropriate graphics header file or copy graphics.h in the cource directory and use #include "graphics.h" command in your C Program.
Please revert to me if having problems.
Zulfikar Ali
ali_zulfikar@yahoo.com
09899780221
Jan 31, 2009 | Microsoft Windows Vista Ultimate Edition
C++
What version of Vista do you have it intalled on your system? You will need 64 bit Vista OS, 32 bit wont support it.
Aug 18, 2008 | Microsoft Windows Vista Ultimate Edition
Pencommander icon is not displaying in system tray-Text is not displaying in the editor while drawing.
try going to web site for penwriter and download drivers for vista. may not be designed for vista...
Jul 29, 2008 | Wacom (PTZ930AC) Graphic Tablet
Microsoft Windows Vista Ultimate Edition Logo
149 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
