Question about HP Hewlett Packard xw6600 Workstation with 650W 80 PLUS Energy Efficient Chassis - RB455UTABA PC Desktop
Computer will not start it give me two beeps - HP Hewlett Packard xw6600 Workstation with 650W 80 PLUS Energy Efficient Chassis - RB455UTABA PC Desktop
  • HP Master
  • 27,725 Answers
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Remove added memory If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory. Open computer and reseat memory Sometimes when the computer is moved or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer. Swap memory location If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. If you have more than one stick of memory try removing all but one stick of memory and boot the computer. Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory. Try another computers memory If you have access to another computer that uses the same memory, try using its known good memory in your computer. If another computers memory works you know that you have bad memory. If another computers memory does not work and it is compatible with your computer unfortunately your motherboard or the slots on the motherboard are defective causing it to be unable to properly read the memory, which means the motherboard will have to be replaced. Replace memory If it is determined the memory in the computer is bad we suggest that you replace it if you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. First you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system You should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible b> Hope this helps.
Posted on Jan 15, 2013
Et1862 stuck in elogo and restart with a beep continously
See if the computer will start in safe mode.
Steps to get in to safe mode: Make sure the computer is OFF not in sleep or hibernate mode.
Start computer and tap on the F8 key till you see a text screen that gives you the: Start windows in safe mode with networking.
Select that startup. If the computer doesn't start and you get the same beep - Then you have a possible hardware related issue.
If the beep is actually a number of beeps - this would relate to your system memory. Hope this help you in figuring out your issue.
Have a great night.
Dec 05, 2014 | Computers & Internet
Why does my computer beep but doesn't turn on when I push the start button ?
The model you have and the amount of beeps are important. The beeping sound indicates some sort of hardware failure. If you have access to another computer, then google the model and the amount of BIOS beeps.
This will give you a good pointer as to where to start and what to change.
The fastest way would be to take it into a repair shop and have them look at it.
Jul 01, 2014 | ASUS Computers & Internet
Dryer runs but beeps intermitenly and doesn't stop beeping
you most likely have a bad computer board located in the top console.i haven't changed any of these boards out but on the frigidaire affinity dryer this happens alot and it's the computer board.the dryer would just start beeping on it's own,like 3 beeps at a time beep beep beep,then beep beep beep,was the board,you have to give the full model number to whoever you order the board from,open the dryer door,look around the opening where you put the clothes in and you'll see a tag with the full model number.good luck.
Feb 25, 2014 | Whirlpool GEW9868K Electric Dryer
Bangladesh
Friends.
Beep means you computer good or damage conduction denote. If one beep and you laptop start then good conduction. If one long beep and laptop not start then you RAM damage position. But you say you laptop start then not problem in beep sound. And you touchpad not working so i suggest you contact good engineer.
Thanks..
Sep 23, 2013 | Acer Computers & Internet
My Computer Beeping when star-up. The Beeping sound is continue such as Beep...Bee...Beep...Beep..until I force it by pressing the start up button to stop it total. I think due to the new mouse and...
Beeps always indicate error excluding a one single beep only which indicate process.Every manufacturer has its own beep setting. it comprises on short and long beeps. If previously it working good, then your idea may be correct. replace both the keyboard and mouse with existing. start computer if now it not giving beeps it meant that one of them is causing problem. connect one by one and start computer you will reach. AND if even after replacing keyboard and mouse it gave beeps then shut down your system. Open casing remove processor and memory chip out and connect them again it will work now INSHALLAH.
Sep 24, 2010 | Computers & Internet
Starting proplem
The one beep is normal . If the fan is not working on the CPU , replace the fan or oil it The CPU can go only a second or so without the fan working. Some models(BIOS )will not allow the computer to start if the fan is not working. Start there.Check out the link below:
http://www.computerhope.com/beep.htm
Jan 19, 2009 | Compaq Presario SR1000T (568657) PC...
Cusl2-c motherboard problem, no clue what it is
can you give me the beeps explanation. All computers have a standard "beep code" this is a standard code to determine the problems in boot up. Long beeps, short beeps, intermittent beeps all mean something. Can you give me your best definition of the beep codes ? long, short, quick successive beeps etc also can you give the nake and model of the computer.
Chris the computer doctor
Dec 26, 2008 | ASUS Intel 815E Chipset CUSL2-C...
Beep code
The sequence of one long beep and two short beep when starting computer usually means problem in your display adapter. Make sure your VGA connector is connected properly to VGA out port.
If you are using VGA card (non on-board), you might want to make sure that the card is inserted properly to motherboard.
The beep indicates that system can not initialize display.
Dec 15, 2008 | HP Pavilion dv9000z Notebook
HP Hewlett Packard xw6600 Workstation with 650W 80 PLUS Energy Efficient Chassis - RB455UTABA  PC Desktop Logo
24 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
