Question about Epson Stylus Nx420 All-in-one Color Inkjet Printer
Ghosting After clearing a nasty paper jam my printer began ghost printing. Epson Support suggested cleaning the head at least 4 times. Have done more than that and it is still ghosting. SOS.
  • 4102 Answers
SOURCE: epson stylus color 760 failing to print.
you can take it to repair shop and they will clean the head for you with some cleaning fluid if it has been without ink for a while sometimes these get blocked but it is not worth replacing cus would cost more than the printer as the ink cartridge you brought was originall then this isnt the problem check all cables if not better off buying new printer as these are not made to last long sorry couldnt be any,more help...........................
Posted on Nov 05, 2007
  • 90 Answers
SOURCE: My EPSON Aculaser C3000 is ghosting
Could be any of the following:
* Bad toner - try a different toner
* Unsuitable paper - try a different paper
* wrong software drivers - download the latest drivers for your operating system from the manufacturer's site.
Posted on Jan 04, 2008
Soulvisitor
  • 1113 Answers
SOURCE: epson printer had paper jam which is now clear but
Some paper is probbally lodged btween head and printer wall, off with the power, can you then pull head to right and seek for paper fragments smashed aginst inside wall? then if all is well may need to run a clean, you should be right...
Posted on Nov 03, 2009
  • 420 Answers
SOURCE: My Epson R2400 appears to have given up the ghost.
the problems are :-
  • cartridges are not recognised or installed
  • there is a paper jam.
Posted on Sep 18, 2010
  • 10 Answers
SOURCE: Hi. Epson C3000 aculaser.
Hi Colin.
I just have had the same problem with my Aculaser C4200.
I may have found a way to solve you problem.
Just print 10 blank (without anything), and after that i took all toner's, the fuser etc. and put it back again. Printed 10 more blank pages, and printed over 200 pages with lot of tekst and colour (think that 50 pages could do it).
After 2 days everything is still ok for me.
Posted on Oct 07, 2010
Print not clear, double struck, cartridges are new and sometimes paper jams
Paper Does Not Feed Correctly - Epson
https://files.support.epson.com/htmldocs/pho22_/.../trble_4.htm
EpsonPaper does not feed correctly when using the double-sided printing feature. If one of the ... The ink cartridges are not empty. ... If the error does not clear, open the printer cover and remove all of the paper inside, including any torn pieces. Then ... If yourpaper jams frequently, make sure of the following: ... Load a new stack.
Epson Stylus COLOR 600, Top FAQs - Technical Support ...
www.epson.com/cgi-bin/Store/support/supDetail.jsp?...FAQs...
EpsonThis link provides access to Top FAQs for the Epson Stylus COLOR 600. ... I just replaced an ink cartridge and the printer still won't print correctly. ... [ Answer ]; The printer is not producing any black or color ink. ... [ Answer ]; I'm only getting partial printouts or a "paper out" or "printer off line" error appears. ... How do I clear this?
epson printer problems ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/23851
I loaded a new black ink cartridge into my Epson Stylus C86. .... hit this problem when we first bought it, apparently it needs all colours to print ... i am using Epeon L 110 printer The colour print was good before But now the colour print is not clear ... No paper jams (sometimes paper feeds sometimes it doesn't). it appears that ...
Jan 05, 2016 | Epson Stylus NX420 Inkjet Multifunction...
Ghosting
Normally ghosting is caused by a bad fuser.
Put paper in the manual feed tray(tray 1)
Print something. As the paper gets 1/2 way into the printer, open the cover..
Look at the paper. If there is no ghosting, the fuser is bad. If there is ghosting, could be a cartridge drum.
Follow these steps print a Print quality troubleshooting page to identify which print cartridge is causing the issue.
  1. Open Toolbox .
  2. Click the Help folder, and then click the Troubleshooting page.
  3. Click Print , to print the page. The page prints five bands of color, which are divided into four overlapping sections. By examining each section, you can isolate the problem to a particular print cartridge. Figure 4: Print quality troubleshooting page bandsc01417618.gif 1 - Yellow 2 - Cyan 3 - Black 4 - Magenta
May 01, 2011 | HP LaserJet CP1215 Color Printer
Black marks on the printing
You could have a build up of ink on your rollers, and as the paper is pushed through it is leaving marks. It could also be causing your ghosting effect or double lines. By having your printer cleaned by a certified technician it should reslove your issue.
Jun 09, 2010 | Epson Stylus Photo 1290 InkJet Printer
Ghosting on HP2015 Printer
Hi gpeirce:
Ghosting is the result of a worn fuser assembly. Try to print a half page by printing a document and then try to open the top while the paper is going under the toner cartridge. You have to listen to the paper moving through the paper path.You will see that the paper has print on it but not the hole document. This will tell you if the toner cartridge is bad or the fuser assembly.
Hope this helps
May 30, 2009 | HP LaserJet P2015dn Printer
Ghosting on my laser printer
You just need to run more print outs to clear the ghosting.
Apr 10, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
Epson R320 "General Error" message - unable to clear
If you are getting a 'carriage jam' error as soon as you turn on your Epson printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t5192341-epson_photo_1400_paper_feed_ink
Feb 22, 2009 | Epson Stylus Photo R320 InkJet Printer
Epson CX7450 paper jammed
In some cases, this is cause by a nozzle that got clogged during the jam. You can run head cleaning utility either from the printer or from the computer.
1. Make sure that there are no error lights (red lights), just a solid green light.
2. Take out all cartridges from the printer and put them back in.
3. Once the printer is done charging the inks and you have a solid green light again. Hold down the Ink Button for 3 seconds, after this you'll hear movements within the printer, this is the head cleaning process.
4. Once the printer stops making noises, and you have a solid green light again. Power Off the printer
5. Once the unit is OFF, hold down the paper button while turning the printer ON. Once you see the blinking green light release BOTH buttons. The printer will then print the nozzle check pattern.
* Note: The nozzle check pattern should display all colors in the printer and there should be no gap or break between the lines itself.
6. Do this step 3-4 consecutive times. and that should resolve you concern
Feb 21, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Jan 04, 2008 | Epson AcuLaser C3000 Printer
Epson Stylus Nx420 All-in-one Color Inkjet Printer Logo
21 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
