Question about TallyGenicom 2280 Matrix Printer
"check ribbon " error is comming on my tally 2280+ serialprinter
Tally genicom 2280+serial printer
  • robrat41 Mar 11, 2009
    before putting in the new ribbon it was working okay.
    Changed the ribbon because the printout was very faint and now get the "check ribbon" error.
    Replaced the ribbon with another new one and the problem persists.
    Both ribbons are genuine tally supplies.
The ribbon I had installed (code 061627) which says it is the correct one is in fact not. the drive pin on the printer slips while feeding the ribbon.
I have fitted a (code 062471) and now it is printing fine again.
a google search reports both these codes as compatible but they are quite clearly, not.
Posted on Mar 11, 2009
    Novelist:
  • 169 Answers
The correct ribbon for the 2280+ is part number 062471.
It is important that this part number is used in the 2280+ the printer has a ribbon sensor to ensure the ribbon is rotating only 062471 accommodates the ribbon sensor.
Other ribbons will not work in the 2280+ you will get a 'Check Ribbon' error message.
Think you were given the wrong part number for 061627 this is for the ribbon driver NOT the ribbon cartridge.
Posted on Sep 21, 2009
What is the cause of error +0001 +131 Hardware Alarm, Check Ribbon 000002+5085+3010 on a Tally Genicom 7265 serial printer. Any help would be great
The Printhead is not where the printer expects it to be. Usually the carriage is jammed, which can be caused by a faulty ribbon. If the carriage is not moving freely with the printer off try to find what is causing the bind.
Mar 01, 2016 | Tally Office Equipment & Supplies
Problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
Apr 20, 2010 | Tally T6218 Matrix Printer
Tally Genicom Slow Printing in Foxpro Dos Program
change the connecting cable serial or parallel what you have it may help you.
Jun 15, 2009 | TallyGenicom 2280 Matrix Printer
Bad print out
I would recomend checking the ribbon cartride fitted in the pritner. Ensure the ribbon is correctly mounted on the ribbon drive shaft.
Ensure the ribbon is not jammed.
Ensure the print head gap is not set to close the ribbon is becomming jammed
Try changing the ribbon cartridge for a new one.
Dec 30, 2008 | TallyGenicom 2348 24WIRE 480CPS Draft 136...
My print out cat read some line very light and some line very dark priner is tally genicom 2348
I would recomend the following;
  1. Check the ribbon is seated correctly in the printer
  2. Check the ribbon is not jammed or tight to move
  3. Check the print head gap, ensure this is not trapping the ribbon
  4. Change the ribbon for a new one
  5. Check the ribbon drive is ok
Paper width error on tally genicom 2280+ printer
Power ON printer holding down ONLINE button, release it after TESTMENU is on display. Press NEXT few times, enter APM or somthing like that (or APW? cant remember), switch it to OFF. Press ONLINE. Thats it! Greetings.
ps. this is procedure direct from polish division of tallygenicom servicedesk. it works for me perfectly!!
Mar 12, 2008 | TallyGenicom 2280 Matrix Printer
TallyGenicom 2280 Matrix Printer Logo
1,613 people viewed this question
Top TallyGenicom Office Equipment & Supplies Experts
Kolbrun...
none
Raj Patel
Are you a TallyGenicom Office Equipment and Supply Expert? Answer questions, earn points and help others
