Question about Swanson Tool P0110 Little Blue Book of Instructions for Roof and Stairway Layout
Swanson speed square manual.pdf - Swanson Tool P0110 Little Blue Book of Instructions for Roof and Stairway Layout
Why is a speed square 7 inches ?
Hi Joe,
Yes it is 7" X 7". I offer two videos to enjoy its usefulness. Extreme How To Original Swanson Speed Square
Here is a stair layout 12" X 12" with attachments Swanson Big 12 Speed Square . I prefer stair gauges and a layout square. Either method s good.
Here is the link for a variety of topics and input on the uses of the squares for your library.
Fare. Well. Swanson Big 12 Speed Square for Stringers
Dec 31, 2014 | Office Equipment & Supplies
When I try to cut a 45 it seems to be cutting a little more than a 45. how do I adjust it?
Make sure the blade is 90 deg vertical to the saw table. Make sure the indicator is set approprately. Raise the blade just enough to clear the table/base. Place a swanson speed square against the fence and blade. Make sure the indicator is at 90 degrees. Here you might want to tilt the square and check that the complete blade is flush against the sqaure as high up as possible. Lay the square back flat on the table and pull the blade toward you as much as possible. The teeth on the blade should ride against the square extented completely out.
Now set the square against the fence with the 45 degree angle coming away from the table and set the blade on the 45 deg mark on the insicator scale.
The blade should touch the square all the way out fully extented.
Or just experiment with some scrap and check
May 19, 2010 | Dewalt 12" Beveling Sliding Compound Miter...
How do I factor on my casio Fx115es
support.casio.com/pdf/004/fx-115ES_991ES_Eng.pdf -
It is all explained in the above manual.
May 09, 2010 | Casio FX-115ES Scientific Calculator
Is the Swanson 8" sliding T bevel good for determining inside and outside corner angels?
the t bevel is good for replicating any angle. Been a carpenter for 20 plus years and the tool is priceless
Nov 26, 2009 | Swanson 8 Inch Sliding T Bevel
Need to know how to figure a rafter cut
Assuming you already know the angle you require, take the edge with the level on it(if you have that model) or the side that hangs over and hook it on the edge of the board. If you look at the top, on the 90 degree end, it says "pivot", and that is where you will spin the square around. You read on the 45 degree end that was hooked to the board for you angle. If you are trying to cut a rafter at a specific pitch such as a 6/12 you will spin the square around until the 6 on the Common scale lines up with the edge of the board. The Hip/Val scale is for cutting hips and valleys for the roof structure.
If you have any other questions, feel free to contact me here
Bob
Sep 11, 2009 | Swanson Speedlite Level Square
KNOWING RISE OVER RUN HOW DO I USE THE SQUARE TO MAKE MY ANGLE?
Run is alway 12".
Example 4" (rise)/12" (run)
Measure 4" on one leg of the square and 12" on the other leg. Connect the points and there your angle.
Jun 29, 2009 | Swanson 119 High Visibility Speed Square
Need repair on bunn commercial coffee maker
SWANSON SERVICE & REPAIR INC. 2115 GREENE ST. ADEL IA 50003 515-993-2272 DAN CONE GROUP - Refrigeration Certified 1056 27TH AVE SW CEDAR RAPIDS IA 52404 319-365-3325 GOODWIN TUCKER GROUP - Refrigeration Certified 935 33RD AVE. SW CEDAR RAPIDS IA 52404 319-365-1311 SWANSON SERVICE & REPAIR
CEDAR RAPIDS IA 52401 515-993-2272 COMMERCIAL FOOD EQUIPMENT - Refrigeration Certified 1113 W 4TH ST DAVENPORT IA 52802 563-323-1826 GOODWIN TUCKER GROUP - Refrigeration Certified 2900 DELAWARE AVE DES MOINES IA 50317 800-372-6066, 515-262-9308 GOODWIN TUCKER GROUP 3530 PIERCE SIOUX CITY IA 51104 712-277-0056 GOODWIN TUCKER GROUP - Refrigeration Certified 3175 W. AIRLINE HIGHWAY WATERLOO IA 50703 319-232-5049 SWANSON SERVICE & REPAIR
WAVERLY IA 50677 515-993-2272
Jun 19, 2009 | Bunn NHB Coffee Maker
Humminbird 7300211 speed unit
Hi!
Installation of the speed/temp wheel is quite easy, here's a manual:
SW Speed & Temp
The new sensor cable plugs into the square plugin in back of your Humminbird....it's the small square connector with 4 holes.
Best of luck!
Mike
Apr 30, 2009 | Humminbird 7300211 SW Speed Sensor GPS...
Swanson Tool P0110 Little Blue Book of Instructions for Roof and Stairway Layout Logo
1,687 people viewed this question
Top Swanson Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Swanson Measuring Tool and Sensor Expert? Answer questions, earn points and help others
