Question about Dell Precision 390 PC Desktop
Dell Presision 390 solid amber light - Dell Precision 390 PC Desktop
  • 239 Answers
SOURCE: Dell 5150 - solid amber light at the switch.
Make sure the 12v power connector is securely connected to the system board. If you open up your computer look at the end of the board that the memory modules are there is a 4 pin connector thats the 12 v Make sure thats plugged in and secure, If thats ok you have already did the removal of the memory and replaced them, take out any pci express cards and use your onboard video, if that don't work try one memory module at a time see if that works you already seem to be savoy enough to do that and try that, and if that does not work you may need a new power supply. You can check it but probally will be bad I have the same desktop and thats been a problem with these 5150 along with the mother board going out after the warranty expires. I sure Hope this helps you out,, Happy Holidays to you and yours. Hey If you need me to look anything else up let me know. Thanks again bear001
Posted on Dec 15, 2007
  • 31 Answers
SOURCE: amber light on power button of Dell Dimension 4500
ok - the amber light of doom on a dell means one of two things - either your power supply is pooched - or your motherboard, If under warranty dell will send out a friendly tech to replace them - if not it will cost you a bit. get the price and consider if it worth upgrading instead. Contact your dell rep or dell tech support and see what they say
cheers Pete
Posted on Nov 30, 2008
SOURCE: Dell GX270 won't boot up with solid amber light on Power button
Check motherboard for bad capacitors. I had the same problem and when i had bad capacitors replaced everything is ok.
Posted on Feb 20, 2009
  • 561 Answers
SOURCE: solid amber light ON Dell Inspiron 530 desktop.The
Hi
Please try the following
1) Remove ALL wires from thw back of the PC
2) Press and hold the power button on for approx 15 seconds
3) Replug only the mains power wire and the monitor cable and then retest
Please advise of outcome
I hope this has been useful
Posted on Mar 05, 2010
  • 4 Answers
SOURCE: xp420 dell doesnt boot just a solid amber light on
Solid Amber light is a No-Boot scenario for all DELL PC. It may be either Power Supply, motherboard, memory or Proc. If you try to call Dell customer support they might try to let you isolate the problem by opening up your pc. But they will replace the parts necessary if they found out that its broken and your XPS is still under warranty.
You can call 1-800-232-8544 be sure to have you Service Tag or Express Service code ready.
Posted on Jun 21, 2010
How to solve orange solid light on my dell GX520 when i boot it
Nana, A solid amber power button on your GX520, indicates a motherboard failure. The motherboard will need replaced. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Solid orange power button on Optiplex GX520
My Dell Optiplex GX520 will not boot Forums
Dell Optiplex GX520 amber solid light no power
Aug 05, 2016 | Dell Computers & Internet
Yellow Amber light on Dell Optiplex 390 not booting or display what to do?
A steady or Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Apr 21, 2014 | Dell Precision 380 P4 Dual Core 3 GHz...
Dell poweredge 2650 solid amber light
go here and enter the service tag of your server and download dell open manage server administrator managed node. once installed it will tell you exactly what the problem is. i believe the current version of OMSA is 7.1
Dec 10, 2012 | Dell PowerEdge Computers & Internet
How to fix a yellow solid light on a motherboard for a dell precision 390
dell precision 390 pc booting problem what i do WebRepOverall ratingThis site has no rating(not enough votes)
Oct 24, 2011 | Dell Precision 380 P4 Dual Core 3 GHz...
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
Dell opitiplex 280 is not giving display. first of all his fan speed to much high and then after 4 or 5 day its display disappeared. its just picking now power and fan also start with high noise and...
OK, I use GX280s as home servers and ran into a similar problem with one of them...
The problem may be serious and not worth fixing (motherboard).
Turn power on
Fan(s) come on full power, sounds like a jet engine, or eventually gets that loud.
See if you power light has gone amber.
You get nothing on the screen, no Dell splash screen/post, nothing.
This is what I posted a while back concerning the above. Obviously I cannot bee 100% certain as I do not have your box in front of me. This a known issue.
See if the power light goes amber after power up. I had (have - still siting in my basement) one that did same. Power up, fans go full blast . Power light goes and stays amber. This is USUALLY caused by bad capacitors on the mother board. Known GX280 problem going back. If you look on the motherboard, the capacitors should have flat tops and not leaking. If the are rounded or leaking, the MB has probably gone bad. Bottom line this is usually a defective motherboard. Mine was a bad caps issue, you issue could be different, but it does sound like the motherboard.
You can google "gx280 solid amber light loud fan" and see the issues. Here is one link.
http://community.spiceworks.com/topic/111476-gx280-solid-amber-light-and-loud-fan
I just replaced one of my old 280s with a dual core Dell Precision 390 workstation for about $118, and that included shipping, off of ebay.
Sep 25, 2011 | Dell OptiPlex GX280 PC Desktop
Amber light solid. Replaced the power supply ad the cmos battery. removed the memory and reconnected. Plugged back in and I hear the fan running kind of loud (louder than before) Still solid amber light
most times i have seen amber light, if it is where the pwr light is on front of tower means ur mother board might be fried. check capacitors one by one and make sure none are extended or leaking. dell has had this issue before when they sent out a bad batch of capacitors. may last it job was mostly issues with this. good luck.
Dec 11, 2009 | Dell OptiPlex GX520 PC Desktop
Solid Amber light when starting the Inspiron 530 . Every time i start the Dell inspiron 530, the solid amber light comes on and it dont start. As per Dell user manual i have tried everything but of no use....
Amber led simplifies a start-up-error. This could be a number of things.
For example:
Check if HDD is connected properly
Check if RAM is connected properly / also if this is damaged your pc wont start.
Check your m/board for any loose capacitors an if they are not popped at the top.
Your LCD screen is properly plugged in to the m/board and if the cables aren't damaged they are very thin and fragile.
also could be the power supply...
Goodluck
Ryno Gerber
Jul 30, 2009 | Dell Inspiron 530 Desktop Computer
Amber light on power button of Dell Dimension 4500
cheers Pete
Nov 30, 2008 | Dell Dimension 4500 PC Desktop
Dell Precision 390 PC Desktop Logo
94 people viewed this question
Alun Cox
