Question about Ovens
Remove glass on HJA 4620 OVEN
HOW DO WE REMOVE GLASS TO CLEAN OVEN. hAVE SPADE AND MANUAL BUT CANT WORK IT OUT.
  • 163 Answers
SOURCE: Cleaning the inside of the glass on the oven door
dont try you will broke something and then gonna think that was better to have a little dirt in there, a tech could do but whats if it comes again....good luck if you insist post back
Posted on Aug 08, 2006
  • 17 Answers
SOURCE: Whirlpool double oven - model RBD305PD82
Please take a look at the diagram if you think you want to do that.
if you still want to do it and need more details to disassemble feel free to email me. nguyen@ite.net
Posted on Jun 09, 2009
SOURCE: HJA 3300 Diplomat Oven Door Issue
my inner glass door exploded while cooking at 200 degrees.
Posted on Feb 08, 2010
TheMobilian
  • 8220 Answers
SOURCE: How do you remove the glass front of the oven door
See page 34
Posted on Nov 20, 2010
  • 4 Answers
SOURCE: cleaning glass in oven door
Extend your door hinges and remove entirely over to a table or other flat surface where you can do a step-by-step dis-assembly. Begin by removing the bolts at the bottom of the door, then the main panel and side flanges can be removed. The glass slides out from the tabs and you can give it a good cleaning at this point. Reverse your order to re-assemble, and put your door back on the oven. It's not as bad an exercise as it would appear. Just take your time and watch what you're doing. I used the hinges as a shim, and had it laid out on a pool table for easy, elevated examination.
Posted on Jan 02, 2011
Testimonial: "Thanks for the advice and it worked like a charm, like you said make sure that you take your time and it works TX "
How to remove glass on oven door for cleaning,zanussi instruction manuals
Oven door glass is not designed to be removable for cleaning.
Jul 19, 2014 | Zanussi Ovens
How do I take the glass out my oven door model AP578X-8
Hi, I have pasted the instructions for your Smeg oven you below:
9.4 Removing the internal glass panels
The glass in the door should always be kept thoroughly clean. To facilitate
cleaning, it is possible to remove the door (see 9.2 Removing the door) and
place it on a canvas, or open it and lock the hinges in order to extract the glass
panels.
The glass panels of the door can be completely removed by following the
instructions provided below.
Warning: before removing the glass panels, make sure that at least one of the
door's hinges has been locked in the open position as described in "9.2
Removing the door". This operation may have to be repeated during the glass
removal process if the door is accidentally freed.
Removing the internal glass panel:
• Remove the internal glass panel by
pulling it upwards, following the
movement indicated by the arrows. Doing
this detaches the 4 pins attached to the
glass from their slots in the oven door.
Removing the intermediate glass panels
(on some models only):
• Some multifunction models have an
intermediate glass panel. Remove the
intermediate panel by lifting it upwards.
Cleaning:
• It is now possible to clean the external
glass panel and the panels removed
previously. Use absorbent kitchen roll. In
the case of stubborn dirt, wash with a
damp sponge and neutral detergent.
Replacing the glass panels:
• Replace the panels in the reverse of the
order in which they were removed.
• Reposition the internal glass panel, taking
care to centre and insert the 4 pins
attached to the glass into their slots in the
oven door by applying slight pressure.
You can go to the website for further information: http://www.u-manual.com/download-manual-now-for-free-10/210209/oven-smeg-ap578x-8.html#.UumokD2Sxvg
Jan 29, 2014 | Smeg Ovens
Model HJA 3220 removal of internal glass panel
i have the manual if any one needs it... can't upload it here but email me if you want... faisal at citydealestates dot com - no spaces. covers HJA3220 HJA3320 and HJA3212
Feb 18, 2012 | Ovens
How do you reset the clock on a Diplomat HJA 3300 oven? Would you by any chance have a pdf of the manual?
Press and hold the timer and casserole symbol buttons at the same time then press or - to set the time. If "auto" flashes you will have to cancel that programme.
Feb 25, 2011 | Ovens
I took the wires off the clock/timer to clean the glass because junk got behind it. When I put it all together the clock/timer does not work. It may be that I have two wires crossed. I need a wiring...
I think I worked it out. Black = Neutral. Brown = Live for the two power spades. The four spades for the timer (from the top+ = Red, Orange, Brown then white on the bottom. You will notice that Red and Orange, Brown and White are clipped together. Timer (and oven) is now working perfectly.
Jan 01, 2011 | Ovens
Aug 17, 2009 | Ovens
Food behind the glass front
upper oven will not heat after going thru cleaning cycle
Jan 18, 2008 | KitchenAid KEBC208 Electric Double Oven
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
Ovens Logo
52 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
