Question about ViewSonic VA1912w 19" LCD Monitor
I required alternative of NCP1203D60R2(DAP 8A) Ic which is used in Power Supply board Delta DAC-19M005 AF.......Rev. 02A in my ViewSonic monitor.
Hello friends,the required part which is NCP1203D60R2(DAP 8A) is not available in India or the DELTA DAC-19M005 AF Rev.02A power board.so plz tell me which IC, I can use instead(Alternatively). Plz Help it's very very urgent.
    Problem Solver:
  • 4 Answers
Http://archive.espec.ws/files/DELTA%20DAC-19M005%20(DAP08+BIT3713).pdf
Posted on Jan 28, 2014
2 Suggested Answers
  • 1684 Answers
SOURCE: hello viewsonic vx2235wm no power
The Viewsonic VX2235WM has a known issue with the power supply going out. The flashing power light or not turning on is the classic symptoms of this issue. Check out our web site at: www.ccl-la.com. We have a step by step repair guide posted that will guide to doing the repair yourself. It involves changing a few capacitors on the power supply. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $35 plus return shipping. If you have any additional questions just let us know at: tech@ccl-la.com
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jan 03, 2010
Compatable IC required for DAP 8A
http://www.abnet.am/images/Viewsonic_va1912w.pdf
Jan 11, 2013 | Computers & Internet
What Dac board do i need for Acer P235H 23
The power supply board is the Acer P235H is not made by Delta Electronics so it is not a DAC board. The power supply board is this model is a ilpi-129 and looks like this:
I hope this helps.
Mar 27, 2012 | Acer Computers & Internet
Hello,I am currently using a Viewsonic VX2235 monitor. When I turn on the PC the monitor stays black and it takes turning the monitor on and off several times to get it to work. Would greatly appreciate...
The problem you are having is caused by a power supply board that is starting to fail. Parts called capacitors start to fail and the power supply does not start up as it should and requires power cycling to get it going. Most VX2235 units use the DAC-19M010 power board. Here is a link that shows how to repair the board by replacing the bad capacitors.
http://www.ccl-la.com/blog/index.php/repairing-the-acer-al2216w-lcd-monitor/
I hope this helps, if so please rate my solution.
BuddyMc
Sep 18, 2011 | ViewSonic VX2235wm LCD Monitor
The screen goes on for a second and then turns off. If I then turn the power on and off numerous times it eventually stays on. I put the screen off to 60 minutes. Every time the screen is allowed to turn...
Hello Geoff,
The problem you are having is caused by a power supply board that is failing. Your monitor uses the Delta DAC-12M033 power supply board. We have a repair guide for the Westinghouse LCM-20V5 monitor that uses the same power supply board posted o our web site at: http://www.ccl-la.com/blog/index.php/repairing-the-westinghouse-lcm-20v5/ Check out the web article, it should get you back going again. If you don't want to do the repair yourself we do offer a repair service. We can get deatils on this service here: http://www.ccl-la.com/blog/index.php/service-request-form/
CCL Tech
Corporate Computer
www.ccl-la.com
Oct 26, 2010 | ViewSonic VG2021m LCD Monitor
Hello, I ordered a Viewsonic VG2021m monitor a while ago, and recently, the monitor shows nothing but black when plugged in. All cables on it have been checked, and my computer acknowledges it is there,...
This is 2006 model year, more likely to have bad caps problem in the power supply, look for caps with leaking/bulging tops first, also look to see if you do have 12~18vdc feeding the inverter circuits.
This your power supply/backlight inverter board:
http://www.shopjimmy.com/power-supply-unit-dac-12m033-af-from-viewsonic-vg2021m.htm
Learn about bad caps and failed monitors here:
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 09, 2010 | ViewSonic VG2021m LCD Monitor
Display is blank and the status light blinks Info:
The problem can be occurred due to low voltage the adapter may be defective please confirm that the adapter is ok.
Jan 29, 2010 | ViewSonic VG2021m LCD Monitor
ACER Al 1916W Asd service manual
dac-19m005 power light comes on then goes off
Jan 08, 2010 | Acer Computers & Internet
I have a bad power inverter board for westinghouse L1975NW, not caps but board failure. Need to replace but cant find DELTA DAC-19M005 AF rev: 00A but i can find a 19M005 BF, not sure if they would be...
We do board level repair on LCD monitors so we should be able to repair your board. We also have the board in stock for sale with exchange. Contact us at tech@ccl-la.com or 318-447-9040
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 29, 2009 | Westinghouse L1975NW Monitor
No backlight. I'm looking for a schematic for the acer al1916w with power/inverter board dac-19m0005 rev: 01a bf.
<p>How about the whole <A href = "http://www.go-gddq.com/upload/2009_06/09060313346662.pdf">Service Manual</a> ?</p?
Jun 14, 2009 | Acer AL1916W 19" LCD Monitor
Hello viewsonic vx2235wm no power
this instructable might help http://www.instructables.com/id/How-to-repair-a-Westinghouse-L1975NW-19quot-LCD-/
the dac 19m009 is supposed to simular to the dac 19m005, which is repaired in the instructable.
Apr 28, 2008 | ViewSonic VX2235wm LCD Monitor
ViewSonic VA1912w 19" LCD Monitor Logo
128 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
