Question about Sony Car Audio & Video
High input amplifier installation
Speakers not working
    Genius:
  • 1,669 Answers
Hey guy! If you just bought that amplifier, whatever make and model, there should be instructions that came with it to hook it up to your radio or deck and any speakers you are to use!
Posted on Jan 15, 2013
Amp works on low side and full no high side
high level inputs are for speaker level inputs.Like if you used speaker wires right off your radio for input.Low level inputs are rca type inputs
Dec 19, 2012 | Performance Teknique Icbm-770 Monoblock...
Nitro (BMW-648) Digital Monoblock Car Audio Amplifier.. what is the high input plug for??
High power level input from speakers rather than a low level source such as line input
Nov 26, 2012 | Nitro Snowboards Nitro BMW648 Monoblock...
How it can be connected to a stereo amp
hi,
if ur amplifier have a pre out, then u can connect that to ur L/R input of ur sub woofer.
if not the only way is, connect ur amplifiers speaker output to sub woofers speaker input and then connect ur speaker to sub woofer speaker output terminal. remember don't inter change positive and negative wires.
if ur amplifier have speaker A,B connection then it is very easy. connect the speaker A to ur left and right speaker. then connect speaker B to ur sub woofer's left and right speaker input. be sure to make that speaker A and B switch is in on position. the power on both and check it. ( use good quality speaker cable to connect the sub woofer)
your sub woofer is designed to work , both at low level and high level input.
ok
Dec 17, 2010 | Yamaha YST-SW215 Subwoofer
Fosgate 201s amp, high level inputs... where do i hook these wires....
Hello mhjoubert,
On the Punch 201s, the high-level inputs are located just below the gain control. When used to power a sub, most commonly these are connected to the rear speaker wires of your receiver. If the amp is used to power a set of normal speakers, you would connect them to whichever set of speaker wires you intend to power.
Actually, it's probably a better idea to install a low-level converter on the receiver speaker wires and then use the RCA connections for input. This way, you have better control on the input signal, lessen the possibility of induced noise, and do not need to worry about an impedance mismatch causing problems.
You can download a copy of the Rockford-Fosgate manual here:
http://www.rockfordfosgate.com/scripts/rightnow.cfg/php.exe/enduser/std_adp.php?p_sid=ZLxer3vj&p_lva=&p_faqid=303&p_created=1083264761&p_sp=cF9zcmNoPTEmcF9ncmlkc29ydD0mcF9yb3dfY250PTEmcF9zZWFyY2hfdGV4dD0yMDFzJnBfc2VhcmNoX3R5cGU9MyZwX3Byb2RfbHZsMT1_YW55fiZwX3Byb2RfbHZsMj1_YW55fiZwX2NhdF9sdmwxPX5hbnl_JnBfY2F0X2x2bDI9fmFueX4mcF9zb3J0X2J5PWRmbHQmcF9wYWdlPTE*&p_li=
Hope this helps.
Apr 11, 2009 | Stingpro ST444 1850 Watts Complete...
1000w fli sub has 5 wires on high level input. What do these wires connect to?
Also called speaker level inputs, an input on an amplifier specifically designed for higher voltage and lower impedance signals, typically between 1.2 to 12 volts and 4 to 8 ohms, as found on the outputs of low powered speaker connections. Hi-level inputs are commonly used as an easy and convenient upgrade path to connect factory-installed head units to after-market amplifiers.
high level inputs are less subjected to interference and can travel further without signal loss.
Factory radios do not have dedicated outputs for amplifiers (preamp outputs). So you'll want an amplifier with speaker-level (often called high-level) inputs; these inputs enable you to tap into the factory speaker wires for a signal flow.
They're called high-level inputs because the voltage level is significantly higher than with a standard preamp output connection. These inputs convert the high voltage to one the amplifier can handle. Once connected, you'll hear clean, well-defined sound (including the lyrics to your favorite song).
Speaker-level inputs are a standard of many two- and four-channel, and mono subwoofer amplifiers.
All the power wires no the amp will be ran the same with the exception of the remote turn on wire. +12v constant will still go to the battery(properly fused with 12" of the battery!), and the ground will still go to the chassis. You can hook the remote turn on to the +12v ignition wire behind the radio, or the equivilent fuse in the fuse box. I would not recomend hooking it up to the pwr ant wire on the stock deck as it often goes off when the radio is off, or cd is playing.
As I said, most cars have no issues with any of this, but cars with "PREMIUM SOUND" systems often do not mesh well with aftermarket equipment. Fords JBL or chrystlers infinity (And bose in darn near anything!) are often cause issues. Sometimes you can easily bypass this system(Ford), sometimes you have little choice but to rip it all out and start fresh(Bose). I can walk you through the scenarios for most makes and models, but certainly do not have the time or patience to give every one. Hit me up on the forum and I will be happy to help you further....
Jan 03, 2009 | Jensen LXA300 Car Audio Amplifier
Trying to hook up amplifier to after market 6by 9 using factory radio
You can not connect the speaker lines directly to the RCA inputs of your amplifier. But you can connect them to your amplifier if your amp has a high level input. Most of the time it looks just like the speaker jacks of the amp, but smaller. It will be labeled high level input or speaker input. Sometimes an amplifier will have a jack for a wiring harness just for this purpose. Some amplifiers have them and some don't.
If your amplifier does not have them, you can purchase a line level adapter at most anyplace that installs car stereos. it converts the speaker level to the proper level of the RCA input.
Just follow the instructions on how to connect it.
If you try to connect the speaker outputs directly to the RCA input of the amplifier you will blow up the pre-amp in your amplifier.
I hope this was helpful to you, if so a good rating is always appreciated.
Thanks and let me know if you need more help.
Jun 20, 2008 | Car Audio & Video
Car amp high input pinout
With a 4-pin connector - from left, facing the side of amp with RCAs and high level input:
Left speaker + input, Left speaker - input, right speaker - input, right speaker + input
With 5-pin connector - same as above, except center pin goes to ground and 2 right side pins are for right speaker.
Feb 15, 2008 | Audiovox AMP522A Car Audio Amplifier
No place for amp to go in headunit
use an amplifier that has a high level input so that you can connect directly from the speaker out of your head unit of you car.Mannx246@yahoo.com
Jan 06, 2008 | Audio Players & Recorders
Factory stero to amp
If the amplifier has inputs for a high level signal, you unhook the wires going into the speaker and plug them into the amp, then hook the outputs up to the speakers. If the amp only has rca inputs, you need to also buy a line level converter. Then you unhook the speakers, hook the wires up the the converter, then hook the converter up to the amp, then hook the amp up to the speakers.
Please leave good feedback!
Dec 08, 2007 | Blaupunkt PCA250 Car Audio Amplifier
OEM gm stereo
If your amplifier has what they call High level inputs (basically inputs on the amp that you run the speaker wires from your radio into), you can splice wires from where the connectors are on your rear speaker(s), still leaving the speaker hooked up, and use those as an input into the amp. If your amplifier does not have high level inputs, a convertor is available to turn an audio signal from your radio output speaker wires ( spliced in just as above, leaving the speaker hooked up), into an rca output jack. Or the best thing to do would be to buy another say 2-4 channel amp w/high level inputs and rca inputs and outputs, and run your rear speaker wires into the amp. Then you'll be able to run the rca cables out of that amp and into the sub amp, and you'll have the new amp to power your rear speakers or rears and fronts. That would be ideal. But, A convertor is your best bet. Got em at best buy, circuit city, etc. Hope this was helpful.
Nov 25, 2007 | Car Audio & Video
Car Audio & Video Logo
48 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
