Question about ASUS Computers & Internet
Zenbook display problem
Dislplay show contens with empty white area about 1/3 of highest of screen. Whole information is move down within thid distance. Everything what is on the bottom of display is invisible. There appear random changes of colors and brighnest of screen until disappering entire screen - everything is white.
    New Friend:
    Problem Solver:
  • 5 Answers
Please change your windows or set up your windows again...
Thanks..
Posted on Jan 13, 2018
Cerfer39
  • 709 Answers
SOURCE: Black Out
Hi Detrix, Check with www.lcdrepair.net if you want a repair. Something is wrong with your LCD controller and or GUI interface circuit or the circuit supplying power to it. If your technically endowed, you may want to open the monitor case and clean the dust and lint from around the circuits using a Small paint brush to sweep away any built up dust. These circuits take the Signal from the computer and controls the 2.5 million pixels on the LCD screen. Dsut can cause major problems with handling all that data. Give it a shot, what do you have to loose, its not dangerous if the monitor is unplugged.
Posted on Oct 10, 2007
Corster
  • 79 Answers
SOURCE: upside down characters
Silly question - are you holding it the right way up?
If you are, there may be a display setting for rotation.
Posted on Jan 28, 2008
SOURCE: LCD Screen Fried
Has anyone installed a new flex cable before. and if is, was it very difficult?
Posted on May 02, 2008
  • 29 Answers
SOURCE: Water Freezing in bottom of Freezer and dripping out front of freezer door
this could either be a blocked drain from the freezer not allowing defrost water to escape or the defrost heater failing to turn on due to a faulty defrost heater or defrost timer not enabling the water to escape
Posted on Aug 13, 2008
Niraj Limbu
  • 183 Answers
SOURCE: display shows pink color lines in white areas of the screen
Reinstall your VGA driver and i assume, it should be fixed if not you need to think about *********** board.
thanks
Posted on Dec 27, 2008
Dell inspiron mini 910 laptop video has lines and text is hard to read
1) Is the Screen resolution set correctly?
Native screen resolution should be set to 1024 x 600.
Right-click on an empty area of your desktop screen.
Go to the bottom of the list, and click on - Properties
The Display Properties window will come up.
Click on the Settings tab.
Down in the middle of the Display Properties window, you will see Screen resolution in blue.
There is a Slider. In WinXP it is an Arrow, with a Green tip on top, and bottom.
Left-click on the Slider, hold the left mouse button down.
Now move your mouse to the Left, to drag the Slider to Less screen Resolution, or to the Right to Increase.
Stop at 1024 x 600 pixels.
Also the Color quality should be set to Highest (32 bit)
Click on the blue down arrow to the right of the Color quality box.
In the list click on Highest (32 bit)
Go below to the Right, and click on Apply.
Now go below to the Left, and click on OK.
If that doesn't cure the problem, the problem is a hardware issue.
Problem will be;
1) Graphics chipset,
OR,
2) Video Cable,
OR,
3) LCD screen
[The Backlight used is LED backlighting. Uses a series of LED's.
Light Emitting Diode.
There is NO screen Inverter ]
http://www.dell.com/support/Manuals/us/en/19/Product/inspiron-mini9
If it is a hardware issue, I can guide you through the diagnostic flowchart, to see what the problem is, and step by step.
Post back in a Comment.
Regards,
joecoolvette
Mar 16, 2013 | Dell Inspiron 9100 Notebook
Move task bar to bottom of page
The desktop screenshot might need reducing
Click start "Control Panel."
Click "Display" and then select the Settings tab in the Display Properties window.
Use the slider bar under in the screen resolution section of the applet to change the resolution and click "Apply."
The screen repaints at the new resolution.
Click "Yes" to keep the resolution, or answer "No" at the prompt to revert to the original settings.
The taskbar is a central user interface component within the Microsoft Windows 2000 operating system.
Located along the bottom of the screen by default, it includes the "Start" button, provides one-click access to all open programs and contains a collection of utility icons and the system clock in a section called the Notification Area.
Windows 2000 gives you the ability to adjust the behavior of the taskbar in several ways.
After you know where to find the proper menu item, performing this task takes only a few clicks.
Right-click on an empty area of the taskbar and select "Properties."
Click the "General" tab located along the top of the resulting dialog box.
Check the Always on Top box if you want the taskbar to appear above all other items on your screen.
Check the Auto Hide box if you want the taskbar to disappear into the bottom of the screen when you move the cursor away from the taskbar.
Check the Show Small Icons in Start Menu box if you want to enable this behavior.
Check the Show Clock box to show the system clock within the Notification Area at the right edge of the taskbar.
Check the Personalized Menus box if you want the "Start" menu to show the items you use regularly and hide the items you don't.
Click "OK" to confirm your changes.
They take effect immediately.
Hope this helps
Nov 09, 2012 | Microsoft Windows 2000 Professional for PC
NVidia 6200LE scrambling the BIOS screen
Yep.
Spanky, Alfalfa, Stymie, Buckwheat, and Darla; all down here at the He-Man Woman Haters Club,
http://en.wikipedia.org/wiki/Our_Gang
Reset your Screen Resolution
Assuming you have WinXP;
In the drop down list, left-click on Properties.
In the Display Properties window left-click on the Settings tab. (Top)
Screen resolution is stated in the middle. There is a Slider underneath the heading.
[ Green tipped, and capped, Down Arrow)
Drag the Slider left or right, to bring the screen resolution to the correct setting.
(Ignore if you are aware. Put your mouse cursor on the Slider.
Left-click, hold the left mouse button down. Now move your mouse left, or right, and drag the Slider )
The correct screen resolution is........................hey, come back here with THAT Spanky!...............1280 x 1024
http://support.gateway.com/s/MONITOR/7003481/700348103.shtml
To the right look at Color quality.
Should have - Highest (32 bit) in the box underneath.
If not left-click on the blue Down Arrow to the right of the box.
Left-click on Highest (32 bit) in the list.
Now go down to the bottom right of the Display Properties window, and left-click on Apply.
Finally go to the bottom left side, and click on OK.
Windows XP has the drivers.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 05, 2012 | ASUS Computers & Internet
Adjusting pcoutput signal with windows xp
The only 'output signal' you are going to adjust is the video signal.
The only adjustment there is the Screen Resolution, and Screen Quality.
Left-click on Properties at the bottom of the drop-down list.
In the middle of the window, and on the left side, is Screen resolution.
Move the Slider to the left to Decrease the resolution.
To the right to Increase the resolution.
(The Slider is the arrow that has a green tip on the top and bottom. Sits on the line in-between Lee and More.
Put your mouse cursor on it, press the left mouse button down, and hold it down.
Now drag the Slider back and forth, by moving the mouse left to right. Set it to the Screen resolution that you desire)
Color quality:
It should state - Highest (32 bit)
If not click on the blue down arrow to the right.
Then click on Highest (32 bit)
After you set the Screen resolution and/or the Color quality, be SURE to go below, and click on Apply.
Then click on OK.
The above not what you had in mind? Post back in a Comment.
Regards,
joecoolvette
Mar 17, 2012 | Computers & Internet
I am trying to get the Mephisto, Master, to move as white first. I have set the operation mode at +top but it still opens up game playing computor as black
My name is Paul and I can answer your question about making the Mephisto Master Chess computer play the white pieces.
1. Set up the pieces so that you are playing black or have black pieces closest to you.
2. Push the option button and push your finger or a chess piece down on square G1 making sure that you have a symbol with the appearance of a cross to the left of the word top.
3. Push the clear button once and you will recognize that the display is showing that white has the turn.
4. push the enter button one time to force white to show its first move. Now what you see in the display will not be correct but stand up and look at the display lights horizontal and veritcal and you will see that they indicate the correct piece to be moved but the alphabetical and numerical information on the LCD or the display will not match.
Follow the display lights and look the the piece symbol and you will see what I am talking about.
I haven't figured out how to make the computer show the correct information yet but when I do I will let you know immediately.
Have fun
Jul 17, 2011 | Mephisto Master Chess Computer
Monitor screen is almost completely black - i can only see the desktop very slightly. is there a light bulb that can be replaced to fix this?
Change the display resolution in Windows To change the display resolution to the highest resolution, use the following actions.
  • In Windows 7 , click Start , click Control Panel , find the Appearance and Personalization area , and click Adjust Screen Resolution . Move the slider bar until the highest resolution for the monitor is set, and click OK .
  • In Windows Vista , click Start , click Control Panel , find the Appearance and Personalization area , and click Adjust Screen Resolution . Move the slider bar until the highest resolution for the monitor is set, and click OK .
  • In Windows XP , click Start , click Settings , and then click Control Panel . Double-click the Display icon, and select the Settings tab. Move the slider bar until the highest resolution is set, and click OK .
If the screen is still blurry, please contact an HP support technician for further assistance.
Also see To troubleshoot this problem, make sure the AC adapter is connected. For specific steps, see HP Notebook PCs - Troubleshooting Black Screen Displays with No Error Messages During Startup or Boot .
Nov 02, 2010 | HP G60-127NR Notebook
Screen will flicker a few times at random periods
Change the display resolution in Windows Change the display resolution to the highest resolution using the following actions:
If the screen is still blurry, the notebook display might need servicing.
Feb 13, 2010 | HP Pavilion dv4000 Notebook
MY NIKON D50 SCREEN HAS THE WHITE AREAS OF PICTURES FLASH BLACK AND WHITE
This screen shows areas of the photo that are overexposed slightly.
It flashes them to help you.
You get to this screen by pressing the up or down arrows when displaying the pictures you have taken.
To change it just press the up arrow when the camera is showing the screen until you get a display without flashing.
Once you have done this the display will be steady.
If you get any other screen in future you may have accidently pressed the arrow again.
Just cycle thru the displays to get back to steady.
Jul 21, 2009 | Nikon D50 Digital Camera
Nec monitor LCD1560V
Try changing the resolution of the screen. Right click on an empty area of the desktop and select properties. Now choose the Settings tab and try adjusting the slider for resolution and click on APPLY. The screen will go blank for a few seconds and will show up in the new resolution. If you find it satisfactory, click OK to keep it, or click NO to go back and try a different resolution.
You can also go into Control Panel and check the monitor properties from there.
Hope that helps!
Oct 21, 2008 | NEC Computers & Internet
Nokia 7610i shows white screen
just re format your fon for highest version
Aug 22, 2007 | Nokia 7610 Handheld
Computers & Internet Logo
101 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
