Can i increase RAM from 2gb(1gbx2) to 4gb(2gbx2) on an ASUS A8Fm notebook computer? Can it overcome it's said max memory limitation of 2gb only?
  • raymond_arg1
    raymond_arg1 Jan 15, 2013
    laptop specs says 2gb ddr2 memory is the max memory. I was planning to upgrade it from win vista to windows 7. So I would need to replace the 2gb into 4gb ram. Will it work?
  • 1,824 Answers
It's depending on what OS are you using.
Posted on Jan 15, 2013
  • 2 more comments
  • raymond_arg1
    It's current OS is Vista. But it's running slower. I want to install latest autocad & softwares. But it has only 2 slots filled with 1gb of ram each. Is it possible to upgrade to 4 gb?
  • Janis
    Janis Jan 15, 2013
    If you want to upgrade yourself, hmmm... it'll be difficuilt, I recommend you to go to a computer hardware specialist.
  • Janis
    Janis Jan 15, 2013
    Can you also please say what is the manufucator of the Pc?
  • Janis
    Janis Jan 15, 2013
    manufacturer*
3 Suggested Answers
antiochpc
  • 1314 Answers
SOURCE: How to increase the video memory of my laptop
This is done in the BIOS screen. Upon startup of the computer, press the key or key combination the screen tells you to in order to enter the BIOS. Somwhere in there there will be a selection for video memory that you can change. Thanks and please don't forget to give this solution a fixya rating. :c)
Posted on Jan 08, 2009
SOURCE: Asus charger
www.surelaptop.com is selling laptop accessories such as laptop adapter and laptop case. You can find out you adapter easily and their CS is helpful.
Posted on Feb 17, 2009
P4vp-mx can support dual core proscessor, 2gb. ram and 512 video card
http://www.asus.com/Motherboards/Intel_Socket_478/P4VPMX/#specifications
1 x AGP 4X (0.8V, 1.5V only) (graphic card AGP)
Memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory
Memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory
and if you click on the CPU Support List you see that it does not support Dual core processor :(
May 06, 2011 | ASUS P4VP-MX Motherboard
NO PROBLEM, IT RUNS GREAT. I HAVE A E2 MB MULTIMEDIA CHIP THAT I THOUGHT I COULD INSTALL TO INCREASE THE MEMEORY.?? DON'T KNOWMUCH ABOUT TECH BUT USE COMPUTER ALL THE TIME.
In order to increase the available RAM in your laptop you will need a chip called DDR2 SODIMM. These can be bought at NewEgg.com.
Apr 06, 2011 | HP Pavilion zd8000 Notebook
Can asus p5gz-mx support 2gb kingston 800mhz ram
Click here to view the Specifications of your computer mainboard.
Unfortunately only 2 x DIMM, max. 2GB, DDR2 533/400 MHz memory modules are supported.
Meaning that it is not possible for the 2gb kingston 800mhz RAM to run, according to the Specs.
Sorry to inform you of this fact!
damnor01
Jan 23, 2011 | ASUS P5GZ-MX Motherboard
Asus M2V890 motherboard supports max 2GB memory per specs. Is there any way to increase this, or am I stuck with 2GB?
2GB is enough for the MB you are using, if there are no more slots on the MB then you cant increase them.....every slot has a MAX limit of RAM card that can be installed, check the MB specification....i guess 1GB per slot is the MAX...so 2 slots...2GB
Nov 18, 2010 | ASUS V2-M2V890 AMD SktAM2 Barebone System...
Enquiries on maximum supported hard disk capacity and memory
Dell Optiplex 760 Vista
Max CPU Intel Q9550
Max RAM 8GB RAM
Largest HDD Shipped 1TB (Will likely Support 2TB)
Optiplex GX260
Max Intel Northwood 2.53 GHz - 533
Max RAM 2GB
Largest HDD Shipped was 200GB (Will likely support 500GB)
Dell Dimension XPS D300
Max CPU 333 Pentium II
Max RAM 384MB
Largest HDD Shipped 16GB (Will likely Support up to 80GB)
Dell Dimension XPS M
Max CPU 166S
Max RAM 64 MB
Largest HDD Shipped 4.3 GB (Max HDD likely 20GB)
Feb 09, 2010 | Dell OptiPlex GX260 PC Desktop
Hi, my Asus a8m has 512 mb of ram. I'm considering buying a macbook, but wondering if it would be worth upgrading to 1 or 2 mb of ram and having a professional 'clean out' my asus. Would it be worth it?...
max supported memory is 2GB (2x1GB sticks replacing your current memory). Yes, it'd be worth it to add more memory of you were keeping the machine, otherwise restore it to original configuration and sell it "as is". Don't get a professional, just used your ASUSes restore option to set it back to factory configuration.
Feb 07, 2010 | ASUS A8M Notebook
Can I increase RAM from 2gb to 3gb on an Asus F5VL and if so how, thank you
Yes you can increase your laptop memory up to 3GB because the memory limit that can handle of your laptop is 4GB. Go to any computer shop in your place and buy there a memory for your laptop. Bring your laptop so that they will handle the installation of the memory for your laptop computer.
Nov 09, 2009 | ASUS F5VL-A2 Notebook
I want to change the 2 x 512DDR ram by 2x 2GB DDR ram memories in my A205-S4577/Toshiba. Will it work?
hi,
it will work as your notebook is supporting maximum 4 gb RAM but please check that you are using 32 bit operating system or 64 bit one.
If it is 32 bit then the system will be showing 3.2 gb RAM only as this is the 32 bit os limitation.
Jun 03, 2009 | Toshiba Satellite A205-S4587 Notebook
Asus g2p max ram
You got two memory ports. One on the bottom of the unit.The second one is on top of your Notebook. To reach it you have to remove the keyboard. There are three small points on the top of the keyboard to unlock it. Under the keyboard you will find a metal protector with one screw which protects the second ram...
By the way: The Bios only recognizes up to 2 of ram.
System Profile ASUS G2P Standard Memory 0 MB (removable) Maximum Memory 2.0 GB Slots 2 sockets System Notes PC2-4200/5300 DDR2 SDRAM SODIMMs
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 04, 2008 | ASUS G2P Notebook
EXTENDING EXIST 2Gb RAM to 4Gb
hai ,frist u go to
start--my computer(right click it)---manage---disk management---
see your new hard disk & right click and shirnk volume
Jul 13, 2008 | Toshiba Satellite P205-S6287 Notebook PC
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
