Question about Lexmark X1270 All-In-One InkJet Printer
I do not have my cd
I want to scan to word document
  • 350 Answers
Is this a lexmark x1270 All In One Ink Jet Printer?
Is this a scanned PDF File?
If so you may want to buy the software to do this @
http://www.investintech.com/prod_a2e_pro.htm
or lexmark Themselves @
http://support.lexmark.com/share/
I'd try lexmark 1st they appear to have an awesome site and technical support!
START HERE: http://www.lexmark.com/lexmark/sequentialem/home/0,6959,204816596_652569481_0_en,00.html
Hope this is helpful.
Good Luck!
Posted on Jan 24, 2009
The lexmark x2650 doesn't have the OCR software in it. I try to scan a document and edit it but can't because no OCR software included
To scan documents for editing and saving as PDF file, you will need to install the Lexmark OCR scan software on your computer. The Lexmark scan software (no downloadable version) is only available on the installation disc that came with your printer. If you lost the disc, please contact Lexmark Technical Support Center for assistance.
To install the OCR scan software from the printer installation CD:
  1. Insert CD into the CD-ROM drive. If the installation screen open, click Cancel.
  2. Double-click on My Computer / Computer.
  3. Right-click on Lexmark XXXX CD and select Open.
  4. Double-click on OCR.
  5. Double-click on Setup.exe to install the OCR software. Your operating system will then determine the language in which it is installed.
Mar 05, 2012 | Lexmark X2650 All-In-One InkJet Printer
How do I set up the scanner on my HP J3680?
use the CD that came with the printer.it has the full feature software that will enable the printing and scanning capability of the printer.
- insert the disk in the CD-ROM drive - hit install - reminder:do not plug in the USB cable yet unless you are prompted by the installer to do so - after installing the software , make a test print to prove the functionality of the printer. - then we move on to test the scanner -there are two ways to make a scan: 1. click on the solution center icon on the desktop. 2. in the solution center , there are two buttons for scanning: scan pictures and scan document 3. scanned documents are saved under the MY SCANS folder. file path is : my documents or simply documents---->MY SCANS 4.for scanned pictures file path is
my pictures or simply pictures---->MY SCANS
Jun 27, 2011 | HP J3680 Officejet All In One Printer
I've lost my set up cd and although the printer and copyer work I cannot scan a document onto the computer.
Scanning a document to your computer may require the Lexmark OCR scan software which is only available in the installation disk. Try to contact Lexmark technical support to request for the installation disk. Thank you for choosing Lexmark.
Sep 15, 2010 | Lexmark X4650 InkJet Printer
I am trying to scan a document from HP 4280 All-in-One printer HP Solution Center to My Documents. However, I am unable to type Destination (My Documents) in the Scan to. I have reinstalled from the CD...
Generally, the scan to field will designate the the type of program that you want to use to view/edit the document. An example would be microsoft word.
Once you scan the document to a program, you can then save it in any folder on your hard drive, including "My documents". However, if you chose to leave the scan to on "Scan to a File", the scan will automatically go to c://useraccountname/My Documents/my scans.
You can then go to my documents/my scans and move the scanned document to whatever location you would like on your hard drive.
If you have any additional questions about this information, feel free to contact my by replying to this message.
Thank You,
Brian
Jan 28, 2010 | HP Photosmart C4240 All-In-One InkJet...
How do I scan a document into a pdf and send by email
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
astrtr21
Aug 12, 2009 | HP Officejet 5610 All-In-One InkJet...
How do i scan a document and then email it
If you haven't done so, install the cd that comes with the HP Officejet package. Once correctly install, you should go to "All Programs" and locate "HP Solution Center" Click on HP Solution Center, click "Settings", click "Scan settings and preferences", choose either "scan document" or "scan picture" If word document then under File type: locate "PDF(*.pdf) If document is a picture then under File type: locate "JPEG image(*.jpg), click ok. Step 2 Choose between Scan Picture or Scan Document, click accept Step 3 your file is locate under "My scan" Hope that helps
Jul 10, 2009 | HP Officejet 5610 All-In-One InkJet...
Scan and make changes to document later
Do you have any OCR (Optical Character Recognition) software installed?
That is what you will need to extract the text information from the scanned document, which is simply a picture(photo) of your original.
Have a look here and decide yourself which solution suites you best.
(I would always try the free version first...;-)
It is also possible that your printer came with some kind of OCR software (often a scaled-down version of ReadIRIS) - check the CD's that came with your printer.
Jan 27, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Scanning
you need an application software to scan a document first, install one from your manufacturer's CD and follw the direction carefully, or if your computer recognizes
go to start-program-accesories-then scanner and camera, see if your computer recognizes your scanner.
Aug 16, 2008 | HP Officejet 6310 All-In-One InkJet...
CD-4050 Scanner
First scan a single page and note the file size. Then scan two pages and check if the file size is changed. If the file size is changed, then you have problem with your viewing software. If the file size is same, then check your setting in the scaniing software.
S. Moha, India
Nov 29, 2007 | Canon CD-4050 Path-Through Scanner
Lexmark X1270 All-In-One InkJet Printer Logo
50 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
