Question about Vizio L32 32 in. LCD HDTV
What should i do to make ma vizio work tv in africa with full colour and audio coz its get channels but no clear colour and audio
    Genius:
  • Vizio Master
  • 2,432 Answers
Tried to use with other system like PAL or secam, if your tv not multi system then you can not get good reception.
Posted on Jan 15, 2013
SOURCE: No Audio in my Vizio HD TV
I solved the problem by going into settings. Then audio. I had one of the audio settings turned off
Posted on Oct 06, 2009
tvtek
  • 1284 Answers
SOURCE: vizio pixelation in hd nt all channels
Usually a TV that pixelates only on some channels is a problem with the signal levels coming into the TV or the cable box. If you are using a cable box then definatley the signal is the issue..
Posted on Nov 11, 2009
  • 4 Answers
SOURCE: New Vizio TV - Channel up and down buttons don't work
upon the psp and try to fix it
Posted on Apr 10, 2010
  • 10 Answers
SOURCE: I own a VIZIO GV47LF
If I remember correctly, you have to turn off the set's speakers in order for the optical audio out to function.
Posted on May 02, 2011
eagle338
  • 4889 Answers
SOURCE: imagypsyRe:Vizio 42" LCD TV Screen randomly
You should definitely return it. It is most likely due to backlight malfunction and or backlight invereter malfunction. Either ways you should return it and demand for a replacement if its under warranty.
Posted on May 30, 2011
Hello, I have an LG42cs560 w/o audio output. I'd like to attach a Vizio soundbar. Is there a work around for this?
Unfortunately no. There must be a source for the audio. If there is no headphone jack or Audio output of some sort there is no way to make the sound bar work with the audio in the TV.
Jan 02, 2018 | Vizio Audio Players & Recorders
Screen seems stretched. How do I fix it?
60'' Vizio TV screen is stretched in 'normal' screen mode on HD ...
https://answers.yahoo.com/question/index?qid...
Jul 21, 2013 - Ive had this tv for almost a year and the screen has never given me problems, but just recently all the HD channels are stretched. ... If your Vizio is like my 47" it has 4 Picture Modes - Wide, Normal, Zoom and Panoramic. ... Why isnt my viziotv able to play full screen hd channels?
TV Problem: The picture on my television is stretched out on the ...
Aug 23, 2008 - It is a High Definition Vizio TV. The center of the screen is clear, but the television stretches the image out on the sides. Is there anyway to fix ...
How to Fix the Most Annoying Features of Your New HDTV ...
Dec 31, 2015 | Vizio VA Televison & Video
Lip sync
Vizio HDTV- Lips out of sync
Anyone with a new Vizio E601i-A3 60" or 70" HDTV that is having audio "Lips out of sync problems" with a cable or satellite box.
On Comcast cable boxes (or others), here's what you need to do: FIND MENU for AUDIO or HDMI setup on CABLE BOX or Satellite Box.
FOR COMCAST
1. Turn on TV and have Cable box Turned OFF.
2. Press MENU on COMCAST REMOTE.
3. Go to AUDIO Setting OR HDMI Setting. (On cable or Sat. BOX)
4. Change setting from Auto to L-PCM. (Turn off cable box to exit)
This should resolve any "out of sync" lips to picture after commercials on HD channels.
*This is a handshaking issue from the cable box to the Vizio E601i-A3
Dec 08, 2012 | Vizio 60" E601I-A3 Full HD LED-LCD TV
No sound on a few channels. all others have sound. 26 in vizio.
Since you have sound, the audio circuits are working. The most common cause of this is to have the TV set to use SAP. There are many channels where this is an unused option and others that broadcast the same audio on the standard channel as well as SAP. If you change the channels and get Spanish rather than English for example, you have SAP turned on. Check the audio menu for SAP status.
Let us know what you find.
Dan
Dec 06, 2010 | Vizio L32 32 in. LCD HDTV
I have a VIZIO LED/LCD VF551XVT hooked up to a motorola HD DVR with a HDMI cable. When I switch from standard Def to High Def channels I lose the sound. If I turn the TV off/on the sound returns but if I...
I have the same set, same problem with one of my MOTOROLA boxes, but not with another. I have a SONY TV that works fine with this new MOTO box, but the new VIZIO does not. The audio is coming through the HDMI cable just fine, and the fact that it works when you cycle power on your TV means it's the SYNC between the TV and the BOX. I have the identical problem and am taking back the MOTO box for another one. I spoke to VIZIO for about 45 minutes trying different things. They think it's the MOTOROLA box, COX (my cable company) thinks it's this particular box, who knows.
Feb 01, 2010 | Vizio VF551XVT 55 in. HDTV
Scan No Longer Working
Do you have Verizon? The problem you are having is a long standing issue with Verizon. It was recently corrected for some of us. Certain TV's could not receive QAM channels, because of a Verizon caused issue. They blamed the TV manufacturer and the manufacturer blamed Verizon.
My TV's are Sharps, but I recall Vizio as also having the problem. Although it was fixed in my area MA, and in the Philadelphia area, other areas are still reporting the issue My problem disappeared shortly after the recent channel realignment.
Here is a link to a lengthy thread on the subject at the AVS forum;
http://www.dslreports.com/forum/r19439993-QAM-Changes-from-Philly-VHO
Jul 10, 2009 | Vizio L32 32 in. LCD HDTV
Vizio L32 32 in. LCD HDTV Logo
74 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
