Question about Kodak EasyShare DX6490 Digital Camera
Broken joystick Joystick appears loose, cannot perform functions on any movemnets up, down, left or right
    Genius:
  • Kodak Master
  • 1,019 Answers
Hello,This is a major problem with this series Kodak camera, as they age the switch either stops working or just falls apart !! The cost to repair would exceed the cost of a newer camera on E-Bay, I would stay away from this style control unless camera is new. Hope this helps.
Russ
Posted on Jan 23, 2013
SOURCE: joystick
While trying to fix this problem today I discovered something that seems to help, at least in my case. If I push down on the small button located below the joystick/onoff button, while also tapping the OK button, the camera responds to the OK. (This is the display/info button.) I'm not sure why this works or whether it would help in every case, but it would be worth a try. I've been able to finally set my date and make other changes necessary after recharging my battery.
Posted on Mar 11, 2008
SOURCE: menu wheel and joystick
took back of camera off 6 screws, and found wheel had skipped ofer plastic range limeters. took small screwdriver and popped them over limeters wile twisting. wheel works now but joystick does not work. also wheel spins but functions do not work.
Posted on May 06, 2008
SOURCE: my joystick only work up down and right
I had the same problem. I took my Z760 apart and put in a joystick from a used Z760. But the problem is that the joystick comes unglued from the small computer board. Take it apart and put a tiny drop of superglue on the joystick. Use a magnifier to line up the two little tabs in the proper holes. It should work fine.
Posted on Aug 03, 2008
gemmy23
  • 346 Answers
SOURCE: joystick blinks orange light
It sounds like it could be a couple of different things but it will be hard to tell without having the camera right in my hands. First you might want to check to see if you have a SD card in the cmaera. The internal memory may be full of your images and there is no room for anymore. If you have a sd card already in the camera then make sure it is not over 2gb. That model will only accomodate a 2gb card and nothing more.
Hope this helps
Posted on Jun 26, 2009
shockwave727
  • 262 Answers
SOURCE: Camera works fine other than the joystick. I
It means that the joysctick of camera is defective., Please call Precision camera and binocular repair to send the camera for service Its for US support 1 800 665 6515 or you may call kodak 1 800 235 6325 for an alternative options and solutions., Gudluck!
Posted on Nov 03, 2009
Nutron r51
The age of the Nutron is not the issue, unfortunately. I have seen problems with this model right out of the box. The joystick control is the first area to check. If you have to compensate the joystick so far to the right to correct, you may have a damaged joystick gimbal. You may also have a bad joystick control board or damaged connecting cable to the controller on the bottom frame. Check for damaged, pinched loose or disconnected wiring below at the controller module. With a folding frame it is easy for the wiring to be become damaged or dislodged. Check for cut damaged pinched wiring at the joystick. With a handheld programmer (dealer) you can check for error codes in the fault log. With a poor performance issue there may not be a fault recorded in the log of the computer module. I have also seen these motors fail prematurely. In this case your left motor is dragging or weak causing the chair to go left. With a programmer (dealer tool) you can compensate for this while waiting for new parts(temp fix). Sometimes the motor brushes burn or hang up. Try blocking up the chair off the ground and run it no load to check for motor performance and unusual sounds. Check for joystick dead spots or uneven action. A quick check of the joystick would be to plug in a known good one at the dealer to test. With the chair blocked up try tapping the motor housing to see if the performance changes. Inspect the brushes if you have access to the brush caps.Check the obvious first, plugs, pinched, broken wires and partial plug disconnects and corrosion. If you have a voltmeter you can do some checks on the motors and brakes. Going from memory, the motor leads large black and large red should read zero ohms with the 2 small white wires for the brake reading between 60 and 70 ohms. Check the Invacare manufacturer website for exact specs and technical info for this model.
Hope this helps.
Mar 22, 2014 | Invacare Supply Group Nutron R51 LXP...
My computer is unresponsive to the joystick; I plugged it into the usb port a message confirmed it was installed and ready for use but nothing happens when I move the joystick in a flight simulator or...
Hello, Here's the solution to your problem, you have to configure the games you're playing for the joystick to work, I believe all games have this option, ussualy in the "configure keyboard and mouse" options menu, click on any funcion you want your joystick to use for each button, and then press the button you want for that function, do that with all buttons of the joystick you want to use, some games need the joystick axis to be configured, just click on left/right and move your joystick in the desired direction, same procedure to up/down, if your joystick has a throttle wheel, do the same for it (if needed).
Procedure is simple and most games has small variants of this procedures I gave you, but they are simple to figure out.
Hope my solution helps, have a nice day :)
Apr 14, 2011 | Trust Predator TH 400 (12629) Joystick
Damages joy stick, cannot move up, down, left and right
Most of the time joystick problem can be corrected by :-
-put some servicing liquid like petrol on joystick area and move your joystick up dpwn left right
then dry your board .
- most of the time this problem will be solved by this process. if not then change your joystick
Oct 20, 2010 | Sony Ericsson K700
Etrex legend joystick problems
could be the hardware switch itself
Oct 05, 2017 | Garmin eTrex Legend GPS Receiver
Z525a screen comes on but stays vacant.
If you have access to a laptop computer that has an Infrared Port or Bluetooth communications, you can download your videos and picture files via either of these two methods. I use an old IBM Thinkpad 600 with IR port to download mine. You have to put your z525 phone into Infrared mode first, its kind of tricky with out seeing what you are doing. First, open your phone, press upper right (-) sign to get menu, click joystick control down 2 times then right 1 time. next press upper left (-) sign to select. next joystick right 4 times, and down 1 time. press upper left (-) sign, then joystick up 1 time. press upper left (-) 1 time. Your Infrared Port will now be turned on, and your I.R. enabled laptop can now receive the files from your phone. Close your phone, open it again, press upper right (-) , press joystick down 1 time, then left 1 time, then press the joystick center select button 2 times. Joystick right 1 time, press joystick select 1 time. press upper right (-) 1 time, joystick down 5 times, joystick right 1 time, joystick down 3 times, joystick center select 1 time. Hold the lower left corner of your phone toward the I.R. port of the laptop, it will receive the first photo file in your camera pictures file. Another possible method would be to obtain a usb connector cable for the z525 phone to connect it to your computer. Using the usb cable the computer would recognize the phone, you could click on the phone icon, under "MyComputer" and transfer the files to your hard drive. I hope this helps. -Mike
Mar 09, 2009 | Sony Ericsson Z525a Cellular Phone
Joystick
It is rather frequent problem with Nokia.
If your mobile warranty is expired then try to disassemble your phone and clear you joystick of dirt.
If it doesn't help then nothing can be done but bringing it to service.
As far as I remember menus on 6600 are not recurring so you can not use only up direction to reach icons that are below. I did so on E70 when had he same problem with joystick.
Jun 29, 2008 | Nokia 6600
Cant go left on joystick last solution no good
see buuddy if u have allready triesd with blowing out the dust from joystick part than go for the change of the keypad(joystick). the problem might be with the joystick it might have got broken so change the joystick and than try.
Oct 11, 2007 | Nokia 6600
Right Joystick. . .
I had this same problem with my 360 controller (after modding it, but the solution should be the same..) If you pull up on any 360 joystick it will stick the same way.
The quickest fix would be to take some sandpaper on the inside of where the joystick touches the controller shell, sand it down just enough so the joystick is moving smoothly.
More professional ways would be to cut the little piece of metal that sticks out and goes into the joystick. Just a very small amount, too much will make it hard to press the right thumbstick button.
You could also try some old fashioned grease, just a little bit on the inside, nothing noticeable from the outside.
Also make sure the controller is put back together right, I've taken apart many 360 controllers and sometimes joysticks stick when there's a wire in the wrong place and the shell won't close all the way. (The rumble motors particularly).
Hope this helped!
Sep 16, 2007 | Microsoft Xbox 360 Controller
3230 joystick problem
trow ur cellphone in d river! den cry! dats d best solution!
Dec 14, 2006 | Nokia 3230
Kodak EasyShare DX6490 Digital Camera Logo
49 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
