Question about Electronics - Others
What unit of measurement is inductance measured in?
    New Friend:
  • 152 Answers
Inductance is measured in Henry, usually just written as H
Posted on Jan 15, 2013
What should we do when the induction cooker appear E0?
Are you searching forInduction Cook-toperror codes? Here youcan find the error codesof all popular inductioncooktops and how totroubleshoot it. Theseare for your referenceonly, do not try to open your cooktop withoutproper safety measures, we advise you to call theservice person if any servicing is needed.
Error codes like E2, E0, E9, as we see in famous induction cookers like Pigeon, Prestige, Butterfly etc. are annoying at times, when we are in a hurry to go to office. Errors appear as numbers and finding it from the user manual will take days and leave us impatient. Here is a handy guide of induction cooker error codes usually seen in branded and un-branded induction cookers. You may save this page as pdf or as it is in your phone or PC for quick reference.
E0 -Cooking vessel is not placed correctly. Vessel is either removed or not made of a material usable with induction cooker.
Feb 03, 2017 | The Kitchen Appliances - Others
My grinder makita 9017,what was procedure before changing aremature? My aremature new ,what is further check up on capacitors?
For every machine if it is not working begin measure on the power cable if its not defect measure the carbon brushes to each other over the commutator of the armature (maybe only the auto-stop inside the brushes is activated ) when the brushes become to short there comes a little spring from inside the brush out to protect. measure the 2 or 4 electric field contacts to measure the 2 coils if that's good then measure the switch the capacitors ? no that is only on some machines called feedthrough capacitors like the brand FLEX has on its grinders , but Makita have i not seen in 20 years the capacitors in machines with brushes ( not induction motors) for only radio interference suppression you can without problems remove them it has nothing to do in function. switch and electronic can be defect this model 9017 is not common in my country but every machine has the same principle.
Oct 27, 2015 | Makita Saws
Hob ceran replace with new induction hob
Need looking at by NEFF , a big job .
Mar 16, 2015 | Neff Cooktops
300g of cornflour = how many cups
See this site for convertor:
Cornflour maize cornstarch converter Convert to units and culinary measures
It's 2 cups.
This is not a direct conversion, but rather an empirical measure resulting from tests.
Grams is a weight measure and cups is a volume measure - clearly there can be no direct conversion.
300 grams of steel is far far less than 2 cups and conversely, 2 cups of steel is much more than 300 grams.
Feb 28, 2015 | Kitchen Appliances - Others
Got a LG ducted air conditioner coming up with error code ch26 tested winding all reading 1.6ohms is that normal on a inverter system
Do you mean it is powered by an inverter or is it a 12VDC unit for an RV?
If it operates from 12V, the motor and compressor will measure quite low using only a resistance meter.
For one thing, your meter leads will introduce 0.4-0.6 Ohms of resistance. Short the meter leads together to see this.
Any device using a motor or transformer (as in an inverter) and 12 volts will measure low resistance since the major portion of its 'resistance' is determined by the inductance of the windings and a normal meter cannot measure this.
Nov 25, 2014 | Heating & Cooling
What is a unit
In which context? Vitamins and some drugs are measured in units. Trailers are counted in units and so are houses and apartments. Units of measure are also used to look at the earth and components on it. A unit is also a way of saying that you have 1 of something - like 1 cm or 1 mm.
May 27, 2014 | Measuring Tools & Sensors
Miele Fault Code FE 30
I have the same FE 30 problem on my KM5733 Induction cooktop whenever it's circuit breaker/isolation switch (in my house's fuse box) has been turned off and then on again. I have turned in back on after waiting a day or longer (figuring it needed to reset itself?) and the results have been hit and miss and I have had no idea why it would work sometimes and not others. Needless to say, I've trolled the net looking for answers and Miele online support is useless (unless you're ok with shelling out loads of cash to have a technician come by) and I still haven't heard back from them after lodging an enquiry.
What I have discovered from this and other forums is that these units do not like being attached to a power source which has a voltage significantly above the amount stipulated in its specifications (for my unit it's 230 Volts). After reading this I used a voltage meter to measure the voltage in one of the power outlets in my house (I have a really cheap meter I'd bought a while ago at an electronics retailer). Sure enough it was above 260 Volts which is totally beyond the range it's supposed to be for where I'm living.
The thing is, I know the unit works just fine provided it has been turned on and it doesn't get the initial FE 30 error (it's almost like you have to get past an initial voltage check and then once it's going everything is ok). If the voltage is at an "acceptable" (whatever that may be) level when it's turned on, it will turn on and then stay on even if the voltage goes up afterwards (which it obviously has done during the time from when it was last switched on until recently).
How did I get it to work this time? well I thought of ways to reduce the voltage to the unit and came across all sorts of stuff on the net including powerbox voltage reducers, optimisers, blah, blah... I thought this is total rubbish and I'm going to ring the power company and complain about the voltage being so high when it's not supposed to be. I then thought back to my old high school physics days and remembered that there's a relationship between voltage, current and resistance. I then thought the voltage to the induction cooktop (as well as to all the other power outlets/circuits in the house) is likely to drop if I plug in and turned on a lot of high resistance electrical appliances.
Sure enough, when I turned on the kettle, toaster, clothes dryer, computers, televisions, electric oil heaters, lights and dishwasher, the voltage in the power outlet I'd been measuring went down from 260 to 235 volts.
I then turned on the power to the induction top back on and it turned on and with no FE 30 error!
I boiled some water to make sure everything was working ok (it was) and then I turned off the induction top and all of the other devices I'd switched on.
Still no FE 30 error! Great.
I double checked the unit by turning it back on and boiling water again and it did it with no problems. I then turned the unit off and measured the voltage in the power outlet again and sure enough it was back at 260 Volts. Hurray!
I'm now going to ring the power company and make a complaint...
Mar 22, 2013 | Cooktops
Actually I have 6681, 600w; want to use to regulate 80w soldering iron. Why can I not measure resistance across new switch, before installing? If it is inductive, how can I measure to know it will work? ...
The dimmer isn't a straight resistor, its an R-C timing circuit, and the caps within that circuit are going to mess up any resistance measurement you're trying to make. The R-C circuit is there as a timing mechanism to determinine the duty cycle on/off time of the dimmer. It is because of that, that I recommend you try to not use a light-dimmer for a soldering iron - the dimmers are not resistive rheostats, they're light switches (on and off @ 120-times a second). Depending upon the nature of the soldering iron, that may cause some harmful problems.
Aug 28, 2010 | Leviton Electrical Supplies
Electronics - Others Logo
603 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
