Question about Toshiba Satellite A505-S6970 Notebook
How do I setup audio input on a toshiba satellite labtop
IS audio input built in or do I neeed to add some hardware?
  • Toshiba Master
  • 7,627 Answers
What audio inputs? On a laptop, hardware wise, your input are pretty much fixed.
Posted on Jan 16, 2013
2 Suggested Answers
  • 289 Answers
SOURCE: unable to locate audio and voice inputs on toshiba
they should be in the front of the laptop (not where the plugs are, opposite side) if windows won't show them up then its a different story, your missing drivers.
Posted on Sep 27, 2009
Labtop freezing often and shutting down
Actually your make and model of satellite was the worst of toshiba's recent production- the estimate was 16-18% have displayed what's called an intermitten i/o failure to the main board. (Input output of processing data to the mother or logic board that processes the overall functioning of the comp~ the brain of the comp). This has plagued Toshiba's production for the last 3-5 years, and 9-18% of units have been affected. The good news is: it's neither a logic board nor electrical failure! And the repair is both easy, a DYI repair for any novice, and super inexpensive (well in the grand scheme of comps). What will fix your laptop is new RAM. Your toshiba can seat up to 8gs and as little as 4g. It uses DDR3 RAM, paired. The ram sits in the main board and over sees the i/o of data, is a main part of the EFI (the firmware interface of your hardware), and is in charge of ensuring the electrical assembly circuit is complete. Cost of parts on Amazon (spring for new RAM) will run you $50-65, the repair is 3 screws, pop out old ram, pop in new, replace panel, screw back in 3 screws. It's the easiest possible repair you can do yourself, even listed in the owners manual. See links below. 1st is your ownwers manual, 2nd is to ifixit.com to your laptops ram replacement guide. I'm an A+ PC repair tech and an ACMT apple repair tech. I rarely recommend DIY, but this is cake. If you boot after and see 3 blinking lights, you didn't put the ram all the way in. good luck! Next time, buy a toshiba TV, but not a laptop.... :) http://www.manualowl.com/m/Toshiba/Satellite-L655-S5150/Manual/281632 http://www.ifixit.com/Guide/Installing+Toshiba+Satellite+M305D-S4829+Memory+%28RAM%29/5424/1
Mar 01, 2013 | Toshiba Satellite L655-S5107...
Toshiba a105 on start up screen is red, then goes black
The Toshiba A105 notebook computer is made for mobile computer users who need optimal processing power. The LCD screen is a 15.4 diagonal widescreen with TruBright technology. The laptop has a fast hard drive access rate that is in the 3ms range for the paging and access of data. There are problems that can occur with the Satellite A105 that can be solved by knowing what to look for when troubleshooting the system.
Black Screen Problem Black screen problems can occur when the Satellite A105 backlight is burned out or the inverter is not working correctly. The backlight can be replaced with a new LCD bulb manufactured for LCD screens. The inverter is a housing unit that controls the voltage to the LCD screen. The inverter must be replaced by a compatible A105 Satellite inverter unit. Power Problems b> During the power-up phase of the laptop, the Satellite A105 will quickly turn off without signing into the Windows Operating Screen. The problem can be due to a faulty power adapter that is not supplying the right amount of voltage to the system board. You can also check to see if the unit that houses the power plug is loose, which also indicates lack of voltage or electricity going to the board for power up operations. Hardware Conflict Problems b> Hardware conflicts can cause system errors or "freezes" by loading a new hardware component into the same hardware I/O address. The Satellite A105 has designated input/output addresses for peripheral devices, such as hard drives, video drivers and other hardware functions. To solve hardware conflicts, use the Control Panel "Hardware" device function to see which hardware I/O addresses is not being used. b> Audio Not Working Correctly b> Loading a new audio program can cause the audio codec for the Satellite A105 not to produce sound. The audio codec can be restored by loading the "restore system disk" for the A105 laptop. The restore menu provides options on certain components that you want to restore. If you pick the option for audio, the program will restore the audio to its factory settings. b> On-board LAN Switch Not Working b> The Satellite A105 is automatically configured to detect T Base 10/100 Ethernet networks. If the laptop does not recognize the on-board LAN switch, check the system setup to examine if the LAN switch is on. If so, a firmware update may be needed to upgrade the BIOS.
Jan 16, 2013 | Toshiba Satellite A105-S4334 Notebook
After trying to plug in headphones (in the headphone socket) I have lost all sound on my Toshiba satallite 2040 (Idid have sounds from built in speakers before hand) can you help
Hi
You have not mentioned which operating system you are using.
You might have changed the defaul audio settings.
Vista/Windows 7: Start > Cxontrol Panel > Sounds & Audio Devices > Hardware & Sound > Manage Audio Devices > highlight the external speakers from the list of devices > Set Default > Apply > OK > Restart computer.
Win XP: Start > Cxontrol Panel > Sounds Speech & Audio Devices > Hardware & Sound > Change the Speaker Settings > Advanced > Speaker Setup - select Internal Stereo Speakers > Apply > OK > Restart computer.
I hope this helps.
Aug 27, 2011 | Toshiba Satellite 2450-401 Notebook
It says...no audio hardware installled...what do i need to do..
The PC might not recognize any driver for the audio hardware that is most likely built into the motherboard of your laptop.
You should Google audio drivers for your laptop
This website might help you
http://www.gzrcw.net/drivers/toshiba/Satellite/drivers_1135.html
Hope this helps you : )
Dec 30, 2010 | Toshiba Satellite M45-S265 Notebook
Im having trouble with my labtop, i have done all the updateds, and still i am unable to hear any sound coming from the labtop, i think it is a driver or controller problem, can you please help this is...
Please confirm make and model of operating system. If it is XP, then it is worth removing the hardware and restarting. You do this from Start,Control Panel , Add hardware.
Tell me if this helps.Then reboot and it should start by detecting the hardware and finding the droivers which you have.
Jan 09, 2009 | Toshiba (P000352520) Sound Card
Toshiba audio failure
Check for any hardware conflicts. If there are none then the 3.5mm stereo jack for audio out may be damaged - it has internal switches to turn off the speakers when headphones are used.
Mar 16, 2008 | Toshiba Satellite P105-S6104 Notebook
Toshiba Satellite A505-S6970 Notebook Logo
78 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
