Question about Baby Gear
I need to find out the electrical load in amps or KW for a zenith sun bed
The wife has just brought a zenith sun bed and i need to get it wired in but to do this i need to find out the electrical load in amps or KW would be greatfull for any help in finding this out
  • 396 Answers
Use OHM's law. wattage divided by voltage=amperage The bed should have an info sheet attached showing how many volts ( I am guessing 110 VAC) and it's wattage rating. I found that Zenith and Sunquest may be one in the same. Here is a link to the info sheet they have. Zenith/Sunquest Sun Bed Specs Link Looks like they draw a serious load, averaging 50 amps. Be sure to allow enough extra amperage in the circuit as to not overload and keep popping breakers.
Posted on Jan 22, 2013
Can you use 5.5 kw element in 4.0 kw balboa 58104 unit i ordered wrong part
The 5.5 KW unit will draw an additional 5 amps on the electrical circuit. There may be issues with wire size, switches and relays, and physical size. If it fits, and the wire size is at least #8, you should be good to go.
Oct 23, 2016 | Pool & Spa
Can I use the existing 40 amp double pole breaker?
Rule of live by: Each unit must have its own breaker. Cooktop needs 30 amps and a double oven needs 40 amps. Never combine the unit as the amps flow if too high can cause the wires to melt. I hope this helps. Be safe!
Sep 13, 2012 | Thermador Ovens
I HAVE A 3 PHASE 480V. 50 AMP TED134050 BREAKER WHICH FEEDS A 45 K.W. TRANSFORMER.WHICH TRIPS OCCASIONALLY, NOT OFTEN. IT RESETS O.K. WHAT DO YOU SUGGEST?
I would get an amp metetr on it and see what the load is.... if it is running continually at over 40 amp. then you are overloading it...and need to shed some load...
If it is not then the breaker is going bad and needs to be replaced...
heatman101
Nov 16, 2010 | Electric General Ted134050 50a 480v...
Goodman unit blows 45 amp fuses only in heat mode, worked fine all summer on a/c. It works well for some time then blows them again.
Check the breakers on the unit How many KW--electric heat? Check to see if you have the right wires wired up to the correct breaker cause some units have 40---and ---60 ---amps breakers and your thickest wire could be wired to the 40-amp breakers,, (some 5 KW pullls 19-23 amps respectably some breakers have 7.5 KW heat stips and pulls more and if the wire size can,t cary the amps, then all you have to do is reduce a heat strip.
Dec 18, 2009 | Goodman GMS90703BXA Heater
Zn110 controler
you need the RR3457. This remote will work right out of the package for your tv. NO PROGRAMMING REQUIRED. go here to check out more detail about it.
Sep 21, 2008 | Zenith ZN110 Remote Control
Wattage for oven pleb30s9fc
  • Connected Load (kW Rating) 240/208 Volts: 3.5/2.6
  • Amps @ 240/208 (Approx.): 14.6/12.6
  • Minimum Circuit Required - Amps: 30
  • Bake Element Wattage 240/208 Volts: 3400/2554
  • Broil Element Wattage 240/208 Volts: 2750/2065
  • Armored Electrical Cable
What kind of wires did you buy?
Jul 25, 2008 | Frigidaire PLEB30S9DC Electric Single Oven
Baby Gear Logo
272 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
