Solution to copy is too darker in canon gp160f copier
The copy is too darker, how to fix it
    Genius:
  • 1,669 Answers
Try this site:
http://www.2shared.com/document/wADPOTJz/Canon_GP160F_GP160DF_and_GP160.html
Posted on Jan 15, 2013
jaylex
  • 417 Answers
SOURCE: Failure to print properly
Is the machine a digital machine? If so there is a slight chance that the reason for the problem is that the mirrors are dirty under the copy glass. Remove glass and using glass cleaner on a soft cloth clean mirrors. Do not remove mirrors........
Clean copy glass and replace. If problem still there poss developer change or drum unit but most common is optic section. Also clean a **** glass in the machine. Open the door and you will notice a glass rod sticking out just above the drum unit. Remove clean and reinstall.
Hope this helps
Thanks Jason
Posted on Aug 17, 2008
  • 134 Answers
SOURCE: Canon PC981 Copier Print issue
When using generic toners, the automatic setting doesn't adjust to factory specs. So you have to adjust it manually. If you are using OEM toners the there is an issue with the density settings, and the unit needs to be adjusted by a tech.
Posted on Jun 12, 2008
  • 1602 Answers
SOURCE: darker copies
GO ON LINE AND TYPE THE FOLLOWING INFORMATION.
CANON PC-150 GRAYSCALE COPIER SERVICE MANUAL AND DRIVERS
OR
CANON PC150 COPIER DRIVERS SERVICE GUIDE
CANONUSA.COM
IF A USERS GROUP FOR CANON FORUM
TRY TYPEING THE FOLLOWING:
CANON PRINTER USERS GROUP FORUM
ENTER
PICK FROM THE BEST OF WHAT YOU NEED IF ANYTHING.
ROD
Posted on Feb 09, 2009
20YrsCompExp
  • 227 Answers
SOURCE: Lines repeating on copied paper from Canon PC 745 copier.
You probably have a piece of paper wrapped on your pressure cleaning roller inside the fuser. The patterm on the paper is the same and the spacing is equal and it is in the direction or feed.
Posted on Apr 12, 2009
Cogz
  • 1326 Answers
SOURCE: Canon PC6re copier makes copies that are dark on the long edges
Just fyi, a Canon PC-6e is a copier that is about ten + years old of a model... The drum unit will make the copies better.... But, you most likely need to clean the optic's. Have you tried to make the copies lighter??? If I am correct, there is a small botton on the control pannel that will turn... It will make the copies light one way and darker the other way... Good Luck
Posted on Apr 20, 2009
Mp 470 printer, how to make copies darker.
You most likely have done gradation simulation, strange that they are all light? All drums are new or in good %? have you changed out your transfer belt ITB?
Dec 04, 2013 | Canon imageRUNNER C3220 Color Copier
How to make darker copies
if your referring to photocopying but printout is darker, it doesnt work. canon copiers produce copies like the original or better than the original sometimes. try to scan the file in custom mode and adjust the brightness and contrast and click preview to view the outcome before scanning it then print it later
Sep 30, 2013 | Canon PIXMA MP210 Photo All-In-One Printer
Canon ir 1600 my copier print copy image is very poor
iR1600 are special machine that needs a little bit more care.
First, clean the laser unit and optics ( beneath copy glass too ). Then use some polisher and polish the developing cylinder and clean/replace developer cylinder blade.
Use GENUINE CANON DRUM UNIT and GENUINE TONER.
Jul 02, 2010 | Canon Office Equipment & Supplies
Apr 20, 2009 | Canon PC170 Copier
Want a B&W copy from colored sheet of paper w/o dark background.
It's never going to be perfect (unless the background is quite light in colour), because the copier basically "sees" the coloured background as "gray", and the darker the background the more "gray" it looks. Try setting the original type to "photo" mode, and then adjusting the exposure a little lighter/darker....that's all you can basically do.
Mar 25, 2009 | Canon imageRUNNER C5180 Color Copier
Darker copies
OR
CANONUSA.COM
ENTER
ROD
Feb 09, 2009 | Canon PC-150 Grayscale Copier
Cannot make copy darker
go into service mode second level and adjust your colors
Sep 26, 2008 | Canon imageRUNNER C3220 Color Copier
1/2 Page Darker
Did you put the old cartridge back in with the same out come? Also when the orginal is being scaned dose the scanning lamp turn off in the middle of a copy?
Mar 05, 2008 | Canon PC981 Copier
15 people viewed this question
k24674
jasbo
jasbo
