Question about Baumatic B180 Electric Single Oven
Baumatic fan assisted oven not heating up
Hi there
We have a Baumatic fan assisted oven and all of a sudden when on the oven function it doesn't heat up anymore. The grill and light and fan are still working.
Do you know what this might be caused by? Can it be repaired by ourselves? Thanks
  • Anonymous Mar 14, 2014
    How to start the oven
  • Anonymous Mar 24, 2014
    My Baumatic oven will not start?
  • Baumatic Master
  • 3,463 Answers
The oven element has failed, you need to fit a new element.
It is a straight forward repair to do.
Remove inner rear panel of oven, you will see the round element at rear.
Unfasten element, detach wires, and fit new element.
Refit rear panel, and test.
Plz rate my solution.
Thanks.
Posted on Jan 24, 2009
FIrstly disconnect ideally by turning off at the switchboard and then also in the kitchen. You will need to remove the inner oven panel and then remove a retaining nut from the element. Then you need to access the back of the oven - remove the back panel completely. Then disconnect the element - earth connection is in the centre - remove the two retaining screws on the element. Then instal the new element with retaining screws, and the one also in the inner section of the oven.
Posted on Dec 13, 2013
Grill and fan works but no heat to oven
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
May 15, 2011 | Baumatic B180 Electric Single Oven
Oven has stopped heating up
Hi.
This oven should have two elements.
If both broiling and baking element are not heating, then the most common fault causing the problem is a defective temperature probe.
The probe is located inside the oven cavity.
On most ovens there is only one temperature sensor, connected in line on the circuit from electroning oven control to baking and broiling element.
When the probe fails, it will affect both baking and broiling function.
The temperature probe is tested reching the probe, cutting or disconnecting its wiring, and testing the probe at room temperature, with a multimeter set on impedance at Rx1. If the multimeter reads no continuity (circuit open), then the probe must be replaced.
If the temperature probe is good, then parts that may be responsible for the fault are oven electronic control and wiring. Having both elements failing at the same time would be rather unusual.
If only one element is failing, then the fault is probably the element. In that case you can test the element removing it from the cavity, and testing Ohms on the element. If circuit is open , then the element must be replaced.
Regards.
Mar 03, 2010 | Baumatic B180 Electric Single Oven
My Baumatic B180W-B oven does not heat up. The
If the oven is electrically heated, then more than likely, the oven element has failed.
This is located behind a removeable cover at the rear of the oven.
Feb 21, 2010 | Baumatic B187 Electric Single Oven
Baumatic oven not heating up. Grill and fan fine.
if it is the b180, the answer (having just fixed this) is really simple.
The coily bit is the oven element - it will have gone. A new one from eBay cost me about 6 quid.
[WHEN IT ARRIVES !]
Turn the power off.
Inside the oven use a philips screwdriver to remove the 4 screws (KEEP THEM !)
You will see a coily thing and a fan.
You unscrew 3 more screws (2 on the left and 1 on the right).
(KEEP THESE TOO!)
now ... bit tricky, have the new one inside the oven and take each wire off one at a time and put it on the new element.
Screw it back on but DONT put the last panel back in.
Turn the oven on maximum for about 2 minutes and see it glow red.
Turn the oven off. Make a cup of tea and have a couple of biscuits while admiring how good you are and waiting for the element to cool down!!!
Put the final panel back in place. Whole thing (including a cup of tea) takes about half an hour.
Jan 27, 2010 | Baumatic B180 Electric Single Oven
Oven does not heat up in fan oven mode but fan runs. works fine in convection mode. Baumatic B723SS-A
whilst the fan is running the heating element which is usually in parallel with it should heat.. This usually means a faulty element..
Dec 17, 2009 | Baumatic Ovens
Good evening i have a BT2431SS baumatic cooker,i have no heat in main oven yet i have the hob and the grill that work ok.
If it is a fan assisted electric oven, and the fan is wrking o/k, then it will probably be a faulty oven element.
This is located at the rear of the oven compartment behind a removeable cover.
Please rate my solution.
Thanks.
Nov 24, 2009 | Baumatic Ovens
Oven not heating up
Hi.
If the fan is working o/k, then in all probability the fan oven element has failed.
A common problem with fan assisted ovens.
It is a fairly easy job to replace same
Nov 13, 2008 | Baumatic B180 Electric Single Oven
Fan Oven blows Fuse over 175 Celcius -Baumatic BT2760SS
Hi, I was cooking and my oven jut went off, looked in fuse mains box and had tripped. So put back on and now the fan works but no heat...Can you give me some idea what it mite be.
Sep 18, 2007 | Ovens
Fan assist wont heat oven
the ring element may have blown. if it works ok with the top and bottom elements, (the convection oven) then it is likely the element surrounding the oven fan.
Jun 25, 2007 | Baumatic B187 Stainless Steel Electric...
Baumatic B180 Electric Single Oven Logo
1,218 people viewed this question
Top Baumatic Ovens Experts
electric app
Level 1 Expert
Your Consultant
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
