FSC Amilo Xi 2550: JMircon RAID controller and Intel Turbo Memory
I have a Fujitsu-Siemens Amilo Xi 2550 laptop, which is equipped with two hard drives on a JMicron SATA RAID controller and a 1GB Intel Turbo Memory module. Because of this configuration I can use only 512 MB of my ITM, namely the ReadyBoost part and I can't enable the ReadyDrive feature. According to Intel and the FSC Tech Support this can't be enabled on my machine, because the system drive should be attached to the Intel IDE controller. My question is: how can I replug my system drive to the Intel IDE controller instead of the JMicron? I tried to search for a mainboard diagram of the laptop without any success. Thank you very much in advance for your help!
  • 4 more comments
  • sityisxt Jan 25, 2009
    I would like to add there's no option to disable the RAID controller in the BIOS (and personally I don't think it's a good idea, since my HDDs are attached to it). Uninstalling the RAID drivers also doesn't work, because Vista relies on them - without them my system won't recognize the HDDs and won't start at all.
    Just to clarify: on the Intel IDE controller only my DVD burner is attached, the second SATA port is free, but I don't know where is it located physically on the mainboard of my laptop. The two hard disks are attached to the RAID controller and because of that I cannot use half of the capacity of the Intel Turbo Memory - namely the ReadyDrive part.
    Another thing: this is a laptop. According to SiSoftware Sandra the mainboard is a Fujitsu-Siemens F44. And that's my problem - I can't find any information on the Internet about this mainboard relevant to my problem.
    There's no option to disable the RAID controller in the RAID controller BIOS, although the HDDs are set to non-RAID. Vista still requires the drivers. The ONLY solution is to replug my system drive to the free SATA port of the Intel controller. The question is: where is that port on the mainboard?
    To avoid further BIOS settings suggestions, here are the screenshots of the BIOSes of my laptop, also a picture of the mainboard:http://sityisxt.photoshop.com/
  • sityisxt Feb 02, 2009
    Where shall I disable the RAID in my BIOS? Check the screens at http://sityisxt.photoshop.com/
  • sityisxt Feb 03, 2009
    Ginko, you can see my current configuration on the phtots and all I can adjust in the BIOS. Where can I do what you have written, because I can't find it?
  • 535 Answers
U have to install raid driver from the mother bord if u have disable it then go in bios by press F2 or Del key then advace manu then go chip setting there u have to disble raid controller if give me the model no of *********** bord i can provide u a driver download link
Posted on Jan 25, 2009
  • 13,433 Answers
The raid, you can change and disable the raid in bios, no it wont disable the raid controller and the drives will still work, they just wont be on the raid setup. You may also have to look into raid bios some computers have it separate from the main bios..
  • 565 Answers
U can change the option in bios if u have warrenty but dont know how to do it go to service
  • 679 Answers
You haven't provided me with the make and model of your motherboard, but I can answer the question with some certainty. It is a IDE and/or SATA controller. Intel has dropped support for IDE controller in all of their newer chipset (if I remember correctly from the P965 up), so motherboard manufacturers have had to add third party controllers to provide support for IDE drives. Most of these controller actually provide support for both types (SATA/IDE). Usually the SATA ports supplied by the third party controllers are colored differently from the Intel controllers. Hope that answers your question.
If you need more specific information, provide you motherboard make and model.
Thnaks
  • 19,396 Answers
You do not plug or unplug anything, you have to go to the BIOS, and disable the RAID system from BIOS settings.
  • Ginko
    Ginko Feb 02, 2009
    Try Revert HDD to non Raid.
    If it does not work, try delete RAID, and do an hard disk auto detection afterward.
    Remember to save settings before exiting.
  • Ginko
    Ginko Feb 03, 2009
    The settings are in RAID bios
    Use "Revert HDD to non Raid." from menu at the left.
Key to turn pn wireless
there shouldnt be a "key" to turn on your wireless just look for a button on your laptop to turn wireless on
Apr 09, 2010 | Fujitsu Siemens AMILO Xi 1546 Notebook
How to change and upgrade the memory Fujitsu-Siemens Amilo Pro Fujitsu-Siemens Amilo Pro V2010
on the bottom of the laptop is a square plate with 1 or 2 screws, when the laptop is off, remove those screws and you should see your laptop memory, gently expand the two thin metal clips on either side of the memory and it should pop up at an angle, gently remove it and replace with a larger capacty memory module.
Nov 18, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
Keyboard is not functioning
go to control panel then system then device manager look for you keyboard uninstall it then scan for hardware changes the machine sould detect the keybaord and install it automaticly
Oct 12, 2009 | Fujitsu Siemens AMILO Xi 1546 Notebook
Forgot password
Assume this is a BIOS password? You will need to call the FSC helpdesk as they will need to take the machine in to reset the password.
Apr 22, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Fujitsu siemens amilo m1405
need more info on exactly what happens...
do you see any lights on ..be descriptive..
do hear any beeps..can u hear anything...fans working hd clicking cd drive kicking in etc
Oct 29, 2008 | Fujitsu Siemens AMILO Xi 1546 Notebook
Amilo XI 1546 wont boot up
it seems that before shutdown system was updating pc (in all cases) windows update does this in silent mode so sometimes youre not to know.
boot up as normal...wiat a minute or so ...press and hold power button until pc shuts down completly(you can hear this) a light should be lit momenterily and then fade off.
you may now be able to reboot.
Computers & Internet Logo
1,485 people viewed this question
David Payne
David Payne
