Question about Vizio Televison & Video
Vizio 50 inch flat screen HDTV monitor slow to turn on - displays "No Signal"
Lately, when we turn our 50 inch Vizio monitor screen on it is slow to display video or have sound. It sometimes comes on then goes off with a "No Signal" displayed. I double check the input and it is correct - HDMI HD2. After a few minutes of going on and off it settles down and is fine he entire rest of the day as long as we don't turn it off. Picture and sound are great when it settles in.
    Genius:
  • 1,669 Answers
There is obviously something loose or not making good contact. Open and then remove and then tighten down ALL the connectors that come into the house for that TV and go through the cable box to the TV!
Posted on Jan 15, 2013
  • 979 Answers
SOURCE: Unable to display HDMI Input
Okay so you have the HDMI cables from both the DVD and the Cable box plugged into the reveiver?
Posted on Feb 28, 2008
SOURCE: Pink Screen on Vizio 37 inch with HDMI Connection
I work as a contract technician for Vizio, and I can tell you from experience that replacing motherboard is one of the only solutions to this problem. The other solution if under warranty is to replace it. If you experience red, blue, or green pixels where dark shades (like nose, eyes, clothes, etc), call Vizio and accept nothing less than a full replacement! I have had situations where I replaced motherboard and within 2-3 hours the pixels return. Hope this helps.
Posted on May 08, 2009
dsacco86
  • 1077 Answers
SOURCE: 50" Vizio Plasma reads "No Signal" on all inputs?
Well, your TV is still under warranty. That's the good part.
The only thing I can recommend without voiding the warranty is leaving the TV unplugged for 30min. That way, the TV can reset itself and hopefully correct the problem.
If that doesn't solve the problem, it's time to use the VIZIO warranty.
Here's contact info if you need it.
Technical Support
Toll-Free: 877.698.4946
(877 MY V I Z I O)
Technical Assistance Emails:
techsupport@vizio.com
Customer Service
Toll-Free:888.849.4623
(888 VIZIO CE)
Posted on Jun 17, 2009
SOURCE: Vizio P50HDTV10A 50 in. HDTV Plasma HDTV Tuner out
The HDTV tuner is out. Analog tuner, and video inputs work fine.
TV Model P50HDTV10A
Screen Size 50 in.
TV Manufactured Date Jan 1, 2007
Part Type MAIN UNIT
Alternate Part Type SIGNAL BOARD
Part Number 3850-0042-0150(3A)
Alternate Part Number 0171-2272-2163
Posted on Dec 27, 2009
  • 4 Answers
SOURCE: 37 inch vizio has black screen. the vizio display
L37HDTV10A THE TV ON NO VIDEO NO MENU SAON OKEY
Posted on Jan 21, 2010
Vizio tv screen went gray
Hi Mike,
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 05, 2015 | Vizio E500i-A1 50" LED TV 1920x1080, 120...
I have a 55 inch vizio flat screen. it turns on but the screen fades away.
//If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Dim screen
- Slow start
Apr 22, 2014 | Sanyo DP50747 50 in. Plasma TV
Have a 50 inch vizio when u turn it on the lite in front turns white but no pic black screen any ideas
you will need to check your power supply!
All televisions wich have tese problems with starting faulty and screen staying black have power issues!
Apr 05, 2013 | Vizio L32 32 in. LCD HDTV
Vizio half of screen is solid color bars. Top half works great.
You have either the circuit board that drives that half of the screen(one for top and another for the bottom) or you have a bad display panel.
May 25, 2012 | Vizio 32-inch Sv320xvt Full 1080p 120hz...
My vizio 50 inch plasma tv will not turn on. what
Tries unplug,replug about an hour,see if it reset itself.Not than must replaced the signal tuner board.Plasma have this problems alot.
Jan 08, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
I have a Vizio P50HDM which will seem to turn on but It displays a small blue rectangle in the center of the screen with the message: "No Signal" I have tried pressing the input button but same message....
Your TV isn't detecting a signal on any input. You can have a bad connecting cable, or a defective source unit, (cable box, satelite reciever, DVD player....). Those are just a couple of possibilities, but a good place to start. Good luck.
Dec 04, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Lenovo T60 interfacing with Vizio HDTV using RGB cable
The X1400 supports Full-HD resolution. Full-HD/True-hd (1920x1080)
The best output would be via DVI but you are limited with the VGA port.
I would purchase a Grand Hi-Wire PC to HDTV converter from www.globalcomputer.com. Item # G126-1036 @ $139.99
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 04, 2008 | Computers & Internet
42 in lcd vizio "no signal"
if the TV have a no signal sign which means most of the important part is missing. Try checking your connections. The best way is to hook up a dvd player using AV input (the yellow, red and white). make sure that you turn the device on and whatever input you connected the device to is selected. if your TV is a P50HDM model, the TV will shut itself off after a short period without and input connected.
Sep 08, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Televison & Video Logo
428 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
