Computor power supply not turning on only the fan cooler turning
  • 7,627 Answers
With out much info, the PSU may be bad. You didn'y supply the Make Model of computer Or the OS.
Posted on Jan 15, 2013
The computer won't start up
does the computer put anything on the screen?
does the computer one beep after self test?
what kind of lights or no power at all
any errors. windows boot up problems
Jul 08, 2015 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
PS-6121-1C HOW TO MAKE UNIT WORK OUTSIDE OF COMPUTOR
Plug into motherboard, turn on computer.....(you dont need it in computer to test just pins)
Or you could buy a Power supply test device
May 17, 2012 | Compaq PS-5500-1C (244163001) 50-Watt...
Hi, I removed my PC's motherboard from one case to the new one. after installing every thing when I turned it on, it displayed the message 'CPU fan power failure' I double checked the...
is the new cooler fan does not draw enough power from the terminals that supply the CPU fan. The motherboard is looking for a specific amount of power from the terminal and gives a warning of a failure when the current drawn is different from the specs. You could look at the old cooler to see if the current requirements are marked on it and then match that current with additional fans ETC to the cooler you are wanting to use.
Sep 01, 2011 | Computers & Internet
I have not been able to find any solutions online and apparently neither has anyone else. Clearly the Emerson FR48 wine cooler is a piece of $#!%. It appears the power supply on these is flaky. I can hear...
check the fam to make sure it spins freely ,, a little wd-40 could help, If the power supply is straining to make the fan move, you will hear that whining sound as its over loading
May 29, 2011 | Emerson (025806803716) Wine Cooler
What is the power supply name and model number of the cooler master(cac-t05-uw)
Go to any computor store and ask for an ATX power supply. You usually want the highest wattage you can afford. You will need to know only if you have the old style hard drive or CD drive power connectors. Are they a four wire with a white block connector, or a 1/2 inch wide red or orange with a slim L connector.
Will cost you about $50 - 60
Feb 19, 2011 | Cooler Master CAC-T05-UW ATX Mid-Tower...
My computer shuts down after a few minutes
2 possible issues come to mind: 1) the computer is getting hot (CPU, memory or video card), 2) the power supply can't keep up with the demand.
Try using a program that lets your track your computer's internal temperature. System Information for Windows, http://www.gtopala.com/ , is the one I use. Depending on the cause, you may need to increase the ventilation of your case (add fans - slot cooler by the video card, front, back or side panel.). If the CPU is getting hot, make sure that the CPU cooler is working and consider removing it and reapplying a new layer of thermal paste before reattaching the cooler.
If the problem is the power supply, check the specs on your devices (memory, CPU, video card) and the power supply load rating. You may need to upgrade the power supply.
I hope this helps.
(I am not a gamer but the default power supply that came with my computer didn't have enough power for the added memory and video card. I replaced that and added a back fan (spot available), a slot cooler, a drive bay fan and cut a hole to add a side panel fan.)
May 08, 2010 | Biostar P4M900-M4 Motherboard
Computer just turnoff suddenly
Could be one of two most common problems?
#1
Have you ever replaced the CPU Cooler (Heatsink/fan)?
CPU Cooler fan may be working, Heatsink dirty.
CPU is over-heating = mainboard turns off
Replace CPU Cooler
#2
Power Supply fan not working causing partial failure on 5volt or 12volt side.
Replace Power Supply
There are more causes but these are most common for short-time boot problems.
Another could be hard-drive, but that wouldn't shut system down like first two would.
Apr 04, 2010 | Sony VAIO PCV-W500GN1 PC Desktop
When I turn on my computor, the CD rom light flashes then nothing further happens
95% of the time if the pc turns on cd rom light flashes then fans turn off its a bad power supply.
Feb 25, 2010 | Computers & Internet
I get no power at all to my computor. There is
The easiest and safest way is to purchase a power supply tester. Just unplug the power supply wireing harness from the motherboard and plug it into the tester. It gives led readouts. Its around five dollars. or just simply take it to a computer shop, most will check that for free
Aug 31, 2009 | Antec SP-400 400-Watt Power Supply
My computor screen is black pc tower has green light on abut no fans are running what has gone wrong . i took caseing off and cleaned all dust but plugged back in and no fans
The first thing I would check is the power supply. It sounds like it has just enough power to turn on some lights, but not enough to power up fans, motherboard, CPU, etc. So either test the Power supply, or just purchase a new one. They are pretty cheap these days.
Aug 04, 2009 | Computers & Internet
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
