Question about HP Designjet T610 InkJet Printer
Code error 08:10 of designjet t610 - HP Designjet T610 InkJet Printer
Joed911
  • 4338 Answers
SOURCE: error code 22.1:10 on HP Designjet T610
HP does not specify what that error means. It says to contact HP Support. If the unit is in warranty, Hp will repair it, free of charge.
HP and Compaq products
800-HP invent
or
800-474-6836 24 hours a day, 7 days a week for most products U.S.: English and Spanish for most products.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 27, 2008
  • 16 Answers
SOURCE: mu HP Designjet T610 get mistake 21.13
Service Station error. Switch the power OFF from the back of the Printer and disconnect the power cord. Check the Primer Tubes. Reconnect the power cord and power On the Printer. Make sure that the Service Station path is clear. Remove any visible obstacles (e.g. screws, plastic parts, etc...) restricting the movement of the Service Station. If the System Error continues, replace the Service Station. If the System Error continues, replace the PrintMech PCA
Posted on Aug 18, 2009
  • 1170 Answers
SOURCE: hp designjet t610 error 01.1:10
Explanation Problem with the PrintMech PCA. Recommended action Try the following:
  1. Turn the printer off (using the power switch at the back of the printer), and disconnect the power cable. Wait 15 seconds and reconnect the power cable and turn the printer on.
  2. If the error continues, call HP for support.
Posted on Sep 24, 2010
  • 181 Answers
SOURCE: Error code 08:11 on hp
down load drivers
open google home page serch driver magician
update
open drivers click
driver version relese date
driver name copy serch google free down load
Posted on Oct 31, 2010
seeker5211
  • 1089 Answers
SOURCE: HPdesignjet T610 error code 08:11
The 8 code is a formatter or front panel problem. Try reseating the formatter and its cables. Also reseat the front panel cable.
Basically it means that there is no communication between the front panel and the Main board. Turn the printer off and unplug it from the wall. Reconnect the cord and power up. If it still fails, the formatter or the main board or the front panel will have to be replaced. Get a tech to check it out.
02.1.10 error plotter t610 and solution
The error code 02.1:10 means the plotter has a communications problem between the main logic board and the carriage PCA. The possible parts at fault are: The Carriage PCA, Trailing Cable, or the Main Logic Board, all available here: Designjet T610 Parts
You can watch this video to see how to remove the covers Designjet T610 Belt Replacement How To Video
The service manual is here: Designjet T1100-T610 service_manual
Sep 18, 2013 | HP Designjet T610 InkJet Printer
I have hp t610 plotter and it incurred paper jam
Check the carriage belt for wear. Is there an error code?
Aug 19, 2013 | HP Designjet T610 InkJet Printer
Hp desinjet t610 error code 02.01.10
Switch the Power OFF from the back of the Printer and disconnect the Power cord. Reconnect the power cord and power On the Printer.
If error comes back, call a tech. There is a problem with the Carriage Board or Trailing Cables
Aug 14, 2013 | HP Designjet T610 InkJet Printer
Just got a new HP Designjet T770 hard disk printer, keep getting error code 21.1:03, turned power off and unplugged, still receiving same error code
Issue with the service station. Turn off and turn on your printer couple of times. Try moving the carriage assy., manually.
Still if it don't work then the service station would have gone bad. Needs to be replaced.
May 24, 2011 | HP Designjet T610 InkJet Printer
I had a paper jam I removed the paper but the error message is still there 86:01 is the code I have an HP Designjet T610 44"
86 errors are usually generated when the carridge assembly cannot move all the way from left to right. Open the top door and check on both ends to ensure that a small piece of paper is not jammed there. It does not take much to cause this error. Also make sure that the print head retainer is seated properly as I have had that issue generate this error.
May 11, 2011 | HP Designjet T610 InkJet Printer
Oct 31, 2010 | HP Designjet T610 InkJet Printer
Hp designjet t610 error 01.1:10
Sep 24, 2010 | HP Designjet T610 24-in printer InkJet
Mu HP Designjet T610 get mistake 21.13
Aug 05, 2009 | HP Designjet T610 InkJet Printer
Error code 22.1:10 on HP Designjet T610
800-HP invent
or
Thanks, Joe
Nov 18, 2008 | HP LaserJet 4 plus Printer
HP Designjet T610 InkJet Printer Logo
85 people viewed this question
Seeker5211
Seeker5211
