Question about Logitech Speakers. S-120
What is the output voltage of the transformer in the system, mine is burnt so i need to change the transformer so i need to know the output voltage
    Problem Solver:
  • 5 Answers
Nominal Output Power (Total) -- 2.3 Watt
On the back of the right speaker where the power cable is connected there is a sticker where you can see the voltage the speakers are using. You should read there 120 V - 60 Hz 100mA.
You will have to use a voltage adapter from 120v to 220v. (found in electronic shops) that maintains the Voltage stability.
Regards,
Tariq Khan
Posted on Jan 15, 2013
I recently bought a U.S. version Nakamichi 600 II cassette console (120V), and I accidently burnt its transformer out by a 220V mains supply. Now I need to replace this burnt out transformer better with a...
To match it with an other transformer, you have to know about its secondary voltages. Try to download its service manual by internet. It will have all details. It will be best to contact any expereienced service technician or to the authorized service center for Nakamichi.
Feb 24, 2013 | Televison & Video
Crosley CR24 transformer rating
As transformers are Safety parts they must be replaced by the excat same part or one that is approved by Crosley. You should not attemp to use another transformer unless it's approved by Crosley. Otherwise it could become a fire hazard.
You can contact them here:
http://www.crosleyradio.com/Support.aspx
Nov 17, 2012 | Crosley Cr42 Turntable
Hi .. I recently got a bose 321 home entertainment system. Unknowingly i plugged it to a 230 V main .The display in the DVD player came for a moment and then went off..I came to know that i need a 230V to...
Right now the Transformer in the BOSE system might have burnt out or it might be shorted out. It would be better to check with BOSE, but for burnt transformers you cannot claim warranty from BOSE.
If bose refuses to provide the warranty then take it to a TV repairing shop and ask them to change the Transformer so that it would support direct 230v....
Apr 19, 2011 | Bose (321GS) System
I need the input voltage for ac adapter for my GE 98903 2.1 Pro Speaker System
The AC adapter input voltage is 120 Volts AC as it plugs into a wall outlet. I suspect you want to know the output voltage of the transformer. If you have the old transformer the output voltage is listed on the transformer top. May be hard to read but it is there. This system is also sold under then brand name Jasco. The Input voltage of the system should also be printed next to the power connection or on the speaker itself.
Nov 11, 2009 | Cars & Trucks
Transformer secondary out ???
please my name is dele i have this BOSE radio/cd system model number is AWRC2G which transformer burnt out rightly, that the input is 240volts which output is the problem and in nigria. please i just want to know the output on each coloured wire of the secondary that has 8 wires output from the secondary (2 purple - brn = volt, 2 blue = volts, and 2 black - gray = volts. so that similar that i can use to work it.
thank you
Aug 24, 2009 | Bose Wave Radio
I need to change the transformer inside the power supply. can you tell the the output voltage?
You need a meter to test the voltage else check the manual or normally it is written on the transformer about power,voltage and current.Hope this helps.
Jun 25, 2009 | Polycom SoundStation Accessories:...
Transformer blew on Hk395 speaker sysytem
I think I remember it being in the 12-24VAC range. If you are still interested I will open mine up and measure it.
Jun 23, 2009 | Dell HK395 Computer Speakers
Philco 841.205 Power Transformer
Hi:
...I have a brand new one exactly the same (Philco) that I will sell you for ten bucks.... but I don't know where you are?
Please e-mail me at: brodi@telus.net
Feb 08, 2009 | Philco (R) 841.205 CD Shelf System
NEW 600W L.V.TRANSFORMER DOES NOT PRODUCE ENOUGH POWER
This is more than likely what has happened . I am going to guess that your original low voltage trasformer was a 120 volt .6KW. Or 600watt transformer that has one lead from it to the lights . The newer less expensive transformer is also 600 watts , but the new one may have 2 sets of wire terminals on the back( 4 screws ). If this is the case , you have a transformer that is 600 watts output but it has 2 seperate 300 watt outputs that won't run 600 watts from 1 set of output screws . You will have to seperate the lighting load and may have to run an additional low voltage wire to half of your lights . In other words . Put 300 watts of light on 1 set of 12volt output screws and 300 watts on the other se of output screws .that will solve your issue . Good luck and enjoy your lights again . John
Nov 03, 2008 | Garden
Power Supply transformer failed
2 x 5 Watts RMS Stereo
5 watts continuous RMS power output per channel, at 8
ohms, from 120Hz to 15kHz, with no more than 10%
Total Harmonic Distortion (THD).
Jun 04, 2007 | Philips MC-105 CD Shelf System
Logitech Speakers. S-120 Logo
112 people viewed this question
Top Logitech Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
JP Services
JP Services
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
