Question about Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool
How do i juse the key for the point safe p1e?
How do i juse the key for point safe p1e, where do it go?
    New Friend:
The keyhole is behind the little plastic section between handle keycode part u need to pop it out with a little screwdriver
Posted on Jan 21, 2013
Tuvaro virus, can't remove.
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer.
As the computer is booting repeatadly press the F8 key as the computer is booting
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select the safe mode option
then run your antivirus if still cant get rid of the virus restart again
Use the up and down arrow keys to move the highlight to your choice.
select safe mode with networking download anti malware and microsoft security essentials
http://www.microsoft.com/en-us/download/virus-malware.aspx?q=virus
anti virus and malware
http://windows.microsoft.com/en-US/windows/products/security-essentials
If this fails you might have to go back into safe mode.
You might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System
Configuration utility Installation restore points that occur before you install a program or a service.You can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly.
This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
Feb 21, 2014 | Computers & Internet
Liewe juses se kerkie oos rand gauteng soek hulle telefoon nommer
Ek is dringend opsoek na julle tel nr of email. Liwe juses Oos Rand. Ek het gister gaan kyk en dit is Stunning. Ek wil graag indien moontlik vra of ek 'n troue daar kan hou op die 7 Maart 5h00 die aand en sommer die onthaal ook. Kan julle dring vir my terugvoer gee asb. Ek en my man is 32 jaar getroud en wil trou. my email: irene.oosthuizen@yahoo.com. Tel: 0828224304
Feb 18, 2014 | Computers & Internet
Switches off after few seconds
Does it work in safe mode ?
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
Configuration utility Installation restore points that occur before you install a program or a service. You can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly.
May 15, 2013 | Acer Aspire Computers & Internet
Operating system
You have not stated what type of problem you are having??..
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
Jan 19, 2012 | Compaq Computers & Internet
I have a bunker hill safe #93575, the battery is getting low. is there any thing i need to know about changing the batterys
Change batteries ASAP because if your batteries die you will be unable to get into the safe without the key. The batteries are located inside the safe. If you can't open the safe, you can't replace the batteries!!!
There are NO replacement keys available for model #45891. We've tried. I would NOT buy this safe again for these reasons.!!!
Nov 08, 2011 | Check Point Network Adapter
I had installed bluetooth driver twice. due to this my laptop is not shut downing.
Hi. Thanks for your question.
On the startup press F8 key several times to get to the advanced startup menu. Once you see it choose safe mode. Once the safe mode is loaded press and go too.
Start------->All Programs------>Accessories-------> System Tools------System Restore.
choose restore point just before you installed Bluetooth driver and restore to that point. Once your computer will restart you should be back up and running as normal.
Good Luck
Nov 04, 2010 | Acer Computers & Internet
Everything works except the three bottom keys on the top slide. i.e the menu key, the navigator key and the clear key.
better have it check with your nearest nokia wireless center,i have  the same problem with my nokia n70,it juse needs allignment.
Aug 21, 2010 | Nokia 6110 Cellular Phone
Are all bunker hill safe keys the same?
Never!.............sodeep (unless you happen to be the lucky one in a million)
May 16, 2009 | Check Point Network Adapter
Lost Safe Keys
The safe comes with 3 keys...2 User keys and 1 master. The user keys require a code and a key to open the safe. The master does't require a code to open the safe. As far as I know, there is no way to open the safe without one of the keys...call for a locksmith...
Dec 04, 2008 | Check Point Network Adapter
Cannot get my Bunker Hill Safe open.
get the key number that is listed above the key hole and then call 888-299-3427 for a replacement
Nov 21, 2008 | Check Point Network Adapter
Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool Logo
43 people viewed this question
Top Safe International Locks & Locksmithing Experts
Jim London
Jim London
john h
Are you a Safe International Lock and Locksmithing Expert? Answer questions, earn points and help others
