Question about Exercise & Fitness
Er 4 message showing on the screen. display working, but belt doesnt move.
  • Clairey McBish Jan 19, 2013
    I am still having problems with this machine- I have now found a serial number- hy452580-di. I spoke to the tech team for pro fitness, and they say its a new model and they haven't had this problem before. I was told to take off the motor cover and check everything is still connected which it is. I have also I assembled the side supports to check connections here- they are all fine. Totally stuck :-(
    Genius:
  • 1,669 Answers
How about telling a little more information like what kind of machine it is, what is the manufacturer and the model, please!
Posted on Jan 15, 2013
  • Clairey McBish Jan 15, 2013
    Sorry its Pro Fitness Folding Motorised Treadmill- i believe its a new version. From argos. I cant see a specific model nuimber. I wondered if any one knows what each error message relates to- maybe they are the same on all pro fitness machines., i thought they woudl have told you in the instructions. The error message comes up in the time desply as Er 4. The display works, the belt doesnt move. We have had it working, then took out the key to test it works. Im not sure the key in engaging with the sensor inside. Does anyone know if this might be the problem, and what to do! Thanks
I have a sam4s ER-5200M. Today it started printing a 4 in front of all prices on the receipt. The screen says the correct amount.
http://cashregisterguys.com/files/Samsung_5200_40M_man.pdf
i saw this on page 116,it looks relevant,,,,,,,,,21.. Display add price of linked item? When Y, the customer display shows a total of the item and linked item. For example, if PLU is $1.00 and is linked to PLU2, which is $0.25, the display will show $1.25.
it doesnt add 40 dollars so that leads me to believe that there is an error with the printer,you might need to reset and start over or call the company,good luck.
Apr 21, 2015 | Retail Supplies
Sequence error warning comes up on display, as soon as i turned on my ER-5215 M cash register, how to fix it?
I have a cash register Model# ER-5215 M there is a message on the screen as follows: Reg. PBAL how do I fix it.
Jan 21, 2013 | Computers & Internet
What does message Er IF mean?
LG refrigerator "Er IF" error code is the "Icemaker Fan Error" message.T his error code indicates a problem with the fan that controls the unit's ice production. If this problem occurs because of ice buildup, unplugging the unit for 3 to 4 hours and allowing it to thaw may fix the issue. Call customer service if that doesn't work.
Oct 12, 2012 | LG Refrigerators
Motor not going on York Optimum 60100 - after a while E 1 appears
Dear Sir:
This is probably a 1) faulty speed sensor or 2)the speed sensor is not plugged in properly. Its also possibly a 3) faulty motor control board or lower board 4) Main motor faulty. . The error codes will differ between makes and models but could be e1.You must test
see my personal TIPS for diagnose and troubleshooting.
See if you can run the software calibration for diagnose and trouble.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Mar 05, 2012 | York Exercise & Fitness
How do I change the time on my CopyStar CS-1820
Setting the Time Zone
1 Access Time Zone.
If you are unsure how to use this route map refer to Accessing Menu Items on
page 3-3.
2 Press arrow keys to select the time zone that you are in.
3 Press Enter. The message display shows Completed and returns to the Date/
Timer Set. screen.
4 Press right Select. The message display returns to the basic screen.
NOTE: Periodically check the time that is shown in the message display and adjust
as necessary to match the current time.
1 Access Year/Time.
page 3-3.
2 To set the date, for each field press arrow keys as many times as necessary to
display the correct value then press arrow keys to move to the next field.
3 When the date is correct, press Enter. The time setting screen
(hour:minute:second) is displayed.
4 To set the time, for each field press arrow keys as many times as necessary to
5 Press Enter. The message display shows Completed and returns to the Date/
Timer Set. screen.
6 Press right Select. The message display returns to the basic screen.
Mar 17, 2011 | Copystar CS-1820 Copier
Fridge doesnt work, freezer works
You need to change the freezer fan motor. FF means problem with the Freezer Fan.
Sep 26, 2009 | LG LRFD22850ST French Door 22.4 Cu. Ft....
The panel control going shows Er in temp display
ER in temp means error code next 2 letters are first letter of part giving problem or where problem located.. if " ER DH" means def heater not coming on, does not mean heater bad but def control bad not letting voltage to heater. could need main bd also
Aug 21, 2009 | LG LRSC-26922 Side by Side Refrigerator
Error 4 Deplay showing Over current
hai,
error4, display board maybe not fine
Aug 10, 2009 | Spirit Esprit ET4 Treadmill
H20 dispenser displays er lf
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&^#
May 05, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
LG Refrigerator Defrost Error ER DH
it the def t-stat, def. thermistor, or def. fuse whatever lg decides to call it this week that is causing your issue
Jun 13, 2008 | Refrigerators
Exercise & Fitness Logo
65 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
