Had to do system restore, now it says to undo changes, cannot enable broadcom radiio on acer wireless laptop
Need to undo changes after doing system restore on acer wireless laptop, how? also have not been able to connect to internet because my radio is enabled tryed everything, 2434WLMi Intel dual
  • 7,627 Answers
Connect to the internet by connecting a Ethernet Cable to the Laptop and the Wireless Access Point/router. Open the Device Manager, Network Adapters, Click on the wireless adapter, is it enabled? yes or no? Yes, update driver. reboot laptop. Is your Wireless Access Point securied? unplug the wireless access point , wait for 30 seconds or so, plug in, wait for selftest, reboot laptop. You didn't supply the Laptop Make, Model or the OS you are using?
Posted on Jan 16, 2013
sandrew
  • 2961 Answers
SOURCE: Ip Address 169.x.x.x Wireless Internet Connection Problems 6400/E1505 Dell Laptop
when you renewed the ip address, windows assigns an ip address of 169.xxx.x.x, this your router will not be able to see. if you have enabled dhcp in the router, check that the wireless card is set to obtain an ip address automatically. If you have no luck that way, go to another pc and in the network card properties, look at the assigned ip address number that the router has given the pc, eg 192.168.2.2, if you have more than two pc you can bet that the other number assign wil be 192.168.2.3, so go to the problem pc's network card problem and and set the ip address manually to eg 192.168.2.4 and set the dns address to 255.255.255.0, save settings and try connecting again. the only other thing stopping a conection would be if the security, eg wep or wpa is enabled and the number has not been entered correctly into the network card properties.
Posted on Jul 26, 2007
  • 128 Answers
SOURCE: Do not know how to turn the wireless capability of my laptop on
go to device manager and see if your wireless network adapter is enabled (right click)
then go to the network connection in control panel and run the setup internet connection then choose the wireless option
then just follow instructions.
hope this helps
Posted on Nov 11, 2008
hakimmadina_
  • 155 Answers
SOURCE: How do I enable the wireless on my Acer Aspire one?
Open control panel scroll down to Internet connections and click to display. Right click wireless wizard then click choose enable. After this you will be prompted with a box that will show you that the computer has detected wifi connection in the surrounding.
Posted on Jun 22, 2009
Kiran_v3kr
  • 8 Answers
SOURCE: how do i enable wireless function on samsung v20 laptop?
you can try pressing fn+f10 to switch on and switch off wireless
Posted on Aug 11, 2009
KeithHL
  • 67 Answers
SOURCE: configure wireless connection on acer aspire one
Some people like to disable the zero config service for security purposes. Here's how to re-enable it (assuming you're using Windows XP) -
  • Go to Start then select Run (or use (WinKey+R key combo)
  • Put in services.msc
  • Keep hitting the W key until Wireless Zero Configuration is highlight.
  • Double click to bring up the properties of this service
  • You want to make the Startup type set to Automatic and then also click the Start button (next to the stop button and below the "Service status" line.
When you're done just push ok to get rid of the properties window and you can close the services screen. You should now be able to connect to the wireless.
Posted on Oct 07, 2009
Testimonial: "thanks a million for the help KeithHl, my wireless is up and running again, I really appreciate the advice!"
How do I get the acers drivers installed? I have down loaded all three wireless drivers,and none work.
Drivers for windows Vista are here: http://support.acer-euro.com/drivers/notebook/as_4720.html
Under Drivers and Utilities, Select and download these drives;
1. Wireless LAN Atheros
2. Wireless LAN Broadcom
3. Wireless LAN Intel
While installing, please start with "Intel" as you follow instruction there after. Restart your Laptop and install Broadcom, Atheros respectively.
Please ensure that VISTA SP1 is installed on your system prior to installing these drivers!
Driver incompatibilities on a system without VISTA SP1 might affect usability.
Rgds
Feb 07, 2011 | Acer Aspire 4720 Notebook
I have brought acer 5745 with i3 processor...after installing win 7,..it does not found bluetooth and wifi adapter... now how can i use it,...plz give me some sugesion
For you to use the Wireless and Bluetooth of you laptop you need to install the latest driver so that it will be detected by the computer and works properly. Click Here to download. Select the Type of Operating System that youre using wheter it is 32 or 64bit. The drop down is located on the upper right part of the website.
Thanks for using Fixya.
Jan 27, 2011 | Acer Computers & Internet
Wireless connection icon lost and wireless adapter not listed on the system tools
You can reinstall the wireless drivers from the Acer recovery management, to do so:
Start Menu> All Programs> Acer erecovery management> Restore> Restore Application & Drivers> Contents> Select Broadcom/Atheros wireless LAN and install it
Once the installation is over restart the computer.
OR
Got to http://gd.panam.acer.com/home/
Select the computer model
Select Operating System installed on your computer
Click Drivers
Select Wireless LAN and download it.
Once downloaded, install it on your computer and restart the computer
Thanks and regards,
Jitha
Jan 19, 2011 | Acer Aspire M1201 Athlon X2 320 Gb PC...
My gateway laptop cant connect to the internet. _When I plug a cable, the red light in the port does not respond _ The WIFI does not respond
Hello John,
It seems that: 1. Your LAN controller and the WiFi controller could be disabled in your BIOS setup.To re-enable them, if applicable,
  • Press the F1(or F2 ) key repeatedly after restarting the computer to enter the BIOS setup.
  • Navigate through your BIOS and locate the settings for LAN conroller and wireless, and select Enabled to enable them.
2. You may not have the appropriate drivers installed on your laptop for your network controllers. Upon further investigation, your laptop runs on the following network hardware:
  • ActionTec IEEE 802.11b network card installed in Mini PCI expansion slot
  • Broadcom BCM94306 IEEE802.11g network card installed in Mini PCI expansion slot
  • Broadcom BCM94300 IEEE802.11a/g network card installed in Mini PCI expansion slot
Download and install your drivers for the hardware above from: Wireless Drivers(Broadcom BCM94306) from http://www.soft32.com/download_175098.html Broadcom BCM94306 10/100Mbps LAN drivers from http://www.broadcom.com/support/ethernet_nic/downloaddrivers.php
Hope this solution helps.Good day.
Jan 14, 2011 | Gateway M305CRV Notebook
I have the lenovo 3000 n100 and it tells me there is no wireless adaptor installed???? I have a broadcom 802.11g in the notebook.
Normal 0 Restore your computer to a date that your wireless card worked.
Here are the steps to perform a system restore:
1. Click Start
2. Select All Programs
3. Scroll up to Accessories
4. Select System Tools
5. Choose System Restore
Select the first option (restore my computer to an earlier time) Choose a date and click next to complete.
You can always undo the restore by selecting the third option (undo my last restore) so do not worry about picking the wrong date.
If you are curious like I am you may want to know how or when your hardware was removed. If so before you restore your pc open System Information this tool is directly above System Restore in the System Tools folder. After you open the application go to View (on the toolbar) in the drop down menu select System History.
Now to the right you will see a drop down menu click that and select a date you want to view, this will show changes made since the chosen date. On the left pane you will want to highlight Components you can now view all changes made since the date you selected.
If you go to the top of the toolbar in the right pane and click the buttons (Time, Change and Name) it will sort by button clicked. For example if you click Change it will sort alphabetically displaying every added component first click it again and it does the reverse displaying every removed component.
Jan 07, 2010 | Lenovo 3000 N100 Notebook
My Wireless Broadcom Adapter is not properly running
here is the drivers and utilities page for your laptop.
http://support.acer-euro.com/drivers/notebook/as_4310.html
just download new drivers and restart.
go to your os then drivers and utilities tab then wireless broadcom and
lan broadcom.
Dec 26, 2008 | Computers & Internet
Wireless?
two suggestions, first you may need to enable it in your computers setup program. Normally you have the option just before windows starts to load, either by pressing F8 or esc will get you into the the computers main/basic setup screen. You should find the wi-fi is disabled so just a case of changing it to enable.
Secondly, within windows go to control panel then device manager, network adaptors, and you may find that your broadcom 802.11g network adaptor is disabled, you will need to enable it by using the icons at the top. If there is a problem with it then there will be a question mark beside it, then you will need to post the error message your getting for further assistance.
Feb 04, 2008 | Acer TravelMate 240 Notebook
Acer Aspire 3690 LAN/Network issues
You can get this driver, and any others, form the Acer site:
http://us.acer.com/
Follow the "notebooks" link.
Oct 10, 2007 | Linksys StackPro II 100BaseFX Distance...
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
