Question about Samsung LN Televison & Video
Does a samsung model No. LN46A530PIFXZC need an HD box
Version AA02
Can you help me repair my Samsung Curved UN65KS850??
According to shopjimmy this kit is supposed to fix it...here is the URL https://www.shopjimmy.com/samsung-un65ks850dfxza-version-aa02-complete-tv-repair-parts-kit.htm ..there are 2 different versions for that set, be sure you get the right one
Oct 30, 2017 | Samsung Televison & Video
How do i tune my SAMSUNG PS42S5H for high definition channels
Does this model of TV have a built in HD receiver? I've had a quick look at the instruction manual and it looks more or less the same as mine at home. I've not got HD tv reception built in but have to use a set top box. If you're in UK, it should have Freeview HD sticker from the box or manual somewhere but as this looks like an early model tv (only 1 HDMI socket) then you may need a HD set top box such as Sky HD or Freeview HD
Oct 15, 2014 | Televison & Video
Where is power button?
Not even by pressing the power switch on the front panel?
Mar 30, 2014 | Samsung P560 AA01 P560 AA02 P560 AA03"...
Samsung tv flicker
1. Weak florescent tubes;
2. Defective power supply (inverter)
Jan 13, 2018 | Samsung Televison & Video
My Sky HD box will not change channel or do anything with remote and buttons on box. To get it to work you have to turn off for a while and turn on but then it happens again. Sky hd box Modle 1.4.300...
Mines doing the same, started this morning [19-09-2010] I wonder whether there has been a firmware update that has caused this, I suppose its going to end up with multiple calls to Sky which will result in a new Sky Box :(
Sep 19, 2010 | Samsung Televison & Video
I have HCL5515W tv. Want to convert to HD tv.
Not without the box, HDTV didnt really made an appearance except in the past 5 years
Jan 18, 2009 | Samsung HCL5515W 55" Rear Projection...
What do I need to get for viewing HDTV
The TV you have will only process an HD via the component video connections. Your cable box needs to have component outputs and you will need to buy a component video cable to connect from the cable box component video outputs to the TV's component video inputs (should be 2 sets, #1 for up to 720p and #2 for up to 1080i...
Oct 28, 2008 | Samsung PCL5415R TV
I have a Samsung LCD TV - model LN-3251D. My local cable company offers HD channels over the air; however, I canot seem to get them. How do I receive these channles?
You will need a cable box with an HDMI or S-video connection from the box to the TV in order to receive actual HD signals.
Sep 06, 2008 | Samsung Televison & Video
Televison & Video Logo
Henry  Thomas
Henry Thomas
