Question about Speed Queen Parts Speed Queen 55972A Dryer COIL, DUAL INPUT - Speed Queen Laundry Parts
Were in ireland can i buy a coil set for my speed queen gas tumble dryer both coils are a two pin coil the machine is 13 year old but in mint condition this the fifst time that it has given me any trouble
  • brian bergin
    brian bergin Jan 30, 2014
    did u find the coils as aim looking for the same
  • 314 Answers
What is the name of the dryer and what is the model rate these for clean good solution
Posted on Jan 15, 2013
Speed queen gas dryer, at least 20 yrs old: the igniter begins to glow, then fades out, there doesn't seem to be gas ignition as the chlothes are not drying...so?
Sounds like you may need some coils. Mine would heat up for a minute then go out. The coils were my problem. They are located close to the igniter. They come 2 in a pack and you have to replace both. Probably $20
Oct 07, 2017 | Speed Queen Dryers
What's your problem?My older Speed Queen gas dryer is making squealing noiseses
I work on commercial units ,and this sounds like a trunnion bearing, or drum has come loose
1 loose trunnion bolt -easy fix
2 bearings - call experience repair
Jul 16, 2017 | Speed Queen Washing Machines
My Speed Queen dumble dryer smell like burning wire
HI....Does the MOTOR works or rotates.If it still heres no problem with that...if you smell something bad on your machine there something wrong with the motor wires coil..possibly overloading can cause problem with the motor..motor will produce more power beyond its capacity then its coil becomes hotter that gradually burnt the coil.You can check by removing the back cover of the machine.Unscrew it properly.locate the motor as well as the shafting..If yuo smell something bad with the motor possibly coils got burnt. you can check both ends of the motor terminals using a MULTITESTER .Unplug first the machine set the MULTITESTER to OHMS to the lowest value ..Now if moves a little means there is no short circuit happened but if it does the moves its maximum value then it has been shpt circuited.The armature coils might been short circuited
Jul 07, 2011 | Speed Queen Washing Machines
Dryer wont heat where is the fuse? speed queen
I do not believe it is a fuse, the dryer has a heater coil very much like a space heater contained in an air box inside of the dryer. If this heater coil breaks or burns into, then no heat. My 30 year old dryer has had two That I had to replace over the years. in order to get to this coil, youhave to take the back off.
Dec 28, 2010 | Speed Queen AES68AWF Dryer
LPG kit for Speed Queen 30XG gas dryer
You should be able to convert it over. Check out the link that I am providing. It's information on the conversion process and what it entails. Hope this helped and best wishes.
http://fixitnow.com/wp/2009/03/13/converting-a-gas-dryer-from-natural-gas-to-propane/
Sep 06, 2009 | Dryers
My speed queen gas dryer drum will not tumble what do you think is wrong?
Most likely the drive belt is broken. If you pop off the panel at the bottom of the machine, you will probably find a broken belt on the inside. The belt itself isn't very expensive and the overall repair is around $75 to have a repairman out.
Apr 15, 2009 | Speed Queen AGS28AWF Gas Dryer
Speed queen commerical dryer
try replacing the gas valve coils. they are cheap
Jul 25, 2008 | Speed Queen CGS68AWF Gas Dryer
HI, I am having a lot of trouble with my front loader which is only about 4 years old. It seems to become very unbalanced during the coloured wash setting (even with a small load) - and yet is perfectly...
check teco coil on the back of the motor, it may have come loose'its about inch round thing it gives power to the the speed control module circuit board thats why its tumbleing too fast.bye Eamonn Ireland
Jun 11, 2008 | Whirlpool Washing Machines
Maytag LSG7806A stackable washer/dryer - dryer not working
Deb, as long as the ignitor is glowing, it's probably your coils on the valve. Look at number 13 and 14 on the attachment. Part number for the booster coil is 306106 and 306105 for the secondary coil. Not a hard job, the coils slide right off after removing a screw and then replace the harness. Catriver...post back.
Oct 14, 2006 | Maytag LSG7806A Front Load Stacked Washer...
Speed Queen Parts Speed Queen 55972A Dryer COIL, DUAL INPUT - Speed Queen Laundry Parts Logo
164 people viewed this question
Top Speed Queen Parts Dryers Experts
Are you a Speed Queen Parts Dryer Expert? Answer questions, earn points and help others
